Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 2, 2009, 06:36 PM   #1
Personal Sales Rating: (12)
Drives: EVO IX SE
Question A/C removal - any tips???
** I've done the search and have not found a thread providing comprehensive instructions. **
I plan on removing the A/C system from my Evo IX SE. I've removed an A/C before, and ended up doing some butcher work and would prefer to keep the A/C system from my Evo in-tact and still usable (either to myself or somebody else if I sell the components).
With that said, could somebody please provide me with some tips? I will be taking my Evo to a dealership to have the freon legally removed, so that isn't a concern/issue.
Thanks in advance for your help!
Offline
Old Aug 6, 2009, 11:12 AM   #2
Drives: EVO IX SE
...crickets...
Offline
Old Aug 6, 2009, 11:54 AM   #3
Personal Sales Rating: (29)
Creamo3's Avatar
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
It's pretty easy and these are the rough steps I took to do it.
1. Release Freon
2. Drain / Pull Radiator
3. Release tension on accessory belt and pull old belt (1/2" drive & allen key)
4. Unbolt a/c lines on firewall 1 x 10mm bolt and lines on passenger side
5. Unbolt 2 x 12mm lines on a/c condenser
6. Pull out a/c radiator behind coolant radiator
7. Remove 4 x 12mm bolts holding a/c condenser
8. Remove bracket holding a/c condenser to the block (3 x 14mm bolts)
9. Replace old accessory belt w/ shorter belt
10. Replace Radiator and fill back up
I think that's everything in a nutshell
__________________
Shearer HTA3582 / Magnus V5 / GSC S2 Cams / PPI 65mm TB / Dejon 4" Intake / AMSoil 4090 Filter
FIC 1450cc Injectors / Perrin Fuel Rail / BR Dual Pumps / TiAL Q BOV / APS Catback
ETS UICP / Nisei FMIC / HKS DLI2 / Hallman MBC / E85
Speed Density via EcuFlash
Next: Wiseco 1400HD Pistons / Howards Rods / MAP Stage 4 Head / A1 L19 Studs / ACT 6-Puck
Offline
Old Aug 6, 2009, 09:21 PM   #4
Drives: EVO IX SE
Quote:
1. Release Freon
Thanks for that info! When I did an a/c removal on my S2000 I didn't have to pull the radiator. Is it not possible to get to the coolant radiator without removing the radiator? If not, that may be the time to upgrade to the CBRD mini radiator.
Do you know off hand what the part number is for the shorter accessory belt?
Offline
Old Aug 7, 2009, 06:13 AM   #5
Creamo3's Avatar
You will replace your coolant radiator once you remove the a/c radiator if that's what you're asking. There is no way to remove the a/c radiator without moving the coolant radiator out of the way. Removing the radiator is easy to do; on the lower passenger side of the radiator there is a drain plug that you loosen w/ a 10mm socket and you can drain all the coolant into a bucket if you have the car jacked up. The a/c radiator sits right behind the coolant radiator and is held in by 2 bolts I believe.
The NAPA part # for the belt is 060569.
__________________
Offline
Old Aug 7, 2009, 06:26 AM   #6
Drives: EVO IX SE
Offline
Old Aug 7, 2009, 06:44 AM   #7
r.m.s.'s Avatar
Drives: 2005 WW RS
Its called a condenser. Not a "coolant radiator". And if I may... You do know how bad that is for the enviroment right?! Freon can only legally be pumped into a recovery unit by a certified tech! Thats a huge green house gas.
However... I don't believe you have freon in your car, its probably a type of R134a. Call the service desk at your dealership.
__________________
HAR Racing
Offline
Old Aug 7, 2009, 10:48 AM   #8
Drives: EVO IX SE
Who stated that they did (or were going to) vent the freon to the atmosphere? I will be taking the car to the dealership to have them discharge the system.
Offline
Old Aug 7, 2009, 10:53 AM   #9
Creamo3's Avatar
Actually I was referring to the radiator that circulates coolant, nice try though and who said he should vent to the atmoshpere? Now go rinse the sand from your vag unless you have some useful input
__________________
Offline
Old Aug 10, 2009, 09:35 AM   #10
Drives: EVO IX SE
For those of you who removed their a/c, what did you do with the associated electrical connectors?
Offline
Old Aug 13, 2009, 09:10 PM   #11
Personal Sales Rating: (1)
evofabulous's Avatar
Drives: 2nd 05 evo
Send a message via AIM to evofabulous
1. Release Freon
11. send me your ac condenser because i really need it
__________________
tbe, intake, greddy profect b spec 2, and some more look good stuff
Offline
Old Aug 28, 2009, 12:20 PM   #12
Personal Sales Rating: (3)
Drives: your sister to work in the morning after a long night at my house
i am also going to be taking my a/c out and dont know what to do with the connectors. I was just gunna tape them off and tuck them somewhere most likly
Offline
Old Aug 28, 2009, 12:50 PM   #13
Drives: EVO IX SE
Quote:
That's probably what I will do. Don't want to do anything permanent like cut them off. The a/c system could be re-installed at a future date if desired, but if I cut the connectors off it would become a PITA to add them back in.
Offline
Old Aug 30, 2009, 11:23 AM   #14
Personal Sales Rating: (6)
has anyone gone to the dealer to release the freon? or can we go somewhere else?
Offline
Old Aug 30, 2009, 11:42 AM   #15
Drives: EVO IX SE
Quote:
I took my S2000 to the dealership to have the freon released prior to removing the a/c, and I will be taking my Evo to the dealership as well. I think they charge around $75.
Offline
Tags
060569, ac, air, components, condenser, conditioning, evo, evolutionm, napa, number, part, removal, remove, removed, s2000
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
