Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 1, 2004, 01:56 PM   #1
Silver Sponsor
Personal Sales Rating: (80)
MitsuJoe's Avatar
Drives: 03 BBY EVO by PPI and 00 Civic SI
Send a message via AIM to MitsuJoe Send a message via MSN to MitsuJoe Send a message via Yahoo to MitsuJoe
EVO Clutch Install, includes t-case removal and service manual links
EVO Clutch Install
Use at your own risk, use of the factory shop manual will help your install. I recommend air tools and a full service array of wrenches, extensions, sockets, and other tools. My removal order(OR grammar/spelling) may not be 100% correct, and there may be a better way to do everything that i did, although this is meant as a guide to help you install your clutch on your own. I may have forgot a step here or there, and that is why a reference to the service manual will help to clearup what is hard to directly understand in text. Make sure to follow all torque down specifications. If you have never done a tranny or clutch install then pay someone to do it for you, although if you are semi-experienced mechanic with a couple extra days to spare then this writeup is for you. I have worked on other cars although this still took me a little over 20 hours for removal and installation.
Service Manual links (please do not download unless you need them for sure, I don’t want to exceed my host transfer for the month because some people have never seen a service manual before).
http://www.justchil.net/dl/evo/tranny.pdf
http://www.justchil.net/dl/evo/clutch.pdf
http://www.justchil.net/dl/evo/clutch1.pdf
Underhood before jacking up:
Disconnect battery
Remove the air-box and intake pipe
Remove battery and battery box holder
Remove Upper IC pipe from manifold to buy the fans
Disconnect all wiring from top of tranny side
Remove cotter pins and washers from shifter linkage
Remove 3 12 mm bolts holding down linkage assembly and metal piece holding down slave cylinder line
Remove slave cylinder from transmission, do not disconnect it from the line, 2 12mm bolts hold this to tranny, move up to wiper area once bolts have been removed
Untorque front wheels about 2 turns then jackup and set jackstands and remove jack
Remove front wheels from car
Under the car:
Remove plastic undertray, this is a pain, but take your time so you don't break it
Remove the two tie bars, 5 14 mm bolts
Remove the downpipe 2 14 mm bolts engine side and 2 17 mm bolts catalytic side
Support the rest of the exhaust with a jack stand
Remove the soft part to the lower IC pipe
Remove the centermember that runs from front to back, 2 19 mm bolts front and 1 19 mm bolt rear, remove 14 mm bolt and nut from mount and remove corssmember
Disconnect the starter electircal wires
Remove starter from vehicle, 2 bolts, I believe they are 14 mm
Remove 3 or 4 bolts for the small metal plate for the bellhousing(flywheel) access cover, and 2 10mm phillips head screws
Drain the transmission
Axles and removal:
I only removed the driver side axle from the car because it directly interfers with the tranny reinstall, the passenger side axle can stay connected to the hub and be swung out of the way
Driver side Axle:
Remove cotter holding pin from axle nut
Have someone get in the car and firmly apply the brakes, or get an approved holder to stop the wheel from turning when breaking the axle nut
Use a breaker bar and I believe 1.25" socket on the axle nut to break it loose
After broken loose remove the nut and large crush washer
Remove the two 19 mm bolts and nuts from the strut to the hub area, be careful to not let the hanging of the rotor and caliper assembly to break any of the ABS, speed sensor, or brake lines
Remove the axle carefully from the splines not to scratch the back side of the caliper
Use a pry bar in-between the axle and the transmission to pry away the axle
Remove the axle from the tranny and set aside
Support the rotor and hub assembly by using one of the 19mm bolts back into the strut
Passenger side Axle:
Remove the axle from the tranny and swing aside towards the front of the car
Transfer-case removal:
I was unable to completley remove the transfer case from the vehicle, it may be possible but I didn't do it this way
You will need a pole slap-hammer that can pull out the output shafts from each side of the tranny, these shafts are what the axles spline into
With this slap hammer you will need to find a M8x40mm bolt that threads into the end of each input shaft (MB991721 would be useful here but I wasn't going to buy this to use it once)
Then attach the slap hammer to this bolt and after a few hits away from the car the shaft should come out of the car
Remove the M8 bolt from the shaft and repeat procedure to the other side
The driver side shaft is longer, set both shafts in a safe not dirty place
The snap rings (CIRCLIP) on the shafts are the same as a 90-94 Eclipse driver or passenger axle snap ring, the only reason I am including this is because we had to search for this replacement when the dealer couldn't get us this ring the same day, we happened to break one during the re-install, and this was the easiest way to replace the snap ring, we just returned the axle minus the ring. It helps to have a friend at the parts store.
