Wiring diagram for Lancer and EVO VIII
Old Nov 6, 2003, 09:51 AM
benji's Avatar
Post Wiring diagram for Lancer and EVO VIII(look inside)
Enjoy, use it wisely . (Mods might want to make it a sticky).......
wire / color / polarity / location....
12volts white + ignition harness
Starter black/yellow + ignition harness
Ignition black/white + ignition harness
Accessory blue/black + ignition harness
Second Accessory blue/white + ignition harness
Notes: Not required for remote start.
Keysense blue ignition harness
Notes: The wire rests at ground with the key out of the ignition cylinder, and goes to an open circuit when the key is inserted.
Power Lock purple - driver kick, door harness
Power Unlock lt. green - driver kick, door harness
Lock Motor blue/red 5wi driver kick, door harness
Unlock Motor white 5wi driver kick, door harness
Parking Lights+ grn/yel (L), grn/wht (R) + wht plug bottom of fuse box
Hazards white - hazard switch
Turn Signal(L) lt. green or white/blue + driver kick, harness to rear
Turn Signal(R) yellow + driver kick, harness to rear
Reverse Light brown + driver kick, harness to rear
Door Trigger white - wht plug bottom of fuse box
Dome Supervision use door trigger
Trunk/Hatch Pin green/orange - light in trunk
Factory Alarm Arm N/A
Factory Alarm Disarm gray - driver kick, door harness
Tachometer black/yellow or black/green ac either ignition coil
Brake Wire green + brake pedal switch
Parking Brake blue/red - parking brake switch
Horn Trigger blue/red or red - steering column
Notes: It is blue/red on the standard models and red on the Evolution VIII models.
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: DEI 555U (requires a programed key for remotestart)
Notes: Only the Evolution VIII models have the immobilizer.
Old Nov 6, 2003, 09:57 AM
benji's Avatar
And here is a diagram for use of a Turbo timer w/ aftermarket alarm. Enjoy....... And if you guys need any help email, aim, pm me for help on the info i have provided for you....
Old Nov 21, 2003, 05:41 AM
c5racr1's Avatar
I need the speaker wireing diagram, I have changed my speakers and can't figure which lead is the + and which is the -, plays either way. thankx
Old Nov 24, 2003, 11:37 PM
bpclements's Avatar
What kind of relays are those and where can I find them at?
Old Jan 8, 2004, 05:12 PM
MrBonus's Avatar
Jesus, where were you two weeks ago?!
Old Jun 4, 2004, 01:17 PM
lalu728's Avatar
hey can someone give me the diagram for the tachometer. I got all the wires hooked up except the coil ignition wire. I have no idea where that is suppose to go. Thanks
Old Jun 4, 2004, 01:45 PM
Ludikraut's Avatar
AFAIK, the speaker wires in the Evo are as follows:
+ = solid color wire
- = striped wire
That's how I hooked up my Infinity speakers, and they are working fine (read: not out of phase)
l8r)
Old Jul 10, 2004, 11:17 PM
Registered User
fastmitsu18's Avatar
I have a quick question. Anybody know if the lancer and evo ecu clips the same? the reason I ask, is because I want to know if an evo patch harness will work on a lancer or mirage. and if the clips are the same, then that mean it'll work. if they are different then that means, it wont.
thanks
David
Old Aug 1, 2004, 04:48 PM
wprettyboy's Avatar
cant get my lights to blink when arming!
i installed my alarm today and i cant get my lights to blink, i used the diagram on this post and could not find the wires discribed please help!!
Old Aug 1, 2004, 06:24 PM
wprettyboy's Avatar
bump
Old Nov 22, 2004, 12:26 PM
botemarc's Avatar
CHL-2 Keypad Starter Kill System
a couple of questions.
I only have a immobilizer on my Lancer Evo, is this considered as an alarm for the BLUE wire to connect to?..I do not know where to connect the blue wire.
On the relay, #30 connects to the wire leading to the starter motor or to the key ignition. This applies for the relay # 87. Which end connects to which wire.
The red wire connects to the 12 V Battery, would this be the constant power?
The yellow wire - is this for the accessories wire or is this the 2nd ignition wire?
Please help.
here is my wiring info for my car
Constant +12V: White(+) Ignition Switch Harness
Starter Kill: Black/Yellow (+) Ignition switch harness
Ignition +12 Volts: Black/White (+) Ignition switch harness
Accessory: Blue/Black (+) Ignition switch Harness.
Please guide me to which wires to use or not use. Thank you.
...This was a question stated by my friend. Basically, he needs help on which wires to use on the evo.
The yellow wire that he is talking about is suppose to connect to, based on what the instruction said.."Connect Yellow wires to 12V when Ignition is in both "On" and "Start". Which wire would this be? (White, Black/White, or Blue/Black)
The red wire is suppose to connect to a "Fuse 3A", (what kind of fuse is this), which is suppose to go to a 12V Battery. Can we assume that this is the constant power and if so, which wire should it be (white, Blk/wht, or Blue/blk).
Thats basically it. Anyone who can answer this, I would greatly appreciate it. Thank you.
Old Nov 22, 2004, 02:12 PM
VTECH8TR's Avatar
Nice,,, Thanks for the writeup .
Old Jan 24, 2005, 07:21 PM
benji's Avatar
wow sorry guys here is the diagram for the turbo timer/ alarm
been a way from the forums to long....
Old Jan 24, 2005, 08:20 PM
hksevo7's Avatar
Anyone Have The Wiring Diagram For The Ecu?
Old Jan 25, 2005, 04:15 AM
apexernsx's Avatar
ECU and CEL
What is the effect of having no CEL(foreign speedometer). What code if any would be thrown? What would you do with the CEL wires to prevent, wire in another light or?
Quick Reply: Wiring diagram for Lancer and EVO VIII
