Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 6, 2003, 12:04 AM   #1
Personal Sales Rating: (4)
Headlight Adjustment
I posted this info in response to another thread elsewhere, but it probably is better suited here aswell in the how-to section.
The following is one method and the one I used to succesfully adjust the headlights. I don't have first hand experience with any other methods like using a screw driver or torx wrench, but if there are any others out there that have experiences or other ways of succesfully adjusting the lights feel free to contribute.
Tools used.
- 1/4" drive
- 10mm socket
- drive extension (optional)
Here's the driver side with the socket drive on the adjustment nut. Turn counter-clockwise to raise.
Offline
Old Dec 6, 2003, 12:05 AM   #2
Passenger side with the coolant overflow bottle moved over to the right. The socket drive also has a 3" extension on it to reach the nut a little easier. Again counter-clockwise to raise.
Offline
Old Dec 6, 2003, 06:02 PM   #3
Personal Sales Rating: (19)
Bluesmaster's Avatar
Drives: 2009 Infiniti G37x
Send a message via Yahoo to Bluesmaster
This technique worked perfectly for me. Now my lowered Evo has proper headlight coverage. The whole thing took maybe 15 minutes.
Offline
Old Dec 8, 2003, 11:26 AM   #4
Personal Sales Rating: (1)
Same here. I'd recommend it. It was one of the easiest and best improvements I've done.
Offline
Old Dec 12, 2003, 10:19 AM   #5
Personal Sales Rating: (0)
Drives: 2003 Silver Evolution 8
I must be nuts, the only adjustments I can seem to make are on the fog lights and the high beams. What am I missing here?
__________________
Carbon fiber boost gauge housing / Blittz FATT / Apexi SAFCII / K&N filter with MAF adapter. For now... By the way, thanks for the warranty block Mitsu!!!!
Offline
Old Dec 12, 2003, 10:35 AM   #6
Personal Sales Rating: (2)
smackdaddy's Avatar
Drives: 2005 CTS-V
Send a message via AIM to smackdaddy Send a message via Yahoo to smackdaddy
I did mine last night just as shown in the above pictures and I must say it was much easier than everyone is making it out to be in some of the other posts on the same subject.
Offline
Old Dec 12, 2003, 11:06 AM   #7
Drives: 03 Lancer Evolution VIII
i used a big philips screwdriver and it took about 15 min. very easy.
Offline
Old Dec 12, 2003, 11:18 AM   #8
AutoXer's Avatar
Drives: 03 Evolution VIII
Quote:
The plastic gear may be slipping. Mine did. I had to use a flathead screwdriver to coax it along, in combination with the 10mm socket. The metal gear adjusts the high beams and the plastic gear does the lows. Most people are moving both with this method.
Offline
Old Dec 12, 2003, 11:22 AM   #9
Personal Sales Rating: (6)
Space Monkey's Avatar
Drives: 2003 Rally Red Evo VIII
Send a message via AIM to Space Monkey
Works perfectly! Thanks for the write-up!
__________________
Dynoflash StageRev Flash / HKS 272/272 Cams / Helix Intercooler Pipe Kit / B&M Shortshifter / Vishnu Cam Gears / Tanabe Springs / RMR Intake Pipe / K&N Powerflow / Greddy Type-S Blowoff / Ultimate Racing 3" Downpipe & Test Pipe / Helix Catback Exhaust/ Walbro Fuel Pump / Magnecor 8.5mm Plug Wires / Grounding Wire Kit
Offline
Old Feb 8, 2004, 06:59 AM   #10
wspy's Avatar
Drives: EVO 7
Guys please note that the pics that nOOdle posted are showing adjustment for the high-beam bulb! The driving light bulb adjustment nut/screw [HID] is the next one over towards the fender! Same general area with reference to the pics [which are for adjusting the highs] but directly behind the HID bulbs!
As stated in the previous posts with reguards to this subject, the proceedure takes only a few minutes. I didn't even have to use the ratchet handle to turn the nut.
Cool
Offline
Old Feb 8, 2004, 08:54 AM   #11
According to service manual I've got the right adjustment, not to mention many others who have successfully adjusted their headlights over here.... Easy way to raise/lower headlights
And the manual mentions that there is no seperate High beam adjustment. It moves with the low beam. I suspect the adjustment you're making is to the fog lamps.
Offline
Old Feb 9, 2004, 08:07 PM   #12
Personal Sales Rating: (7)
SoFlaBBY's Avatar
Drives: 03' Lancer Evo
Send a message via AIM to SoFlaBBY
Great write-up...took me about 15 minutes to do and it is so nice being able to see!
Offline
Old Feb 10, 2004, 08:09 AM   #13
gunzo's Avatar
Drives: Lancer Evolution SST
Send a message via ICQ to gunzo
WSPY is actually correct .. unless you don't have a electronic tilting headlight .. there's actually THREE screwy things ..
the low beam control is also different .. it's encased in a plastic .. and you need to make sure the light is off when you adjust .. otherwise the headlight electronic tilt will go crazy everytime the light is turn on ..
Where your photo show is for the high beams .. and closer towards the radiator .. there's another adjustment knob for the foglights .. it's higher up and rather inset ..
Again .. I have not seen the non electric tilt headlights .. so your instructions may still hold
Thanks for giving me the idea to adjust too !!!
Offline
Old Feb 10, 2004, 09:02 AM   #14
Alright, but let me repeat... according to the manual there's no seperate highbeam adjustment some keep referring to. But hey... whatever works.
Offline
Old Feb 10, 2004, 09:08 AM   #15
SoFlaBBY's Avatar
I did my headlights last night exactly according to the pics and info posted by n00dle and everything worked fine...
Offline
Tags
2008, adjust, adjusting, adjustment, ajustments, beam, evo, evolution, headlight, headlights, high, ix, lancer, lowe, screw, stuck
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