There are 6 bolts holding the transfer case to the transmission, 3 on top and 3 on the bottom
Remove the 3 bolts on the top, the hardest bolt to understand is one that is not directly next to the tranny, it is a long bolt that is closest to the rear of the car
Remove that bolt and then the other two that are next to the tranny, I removed these from under the car reaching from the passenger side to the bolts, they all face towards the passeger side
Remove the 3 bolts on the bottom side of the transfer case assembly
By lifting up the driveshaft from behind the subframe it is possible to seperate the transfer case from the tranny, a little prying may be needed but careful not to go too far into the transfer case
It now should be possible to seperate the transfer case from the tranny and now move it as far towards the passenger side of the car as possible
Rear Mount on driver side:
There are 3 bolts that hold this mount to the tranny, they are very hard to get to although very possible once acheived, the service manual only shows to bolts but there are in fact 3 bolts
Remove the long bolt holding the mount to the car, jacking up the tranny will be required to make this bolt loose
Remove the 3 bolts holding this mount to the tranny
Remove the mount from the car
Tranny removal part 1:
There are I believe 6 bolts that hold the tranny to the engine, one must be accessed from under the car and must be removed from the passenger side, the rest must be removed from the side and top side of the tranny from the driver side above the engine bay, they are all 14mm bolts
Remove all of these bolts
Now support the engine under the oil pan using a large piece of wood to make sure to not dent the oil pan and jackup slightly
Driver Side Mount removal:
Remove the long bolt that holds the mount to the car, jacking up the engine will be required to make this bolt loose
Remove the bolt and nut
Remove the 4 nuts that hold the mount to the transaxle
Lower the engine slowly
Remove the mount from the tranny
Tranny removal part 2:
Support the tranny with a jack
All that is holding the tranny onto the car now is the spline for the clutch disc and the throw-out bearing
You must now seperate the throwout bearing from the pressure plate
To do this remove the small rubber service hole on the bottom of the tranny
Use a flashlight to see into the hole to make sure you know what you are doing, and inspect the new clutch set and try this out carefuly on the new set to try this process
Push the release fork towards the driver side of the car
While pushing this in get a long flat screw driver and wedge it in-between the diaphram springs and the wedge collar of the throwout bearing
Rotate the screwdriver 90 degrees to disengage the bearing from pressure plate diaphram (refer to tranny PDF page 24 for more info)
Now slowly lower the tranny jack and move the tranny around to remove it from the splines of the disc
If you like being crushed by the weight of a very heavy tranny get under it like me to support the weight of it coming down, or get some old tires to support the tranny so it doesn't smack on the ground
Tranny should be out now, time for a break :P
Clutch removal:
I belive there are 8 bolts that hold the pressure plate to the flywheel
Remove these bolts
Remove the pressure plate and clutch disc
Flywheel removal:
Remove the 7 bolts from the flywheel
Remove flywheel from engine
Throwout bearing removal:
Take the tranny out from under the car and place in a well-lit area to inpect the bearing, most of the time on low-mileage installs it doesn't need to be replaced, although if you have a new one make sure it is as good as the OE unit and you should replace if you have the new part anyways
To remove the bearing you must remove the bronze colored cap that looks like a freeze plug on top side of the tranny
Now disable the springs that cause the fork to spring back towards the tranny
Remove the single 10mm bolt that holds the fork rod
Carefully pull the rod out of the holes and from the tranny plug you removed making sure to take note of the cloth washers and spring arrangement
After the rod is out of the top of the tranny it should now be possible to remove the fork and the throwout bearing
There really isn't a good writeup of this in the service manual, just stare at the assembly long enough and this should make sense
Installation:
If you follow all these steps in an opposite order you should be able to reassamble it, I will make a reinstall writeup if demand asks for it
From bishiboy:
I just installed my Exedy using your write up and my service manual.
