Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 23, 2009, 10:36 AM   #1
Personal Sales Rating: (1)
92gsxbaltimore's Avatar
How To: Pump Gas/E85 Refueling method
This is a step-by-step procedure that will ensure that you are refueling correctly.
1. When you notice that you gas light is on, proceed to the nearest gas station of your choosing. For the most part, they all carry the same gasoline, just branded differently. Also, some people suggest that waiting until your needle points to the "E" is a bad idea because your pick up screen on your pump will get clogged with any debris that is floating in the bottom of your tank. This is a ridiculous notion. Your pickup is always at the same level in relation to the bottom of your tank, so any debris that is sloshing around in their is going to have just as easy a time in finding the pickup as it did when your tank was full. It is however a bad idea to run a pump dry because your fuel actually cools the pump and keeps the pump shaft rpms low, and repeated dry running will eventually cause premature wear of your pump motor due to dry running.
2. Your filler door is on the drivers side(the side you sit in), so don't forget to pull up with the gas pump on the same side.
3. Shut off your car, and pull up(not down) on the gas filler door release. This involves turning the key counter-clock wise, and then locating the filler door release which is right in front of the seat you are sitting in.
4. Exit vehicle, and do not forget to engage the emergency brake.
5. Pay for your gas
6. Open gas filler door, and unscrew gas cap
7. Select gas grade, insert pump nozzle in filler neck opening, and depress gas pump handle to begin filling tank
8. Remove pump handle when gas shuts off automatically, and replace on pump
9. Screw down gas cap in filler neck and stop after it clicks 3 times
10. Close filler door
That wasn't so hard was it? If you have any questions, let me know. I'll try to update this thread later tonight once I get a chance to upload my photos, and once I figure out the torque spec of the gas cap.
Offline
Old Oct 23, 2009, 12:28 PM   #2
Personal Sales Rating: (5)
2003 Mitsubishi Lancer Evolution
evoseb08's Avatar
Drives: 03 Evo 8 GSR
This is a joke right...?
__________________
03 Evo 8 Gsr
Beginning of '09:
12.59 @ 110.05 mph
1.9 60ft. *thumbs down*
1.5 bar (about 22psi)
on 91 octane.
Tein springs.Rsr magic TBE.17' SSR GT2 wheels.HKS EVC III.Exedy stage 2 clutch
Fully stock internals and turbo
New parts:
Evo8 Turbo w/ 10.5 hotside &Custom BR o2dump.1000cc PTE.Walbro 255. Apex'i PowerFC D-jetro &Commander. HKS EVC5. ACT Street disc, Gruppe-S Flywheel. Greddy Type-S BOV. TurboXS FMIC. Tomei Poncam. Special Juice: E-85!!
Stay tuned for results!
Offline
Old Oct 23, 2009, 12:30 PM   #3
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
Insta-ban
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Oct 23, 2009, 12:41 PM   #4
dahuii77's Avatar
Drives: 03 evo 8
Send a message via MSN to dahuii77
and then KABONNNNNNNNNNNNNNNNN!!!!!!!!!!!!!!!!!!!!!
__________________
03 EVO 8/ HKS GT2835 GARRET TURBO/ HKS 272' CAMS/ 850 FIC INJECTORS/K&N DROP IN// FORGE BOV/SHEP STAGE 2 TRANSFER CASE/HKS DL2 IGNITION/ HKS INTAKE/GREDDY INTERCOOLER/GREDDY CAMS GEARS/WALBRO 255 INTANK/ARP HEADSTUDS/PROFECT SPEC 2 EBC@26 PSI//ACT 6 PUCK &FLYWHEEL/PERRIN CAT DELETE/ HKS DOWNPIPE/ /ADVANR RG2 WHEELS,255.40.17 FALKEN AZENIS/BUSHING KIT/APEX N1 DAMPER FULL COILOVERS/APEX PLUGS/JESTR TUNE@380hp 401tq 12.05 @115MPH.
