dremel should do fine, as long as its a new bit and done at a high speed, it will look good.
80 to 125 grit sandpaper to the cut edge after, and you're good to go.
I do still suggest covering the area in masking tape so you can use a marker to outline where you want to put it.
Post pictures after!
Also, hello from DFW/Arlington
__________________
almost full MR exhaust, almost full intake, AMS FMIC, Greddy boost control & gauge, HKS 272's, Full machined head, dual springs and +1mm oversized valves. FP red, new rotors, MR O2, and a Quartermaster Clutch that is unforgiving and angry.
Tuned by KEVIND
