Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Sign in using an external account
Register Forgot Password?
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Sep 14, 2004, 04:20 PM   #1
Personal Sales Rating: (11)
Garage is empty, add now
Drives: toyota celica
Points: 5,341, Level: 46
Points: 5,341, Level: 46 Points: 5,341, Level: 46 Points: 5,341, Level: 46
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Send a message via AIM to Deca Auto
Mechanical o2 Fix
This is how to make a mechanical o2 fix if you have a test pipe/resonator/high flow cat, that gives a cel. You can find it on ebay for about 15 dollars shipped. But why buy it when you can make it for 3 dollars using parts from your local Pep Boys?
First of all you will need 2 spark plug anti-foulers (18mm). It is made by the HELP! brand part#42002 or 42009.
You will also need a 1/2" drill bit and drill. Or a drill bit close to that size
Drill one one the anti-foulers so that the o2 sensor can fit. I recommend using a vise grip and lube for the drill bit if you ever plan on using it again.
This is how the hole should look after. If it doesn't come out nice use a dremel or a file.
Put the one anti-fouler you drilled and connect it on top of the one you didn't. Now you don't have to buy a electrical fix and splice your wires.
Here it is installed. I recommend using anti seize on all treads.
Here is one I tried and gave up on.
Offline
Old Sep 21, 2004, 06:41 AM   #2
Personal Sales Rating: (1)
caymandiver75's Avatar
Drives: 08 IS-F
Points: 19,137, Level: 87
Points: 19,137, Level: 87 Points: 19,137, Level: 87 Points: 19,137, Level: 87
Daily Activity: 0%
wow great write up! I think I may try this before installing the o2 simulator.
__________________
'08 Lexus IS-F 12.20@117 mph
'06 Lexus IS350 (Sold) 12.84@109 mph
Offline
Old Sep 21, 2004, 07:29 AM   #3
Personal Sales Rating: (8)
HKSMX6GT's Avatar
Drives: 2003 Lancer Evolution VIII
Points: 11,029, Level: 69
Points: 11,029, Level: 69 Points: 11,029, Level: 69 Points: 11,029, Level: 69
Daily Activity: 0%
I did this about 6 months ago and everything works great. Not every upgrade needs to be top dollar to be effective!
Offline
Old Sep 21, 2004, 11:05 AM   #4
Drives: 2004 Mitsubishi Lancer Evolution VIII
Points: 7,023, Level: 55
Points: 7,023, Level: 55 Points: 7,023, Level: 55 Points: 7,023, Level: 55
Daily Activity: 0%
I just did this about a half hour ago while installing my downpipe and cat delete. I'll let you guys know if the light comes on at all.
Offline
Old Sep 21, 2004, 11:10 AM   #5
Drives: 08 IS-F
Daily Activity: 0%
ok cool ! We are all anxiously waiting I do have one question though...? How does this work? I mean with adding those adapters and making it longer, which pulls the o2 sensor out, how does this work in keeping the CEL from coming on? With those 2 adapters in place, it looks like the o2 sensor will be totally out of the exhaust stream.
__________________
Offline
Old Sep 21, 2004, 11:14 AM   #6
Volunteer's Avatar
Drives: The "BATMOBILE"
Points: 9,590, Level: 65
Points: 9,590, Level: 65 Points: 9,590, Level: 65 Points: 9,590, Level: 65
Daily Activity: 0%
Guys here is one of the many threads that was started on this, many people have done this and it works for the long term. See this thread. As far as your last method using the pipe fittings you should paint it with some high heat paint that standard metal used to make pipe fittings will rust very badly when exposed to high heat and moisture, it could rust it self where you will have trouble trying to take it off. Just a heads up the anti foul adapters are the way to go. For all those with a CEL and no cat
__________________
1967 Toyota FJ40 125HP 4WD
1978 Toyota FJ40 155HP 4WD
06 Toyota Corolla Type S for "SLOW ROLLING"
Offline
Old Sep 21, 2004, 09:03 PM   #7
Daily Activity: 0%
This isn't exactly a long term test by any means, but I put my DC Sports downpipe on this morning which eliminates the catalytic converter. At the same time I installed the o2 fix used in this thread. After driving 80 miles round trip I never saw a CEL. Hopefully it will stay that way long term and I will be very happy. I spoke to another member on here the other night who is using the o2 fix and has quite a few other mods, including cams, and he also has no CEL problems.
