Mar 24, 2004, 10:21 AM
#31
Personal Sales Rating: ( 0)
Drives: 2003 Apex Silver Mitsubishi Evo VIII
delete please
(mods delete this post)
Offline
Mar 24, 2004, 10:27 AM
#32
plates!
heres those little plates...i cant adjust my headlights cuz these buggers!
Offline
Mar 24, 2004, 03:02 PM
#33
Personal Sales Rating: ( 7)
Drives: 2006 EVO 9 SE
My plates look different than yours. Your look like aluminum and mine is just a black color. Oh well, maybe the plate can be taken off?
__________________
2006 Graphite Gray Evo 9 SE
Offline
Mar 24, 2004, 04:59 PM
#34
headlights
bump
Offline
Apr 8, 2004, 12:03 AM
#35
Personal Sales Rating: ( 3)
Drives: 2005 Mercedes E320 CDI
Quote:
Originally posted by AWDEVO8
I must be nuts, the only adjustments I can seem to make are on the fog lights and the high beams. What am I missing here?
The black plastic gear is the HID adjustment. n00dle is absolutely correct in his how-to if, while twisting the 10mm nut, you’re fortunate enough to also spin the black plastic gear at the same time. The problem I experienced is that my black plastic gear is nearly seized in place. To prove that the black plastic gear is the one and only HID adjustment, I removed the two screws that hold it in place on the passenger side and moved it by hand. With the plastic gear removed it is absolutely clear that it is the HID adjustment and the 10mm nut is the high beam adjustment. It’s a crappy design. The plastic gear should be metal or just a separate adjustment altogether.
Since the driver’s side is difficult to remove, I had to force it around with a large flat-head screwdriver in a clock-wise motion to raise it. I manipulated the outside round part, not the teeth. It’s not easy and took over 200 ‘flicks’ since each flick is at best a quarter turn. Removing the high-beam connector eases access. Make the adjustment with the lights off and check your progress every 50 flicks.
After you have the HIDs where you want them, go back and adjust your high beams. I used a Mikita screw gun with a 6” Phillips bit. With the high beams on, you can literally watch the light move up and down. Of course you’ll want to be sure the black plastic gear isn’t moving. (If it didn’t move before, I don’t know why it would start moving now.)
Hope this helps the frustrated people.
Offline
Apr 8, 2004, 02:02 PM
#36
Personal Sales Rating: ( 6)
Drives: 2003 Evolution VIII
Just did it!
Offline
Apr 10, 2004, 04:28 PM
#37
Personal Sales Rating: ( 5)
Drives: 2003 Evo 8 R.I.P. Now 2006 IX MR Wicked White
I did it with full power on and the electronic adjusters didnt try to adjust mine......Marked highest adjustment setting on wall then adjusted headlight knob to the lowest setting...
Adjusted screw all the way to the mark I left,now I have a good adjustment...The tanabe's I installed totally made the headlights hit the floor...
I did this just like the post mentioned with a small socket and worked perfect.....no extension needed but I did take out the coolant over flow bottle.. took 10 minutes and worked PERFECT !!!!!
__________________
IX MR
Cosworth Cams
Buschur Upper Pipe
Buschur Vclamp Bullet TBE
Tuning Tech Maf Pipe With Filter.
HorsePower Freaks LICP
Hallman Pro RX MBC
Walbro Fuel Pump
Denso 720 cc
Tuning Technologies Tune 341 Hp 324 Torque
Offline
Jul 4, 2004, 03:39 PM
#38
Personal Sales Rating: ( 19)
Drives: 330i zhp
I just tried this today and like someone else said before, I also have a metal pieces over my adjusters. There's nothing that looks like it'll fit a 10mm wrench.
I have bent the metal piece to be able to get to the hole underneath and that looks like it will fit a philiphs screwdriver. Will try it tonight when it gets dark enough.
Anyone have any more pictures?
There's so little space there you can hardly fit a gillete inside, it's crowded with wires...
