Feb 12, 2004, 07:18 AM
Personal Sales Rating: ( 0)
Drives: EVO 7
Yeah, like nOOdle said "whatever works", I guess!
The adjustment I was talking about was for the type headlight that has no HIDs or electronic tilt adjustment. Just some plain old Halogens, and whats more - no fogs!
Came on some of the JMD evo7s; so I installed an HID kit!
Offline
Feb 15, 2004, 08:26 AM
Personal Sales Rating: ( 2)
Drives: Lancer Evolution SST
Hi N00dle .. as promised .. something different for the electronic tilt headlights ..
location of the low beam adjustment ..
Offline
Feb 15, 2004, 08:28 AM
Zoomed in view .. noticed doesn't have the gear thing ..
Offline
Feb 15, 2004, 08:33 AM
view of the high beam and the foglights ..
Where yours are .. so there are some differences ..
This is for those with the electronic tilt headlights
PS N00dle has a great idea .. thanks to him I got mine adjusted so I can just shine those %#)^($% driving around with highbeams on.. yet won't bother others at other times
Offline
Feb 15, 2004, 01:56 PM
Drives: EVO 8, 5.0LX, Ducati Monster , Kawasaki Z1000
Very nice! The write up and good quality photos are appreciated!
Offline
Mar 10, 2004, 04:35 AM
Personal Sales Rating: ( 7)
Drives: 2006 EVO 9 SE
I'm confused. I had my car at the dealer last week and asked them if they could adjust my low beams (HID's) being they've always seemed too low, but now are worde with my car being lowered. The tech tried everything you posted and nothing worked besides raising the fog light and high beam. He called Mitsu and the engineer told him that it's not possible to adjust the low beam.
I've read every post on this thread and I can't figure out if you guys are adjusting the fogs and highs or you are adjusting the HID's.
I'm willing to do this myself, but I want to know for sure what I'm doing.
__________________
2006 Graphite Gray Evo 9 SE
Offline
Mar 10, 2004, 05:41 AM
If you have the electronic tilt ( ie near the foglight button.. there's numbers from 1-4 adjusting the tilt electronically) .. then u'll find the tilt mechanism in a diver's helmet shaped thing (2nd picture) .. you need to make sure there's no power when you adjust .. coz the electronics will try to readjust back ..
what I did was shine at a wall .. switch off then adjust the lights .. switch on and compare the position .. then adjust until I was happy
Good luck
Offline
Mar 10, 2004, 01:37 PM
When you say "if you have the electronic tilt" are you meaning that just incase I have a RS? If not, I though all Evo's came with the electronic tilt besides the RS.
Anyways, I went out to my car and seen the place shown in the pic, but what do I use to stick inside there? By "no power" your just meaning the headlights need to be off right?
I think I'm making this more confusing than it should be, but the dealer totally screwed me up by telling me that it wasn't physically possible to adjust these things.
__________________
Offline
Mar 10, 2004, 05:16 PM
Yes .. not all evo comes with the tilt headlight .. and HIDs ..
Philips head screwdriver .. and yes .. make sure the headlights are off before you start adjusting ..
If you leave the headlight on, then you'll hear the motor whining away trying to readjust itself whenever you turn the screw..
Offline
Mar 14, 2004, 11:03 PM
Personal Sales Rating: ( 32)
Drives: '07 FZ1. BR built HTA35R EVO VIII SOLD:(
D'oh!  Thats why when I adjusted my lights I heard the motor for the lights kick on. Driver's side did it twice towards the end of the adjustment, thought I was adjusting them to far up with the lights set on two trying to get them back on zero. I'll have to do it again with the lights off for the drivers side.
Offline
Mar 14, 2004, 11:16 PM
Drives: EVO X GSR
some other people jump in here , i thought every EVO came with tilt lights and HID , standard equip. listed on my standard features part of the EVO 8 that is .. GUNZO may want to go to the mitsu site and look at the options list i didnt see HID as an Option. only options are .
http://www.mitsubishicars.com/MMSA/M...&1079329819567
SELECT OPTION PACKAGE
Please note that some combinations may not be available.
Large Carbon-Fiber Rear Spoiler $ 600
Power Sunroof $ 750
ACCESSORIES
Please note that the *MSRP does not include installation cost.
6-CD In-dash Changer 486
Air Dam $ 231
Brake Cooling Air Guides 149
Car Cover - JDM $ 216
Cargo Net $ 29
Floor Mats $ 56
Door Sill Scuff Plate Kit 92
Sunshade $ 64
Strut Tower Brace - Fron$ 422
Strut Tower Brace - Rea$ 385
Hyperground Cables $ 219
Instrument Cluster Surrou$ 75
License Plate Frame $ 29
Nose Mask $ 147
Shift Knob $ 113
Parking Grip Brake $ 224
Side Window Air Deflector$ 84
Sports Meter Kit $ 464
Sports Pedal Set $ 76
Wheel Locks $ 25
TOTAL MSRP*
$ 28,987
__________________
So many MODS so little TIME
Offline
Mar 14, 2004, 11:17 PM
Personal Sales Rating: ( 3)
Drives: como tu abuela
I did mine with the lights on, adjustment switch on "0" and no motor whining . Now they are wayyyyy up where I like them
Offline
Mar 15, 2004, 11:00 PM
Quote:
Okay....what side is this? I looked on my passenger side and this thing is covered up by a little plate. I can't even see the drivers side. This is really starting to make me mad. I sat out in the garage and looked all around and can't get anything to even come close to fitting in there. Did you remover the little plate or something?
__________________
Offline
Mar 16, 2004, 05:13 AM
Passenger side .. the white plastic you see is the coolant overflow bottle .. I didn't remove any plates .. what you see on the fotoes is exactly what I see .. the gears are inside those little portholes .. if you only see the gears.. you need to look deeper inside .. find where the main beams are, then look back from there .. the adjustment thing should be pretty close there ..
AWDturbo4 .. I had no problems on the driver side also .. but the other side kept adjusting back by itself
mksevo .. the evo I drive is also not in the options list .. does that mean my car doesn't exist ???  .. you'll never know what dealers do to lower their own costs .. neither did the list you supply indicate that electronic tilt is standard equipment list ..
Offline
Mar 24, 2004, 09:58 AM
Drives: 2003 Apex Silver Mitsubishi Evo VIII
Im having the same problem. My "portholes" to adjust the low beams (I have electronic tilt) are covered up by little plates!
Offline
Tags
2008, adjust, adjusting, adjustment, ajustments, beam, evo, evolution, headlight, headlights, high, ix, lancer, lowe, screw, stuck  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
