Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 28, 2009, 10:38 PM   #1
Personal Sales Rating: (3)
Drives: 2006 IX MR
Best way to install/remove bushings
I'm looking at installing the Perrin PSRS as well as some other suspension bushings this winter and was wondering if I 'have' to have a shop press or can I do it another way with a ball joint kit, or...
If I can avoid taking the stuff to a machine shop, that would be great (I will if I have to though).
__________________
Tuned by Mellon
Offline
Old Oct 29, 2009, 09:16 AM   #2
Personal Sales Rating: (26)
gsrboi80's Avatar
Drives: 03 TB VIII
Press them out then in
__________________
4WS TUNED VIII
Quote:
Originally Posted by Evoryder View Post
Its' the turbo punching out for the day
Offline
Old Oct 29, 2009, 10:58 AM   #3
Personal Sales Rating: (10)
Solo II Evo's Avatar
Drives: 2003 Evo GSR
Send a message via AIM to Solo II Evo
Harbor freight tools sells a press for $100 or so. Definitely worthwhile!
__________________
Schreinerized
An uber 03 LY Evo
Tracked, Autox'ed, and finally, no longer a daily driver.
Featuring: Exedy Twin, Custom Valved PSS9s (12k/16k), Baller NT03+M, and the usual stuff found on most Evos.
WTB: Rota P45R, 18x9.5". Any color.
Offline
Old Oct 29, 2009, 11:14 AM   #4
Personal Sales Rating: (7)
vicksen's Avatar
Drives: evo IX MR
For those you will want to use a shop press with a proper sized die. A harbor freight kit will push the old rubber bushing out, but leave the metal ring in the control arm. You want it all out. If you went with the offset psrs make sure you line up your marks with a straight edge and use a sharpie to put reference marks to line up with when you press the new bushings in. Hope this helps.
Online
Old Oct 29, 2009, 11:49 AM   #5
Drives: 2006 IX MR
So a press it is, I was hoping to get away with not needing one. How would I get the metal ring out? Pliers and a lot of swearing? Also, I'm unfamiliar with presses, do I need a workbench or will it work on my garage floor?
Vicksen, thank you for the suggestion of the sharpie and straight edge!
__________________
Tuned by Mellon
Offline
Old Oct 29, 2009, 12:08 PM   #6
gsrboi80's Avatar
Drives: 03 TB VIII
No you'll want an anchored press bench to press those suckers out
__________________
4WS TUNED VIII
Offline
Old Oct 29, 2009, 12:24 PM   #7
Personal Sales Rating: (8)
Chemwarrior's Avatar
Drives: 2010 Bathurst Black Genesis Coupe V6 Track
You could try cutting the old metal ring and then using a pair of pliers to pull the pieces out. Remember lube is your friend.
__________________
Tuned by Mellon
TRSCCA
14 TSM
Offline
Old Nov 2, 2009, 09:00 PM   #8
Personal Sales Rating: (1)
Its not worth cutting it. Just get it pressed out at a good machine shop. Definitely worth it
Online
Tags
bushings, press, remove, shop
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