Offline
Old Oct 23, 2009, 12:53 PM   #5
Personal Sales Rating: (20)
Remy's Avatar
Drives: 05 Acura TL & 04 EVO Vlll
Send a message via AIM to Remy
Quote:
Originally Posted by TTP Engineering View Post
Insta-ban
x2
__________________
Built by me
Tuned by me
Driven by me
Offline
Old Oct 23, 2009, 01:03 PM   #6
Personal Sales Rating: (23)
yahu's Avatar
Drives: 06 Evo MR
did the significant other fugg something up in the process? Just trying to figure out why someone would make the post.
Offline
Old Oct 23, 2009, 03:23 PM   #7
Personal Sales Rating: (9)
mrtalon20's Avatar
Drives: 03 EVO
Insta-ban
+2
__________________
2003 gsr
Times 1/8mi
6.9@103
1.71 60ft
On street tires
PT6262 T4
always a work-in-progress...nothing else left BUT to improve
4 wheel drive.3 diamonds.2 liters.1 turbo.....you just can't go wrong with it
Offline
Old Oct 23, 2009, 03:41 PM   #8
evoseb08's Avatar
maybe if he deleted all the steps besides 1, you can change the title to "how to keep your fuel pump healthy". some ppl dont know that stuff, but other than that... wow..
__________________
03 Evo 8 Gsr
Beginning of '09:
12.59 @ 110.05 mph
on 91 octane.
New parts:
Offline
Old Oct 23, 2009, 03:47 PM   #9
Personal Sales Rating: (52)
evodan2004's Avatar
Drives: 03 Evolution 8
Send a message via AIM to evodan2004
5. Pay for your gas
1. how can something be floating at the same time its on the bottom of the tank??
3. i dont have to turn any damn key to pull up on my '' gas filler door release'' i just pull that s%&t up.
4,5,6 i live in NJ where we do not pump are own gas. so how about next time you make a damn review on what to do here in this situation.
__________________
JESTR TUNING - FULL-RACE - SPARK TECH - NISEI ENGINEERING - DRIVEN INNOVATIONS - DOG BOX RACING
NEW JERSEY EVO OWNERS *THREAD*
My F/S thread STOCK & AFTERMARKET *CLICK HERE*
WTBWTBWTBWTB : Evo RS door handles
Offline
Old Oct 23, 2009, 04:26 PM   #10
Personal Sales Rating: (3)
596736's Avatar
Drives: GG Evo IX, 2001 jeep XJ
Thanks for the write up. I'll hopefully be able to try this soon.
Question: Do you ever try the "lift the gas line from the pump method" to extract more drops of e85/pump into your tank?
__________________
Stockish?
Offline
Old Oct 23, 2009, 06:03 PM   #11
Personal Sales Rating: (4)
5LEEPERISAH23I's Avatar
Drives: EVO VIII
Send a message via AIM to 5LEEPERISAH23I
kids go to college this is why!
__________________
Jun-BL Cat-Back, Stock 9 Turbo, Injen UICP/LICP, Injen Intake, Megan Racing Downpipe, Megan Racing Exhaust Mani, Megan Racing 02 Housing, Megan Racing Coilovers, Kelford 272's, APG Head Studs, Walbro 255 Fuel Pump, Forge Rec BOV.
STOCK Injectors, STOCK Intercooler, STOCK Cluch.
351WHP/343TQ @23 PSI
1/4: 12.61@110.87 60ft: 1.81
Offline
Old Oct 23, 2009, 07:24 PM   #12
I don't understand why you guys are getting all bent out of shape about the review. It took me a couple tries before I could do it myself the right way. I have a couple write-up scheduled, and I wish you guys would ease up on me for those. Next up is my 3-part How to on A. Checking your tire pressure, B. Adding air to a tire, C Removing air from a tire.
Offline
Old Oct 25, 2009, 12:09 AM   #13
yahu's Avatar
Drives: 06 Evo MR
^I hope you include the rapid-release version for part C. Using a sharpened blade ensures that the pesky pressure not only becomes low but also remains low!
Offline
Old Oct 25, 2009, 01:56 AM   #14
Personal Sales Rating: (0)
epooh1's Avatar
Drives: 03 Evo VIII-Wicked White
Somebody should make a tee-shirt about this one.
Offline
Tags
car, e85, evo, gas, pictures, pump, refueling, steps, stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