I found a few items that you can edit on your write up.
Under the car:
The centermember bolts are 17mm not 19mm.
Transfer case removal:
You only need to pull the driver side output shaft, the short one on the passenger side is contained in the transfer case.
The 6 bolts are 17mm.
Rear mount on driver side:
You want to break the long bolt going thru the mount loose before removing the 3 bolts.
There are 5 bolts, two must be accessed from under the car. There is also 1 10mm bolt above the starter that holds the sheild behind the fly wheel. (maybe that's why you said 6 bolts?)
Clutch removal:
There are 6 bolts.
Installation:
I'd would mention that you can't just jack the tranny straight up. The front differential has to go in 1st the rotate the tranny, being carful not to pop the "pull type" spring thing out with the shaft, (which I did twice).
Also when inserting the output shaft back in, screw the same bolt in and tap it in lightly with a hammer. Also refill tranny and top off any fluild that leaked from transfer case.
Ballistic_EVO Addition:
This past weekend i did an install on a 2005 evo. Basically the install is all the same except you need to deal with the ACD. There is a post floating around about how to do it without removing the ACD line i tried this method which was to back the bolt out as your pulling the ACD so your dont need to disconnect the line. Anyway i couldnt find the leverage to break this bolt loose because you can only get to it with a 17mm wrench. After giving up on this method i figured i would just take the ACD line loose and save myself headace and trouble. After removing the ACD line with a 22mm socket the line will begin dumping ATF fluid all over. I just plugged the line off untill i got the bolt out of the T-case and reconnected the line making sure to put the 2 brass washers back on each side of it. Then continue thru the install just as if it was an 03-04 model. Once you get back to the ACD just follow the steps reveresed to put the bolt back in.
Ok so now you have everything back together you need to bleed the ACD make sure you top of the fluid for the ACD its ATF III rated fluid. Get someone in the car and someone under the car the person under the car needs to break loose the bleeder screw on the ACD 10mm wrench and a piece of plastic line for spotting bubbles. Get the person in the Car to turn the key to the on postion but not start the car and have them press the gas pedal to the floor. This will turn the ACD pump on for 5 seconds. Repeat this process till there are no more air bubbles coming from the bleeder screw. close it and your done!
__________________
Paradigm Performance Innovation
http://www.paradigmperformance.net
Michigan's EVO Club @ www.miEVO.net
Offline
Old Aug 1, 2004, 02:23 PM   #2
Personal Sales Rating: (44)
justchil's Avatar
Drives: EVO VIII, 05 LGT
Send a message via AIM to justchil Send a message via Yahoo to justchil
Mirrored your pdf's no worries on transfer. If you want change/add these to ur links they will always be there
__________________
BR Stage 4 FP Green
Buschur Racing
MY EVO
Offline
Old Aug 1, 2004, 04:56 PM   #3
Silver Sponsor
MitsuJoe's Avatar
thanks for the space...I appreciate the concern
__________________
Offline
Old Aug 1, 2004, 10:55 PM   #4
Personal Sales Rating: (2)
jk_addict's Avatar
Drives: 03 Yellow Evo
Send a message via AIM to jk_addict
Isn't Joe the Sh!t?!
Not only did you help me (save my ass) with the clutch install, but you remembered all that sh!t? Damn. Even all the bolt sizes... Anyways, thanks a million! BTW, clutch is breaking in nicely, and performing sweeeeeeet. Keeping Rpms low for 400-500 miles... got 100 out of the way today!
__________________
-Ryan
03 Yellow Evo
96 Monte Carlo
If you live in Michigan, Check out www.MiEVO.net for a fast-growing Evo & Lancer Club!
Offline
Old Aug 2, 2004, 04:00 PM   #5
EvoM Moderator
Personal Sales Rating: (90)
mitsuorder's Avatar
uhh... I think this earns him title of resident gearhead
__________________
"If ye love wealth better than liberty, the tranquility of servitude than the animated contest of freedom, go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that you were our countrymen!”
