Oct 26, 2009, 06:04 PM
Personal Sales Rating: ( 0)
Drives: IX MR
Prosport Mechanical Boost Gauge
I was wondering what I need to do to install the Prosport Mech boost gauge correctly with my existing MR gauge package. Does the Prosport hook up directly with my existing boost/vac line? What do I use or need to power the lights for the Prosport gauge? What else do I need to do? Thanks!
Online
Oct 26, 2009, 06:35 PM
Personal Sales Rating: ( 3)
Drives: 06 IX MR 400whp/400wtq on a shot trans :)
I have the electric peak/warn boost gauge from prosport, but yes you can use the oem boost line. Does your gauge have the capability of being wired for different color options, like white for day or amber for night, or is it just locked on one color?
Offline
Oct 26, 2009, 08:17 PM
Drives: IX MR
Yes, you can switch the colors on the gauge. Do I have to splice any wires of the oem gauge wires?
Online
Oct 26, 2009, 09:57 PM
Personal Sales Rating: ( 1)
Drives: 03 weightless white
I just got my prosport boost gauge installed. to power the gauge if you dont want to splice, buy an "add a circuit" and plug it into any fuse behind coin compartment (ignition on). I used the power mirrors. or splice into the cig lighter wire (brown). splice into parking light or headlight switch to make it blue. otherwise it'll be amber.
__________________
greddy comp ti turboback, ets licp, act clutch, greddy counterweight shift knob, prosport boost, oil temp, oil pressure gauges w/triple a piller, hks turbo timer, tein type s, ngk br8eix, k&n drop in filter, pioneer avh-5700dvd, bridgestone potenza re960as pole position
Offline
Oct 26, 2009, 09:59 PM
Drives: IX MR
^ Which is the easiest way that you'd recommened?
Online
Oct 27, 2009, 12:25 AM
i'd recommened use "add a circuit", no splice at all. just add longer wire if needed, then crimp and thats it. you can always remove it, its like plug n play.
__________________
Offline
Oct 27, 2009, 05:06 PM
Drives: IX MR
Thanks for the help! Can someone post pictures? I need pictures. I get quite paranoid if I dont see pictures. haha ;P
Online
Oct 27, 2009, 08:39 PM
plug it into an ignition on accessory fuse (power mirrors), it now becomes two fuses. crimp the red wire from the boost gauge onto the other end of this "add a circuit". I used a 3 amp fuse, dont forget to plug in the 7.5 amp fuse for the power mirrors (or whichever one you took out).
http://store.42draftdesigns.com/asse...-a-circuit.jpg
__________________
Offline
Oct 27, 2009, 10:05 PM
Drives: IX MR
Thanks! I will do so. I appreciate your help! ;D
Online
Tags
amber, blue, bluewhite, boost, change, colors, evolution, gauge, gauges, hks, hook, install, lancer, mechanical, prosport, sale, wire, wiring  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