Offline
Jul 14, 2004, 05:32 AM
#39
Drives: EVO8
Okay so were saying that in order for us to adjust the low beam independently from the high beam we should remove the 2 screws that hold the plate with the black plastic gear, make the adjustment to the low beam and high beam then put the plate back on or even leave it hanging for future light adjustment as the drivers side is difficult to remove due to the intercooler resvoir?
__________________
'05 SDUTY
'05 TL
'03 SVT Cobra
'04 MDX Sagebrush
Offline
Jul 23, 2004, 07:28 AM
#40
Personal Sales Rating: ( 1)
Drives: 04 Weightless White Evo
So is it safe to adjust the lights with them on? I don't care one way or the other, it just seems that it'd be a lot easier with the lights on.
Thanks!
__________________
2004 Weightless White Evo. Sold, but not forgotten!
Offline
Aug 1, 2004, 03:21 PM
#41
Personal Sales Rating: ( 4)
Drives: Apex Silver 2003 EVO
Did this mod yesterday. Very simple, only took a few minutes. I was able to adjust the headlights with them on, it just took a few turns of the 10mm nut to raise them where I wanted. Can't wait to drive at night.
Thanks to whoever originally posted this mod!
Offline
Aug 27, 2004, 01:32 AM
#42
Drives: 2003 Rally Red EVO
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRRRGGGGGGGGGGGGGGG GGGGG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
You people that had no trouble with this are fuskers!
I do the passenger side fine w/ the 10mm. Replace the reservoir & then go to do the "easy" one. Well, that one is stripped as hell and there is no coaxing it (after about an hour trying, and tearing it up even more in the process). With every "flick" it just comes back to the not-flicked position and laughs at me. Tried the 10mm + "flicking" to no avail. It's just not cooporating.
So now I'm thinking, I'll just take the damn thing off. After all it's just 2 little screws holding it on, no big deal. OK, well the 2 little screws are about impossible to get to, so I get the bright idea that I'll remove the intercooler sprayer reservoir to get some more room. There is only one bolt that I can see, so I take that one off. Then the bolt falls through somewhere. That wasn't the only thing holding that reservoir in, so I can't remove it to get to the bolt, so now there is a loose bolt in my engine bay somewhere. I don't feel like jacking the damn thing up in my garage, taking the plastic undercover off, etc. This "15 minute" project has turned into a 2 hour + headache, and all I got from the process is a passenger side headlight way up in the air that I now have to go back and put back the way it was...All I want to do is be able to see at night, so fusk  for trying to save $0.05 using a plastic gear that should be metal.
Offline
Sep 26, 2004, 06:03 PM
#43
Personal Sales Rating: ( 43)
Drives: 06 WW IX MR, 08 Yamaha R6, 09 Audi A5
hmm.. i just attempted this mod and it would click for every turn correct? i had the hids on against a flat wall, and i taped the wall where the top of the light shown was. I turned it c-clock and it would click but nothing happened. It didnt raise =\ any ideas?
Offline
Sep 26, 2004, 10:37 PM
#44
Personal Sales Rating: ( 12)
Drives: 05 AS MR (sold), 07 G35x & EvoX?
can you post a pic which black plastic are you referring to?
the orginal post from N00dle is adjusting the high beam headlight,
and counter-clockwise?
Offline
Oct 12, 2004, 10:43 AM
#45
Personal Sales Rating: ( 13)
Drives: 04' Apex Silver EVO VIII, 08' CSM S2000
i did mine this morning. strip both side plastic gear, really PITA to just adjust my passenger side low beam. so after 2 hrs of hard work, now both driver and passenger beam are at the same lvl. plus i did the one lvl higher adjustment, so i can see further at night time, cant wait till tonite so i can see how much further the beam can shine.
thanks to whoever started this tread to help us out.
__________________
439WHP / 362TQ 50T on pump gas@23psi
11.6@120mph 1.6 60ft 55F (11/11/06)
http://mojipage.com - a free personalized start page for your mobile phone
Offline
Tags
2008, adjust, adjusting, adjustment, ajustments, beam, evo, evolution, headlight, headlights, high, ix, lancer, lowe, screw, stuck  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