Offline
Old Sep 22, 2004, 10:09 AM   #8
Daily Activity: 0%
I've driven about 2000 miles since I've written this and no cel. I learned about this from the subaru guys, and I'm very surprised how effective this actually is.
Heads up for most people with aftermarket cat backs: The catback may need to be lower while this is installed, b/c it has very little space between the o2 bung and chassis.
Offline
Old Sep 25, 2004, 10:09 AM   #9
Personal Sales Rating: (4)
snoop's Avatar
Drives: EVO VIII Yellow
Points: 106,434, Level: 100
Points: 106,434, Level: 100 Points: 106,434, Level: 100 Points: 106,434, Level: 100
Daily Activity: 0%
Just did mine and I am happy
I was getting cell everyday
Thanks for making this infromative post
__________________
EVOM OWNER Mark Modaressi RIP
http://www.allwheeljunkies.com/modul...myevo2%7E0.jpg
Offline
Old Oct 17, 2004, 06:27 PM   #10
Personal Sales Rating: (6)
EarsLikenElf's Avatar
Drives: 2003 Silver OZ
Points: 7,100, Level: 55
Points: 7,100, Level: 55 Points: 7,100, Level: 55 Points: 7,100, Level: 55
Daily Activity: 0%
Send a message via ICQ to EarsLikenElf
will this also work on the N/A lancer w/ a header installed? Please PM w/ details.
Offline
Old Oct 20, 2004, 06:43 AM   #11
Personal Sales Rating: (14)
outsider's Avatar
Drives: Evolution VIII GSR / MkV GTI
Points: 5,769, Level: 49
Points: 5,769, Level: 49 Points: 5,769, Level: 49 Points: 5,769, Level: 49
Daily Activity: 0%
can this be adapted to work with a helix pipe? has anyone used it on one?
Offline
Old Oct 27, 2004, 05:16 PM   #12
Personal Sales Rating: (22)
thebluesky's Avatar
Drives: faster than the cops can clock
Points: 8,227, Level: 61
Points: 8,227, Level: 61 Points: 8,227, Level: 61 Points: 8,227, Level: 61
Daily Activity: 1.7%
Daily Activity: 1.7% Daily Activity: 1.7% Daily Activity: 1.7%
Send a message via Yahoo to thebluesky
Doing this mod in this fashion (or even using just one rather than two) basically puts the o2 sensor WAY too close to the undercarriage of the car. This is especially true with an aftermarket exhaust. There is no room for movement. You might want to rethink this mod. If I get my hands on a camera, I'll post an alternate method.
I apologize if I sound overly cruel. It was a good short term idea (say 1 or 2 days), but unfortunatley not a good long term one.
__________________
Horsepower is no substitute for brains, f@#kers!!
Offline
Old Oct 27, 2004, 09:17 PM   #13
Personal Sales Rating: (0)
gtinfosys's Avatar
Drives: IX Apex Silver Evo
Points: 5,910, Level: 49
Points: 5,910, Level: 49 Points: 5,910, Level: 49 Points: 5,910, Level: 49
Daily Activity: 0%
I have the same problem, have you come up with any solutions to solve this problem?
Offline
Old Oct 28, 2004, 06:54 PM   #14
thebluesky's Avatar
yes, my friend and I have. Like I said, as soon as I get my hands on a digital camera, I'll happily post it up.
__________________
Offline
Old Oct 28, 2004, 07:54 PM   #15
gtinfosys's Avatar
Daily Activity: 0%
Right on! Get that digital camera!
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
18mm, 42009, antifouls, brand, buschur, corolla, downpipe, fix, gti, help, make, mechanical, mkv, o2, part42002, plug, sensor, simulator, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