Samuel Adams
Forum Rules & Regulations
Offline
Old Aug 2, 2004, 05:17 PM   #6
Personal Sales Rating: (4)
Wizard_of_Evo's Avatar
Drives: X GG MR
Send a message via AIM to Wizard_of_Evo
hell ya! gearhead it is! he gets my vote.
Not that that means anything around here!
__________________
2003 VIII - 11.74@118.60 - SOLD
2008 GG MR
Offline
Old Aug 2, 2004, 05:34 PM   #7
Personal Sales Rating: (70)
VTECH8TR's Avatar
Drives: Mucho cars
Send a message via Yahoo to VTECH8TR
WOW,
Awesome detailed writeup......
__________________
1 Turbo 2 Liters 3 Diamonds 4 Doors
In Memory of Michael B. Fleming 05/29/07
________________________________________
*** PLEASE READ! New Policy regarding Scammers ***
Please respect our forum rules here:
http://forums.evolutionm.net/evom-newbie-faqs-forum/announcements.html
Offline
Old Aug 2, 2004, 05:56 PM   #8
Silver Sponsor
MitsuJoe's Avatar
well someone point a moderator to this thread and tell them to give me new status...that would be great...
__________________
Offline
Old Aug 4, 2004, 04:17 PM   #9
Personal Sales Rating: (1)
cocoabro's Avatar
Drives: EVO VIII
Damn, that's one sweet write-up. I shoulda waited a couple weeks on the Exedy and saved myself a few hundred bones. Good stuff Joe.
Offline
Old Aug 6, 2004, 01:30 PM   #10
Daddymac's Avatar
Drives: 2003 VW GTI 1.8T 20th Anniversary
Send a message via MSN to Daddymac
Awesome right up bud, i mean SIR GEARHEAD.....or should we just make that LORD GEARHEAD! lol
__________________
VW GTi 1.8T - 20th Anniversary Edition
REVO Tuning - Stage 1
Neuspeed 28mm RSB
Neuspeed P-Flow intake
Sparco Shift knob
18" OZ Aristo's
Energy Suspension Dog bone bushings
Kamei Sport grill
R32 Short shift
2004 Ralliart (Black) - STOLEN!!!!
- I had stuff
Offline
Old Aug 17, 2004, 12:50 AM   #11
Personal Sales Rating: (17)
lil'evil_evo's Avatar
Drives: Wicked White IX
Nice write up. I wish I had this 15,000 miles ago.
Offline
Old Aug 17, 2004, 01:48 PM   #12
Silver Sponsor
MitsuJoe's Avatar
Thanks, I just did my stainless steel clutch line, in some ways I think that was more tough than trying to get at half of the bolts that I did for this tranny job. What was supposed to be a half hour job eneded up being closer to 2 hours and I lost count how many copper washers fell to the abyss somewhere in the EVO.
__________________
Offline
Old Sep 2, 2004, 07:22 AM   #13
Registered User
Personal Sales Rating: (0)
EVOag's Avatar
thanks joe.... I will attempt this myself....
do you suggest friends assistance as well..???
Offline
Old Sep 2, 2004, 08:34 AM   #14
EvoM Moderator
mitsuorder's Avatar
I would suggest a spair set of eyes for the job because you will find yourself attempting to be a contortionist at times to get your hands where they need to be.
__________________
Samuel Adams
Offline
Old Sep 2, 2004, 10:47 AM   #15
Silver Sponsor
MitsuJoe's Avatar
I would have at least a friend to help you that knows what they are doing. And unles syour a big guy then maybe a way to lift the tranny up after you install the clutch. I personally bench-pressed the tranny and got it in the splines. It took a couple of times, although we a friend or two's help I got it in there. Best of luck with your process. Post your progress or any changes that need to be made in this when your done.
__________________
Offline
Tags
2002, bleed, case, clutch, evo, evoix, evolution, hammer, install, ix, lancer, location, mb991721, mr, removal, screw, slide, transfer, vii
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
