Aug 1, 2009, 02:04 PM
Personal Sales Rating: ( 4)
Overheating Issue
i have a fp-red + bolt ons, I recently replaced my thermostat because it was leaking around the seam. she started overheating this morning 240 degrees I wasn't pushing her just driving 60-80mph in 6th, when I checked the coolant I noticed a silver/gold color liquid floating on top of the coolant, it was also underneath the radiator cap and over the new thermostat(this drive was actually her first drive with the new thermostat)
i put everything back including the gasket except thermostat.
Drove her home gently and still overheating (now without thermostat)
can someone tell me what happened and what I should do.
Thanks
Offline
Aug 2, 2009, 01:34 AM
Personal Sales Rating: ( 11)
Drives: 04 evo 8
probably have air bubbles in the system. flush and redo it.
__________________
NEW SETUP FP Black Ported - BR 2.3 - BR stage3 head - BR double pumper - kelford 272 - map rev3 im - Exedy twin hd
OLD IVEYTUNE - 461/451 - 33psi - E85
NEW IVEYTUNE - ???????
Offline
Aug 2, 2009, 05:31 AM
What about the silver/gold stuff floating on top that covered everything?
Offline
Aug 2, 2009, 05:46 AM
Personal Sales Rating: ( 3)
2002 Ford Focus
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Could be oil - if so, headgasket. Or was it more metallic - metal shaving like? Then I would do an oil analysis. A failing water pump would also cause overheating.
Offline
Aug 3, 2009, 04:51 AM
Quote:
the lets call it Gold color also sticky liquid not shavings.
could it be the material from the new thermostat that was installed?
bump for someone knowing what it is.
Offline
Aug 4, 2009, 06:37 PM
bump
someone here must know what this is
Offline
Aug 4, 2009, 08:23 PM
Personal Sales Rating: ( 1)
If you let it idle how long will it take to overheat?
Offline
Aug 5, 2009, 04:27 AM
after extensive research I came to the conclusion that the wax leaked out, this is whats covering everything.
I'd like to thank "How It's Made"
Offline
Aug 5, 2009, 04:28 AM
Quote:
I'll let you know this weekend
Offline
Aug 5, 2009, 08:52 AM
Drives: 04 evo 8
The fiav on the throttle body also uses a wax pellet to determine warmup stage on the evo's same as dsm's. I didnt know the thermostats used wax as well.
__________________
Offline
Aug 5, 2009, 04:18 PM
Quote:
yes they do, check out youtube.com and search for How its made thermostats
cool to see
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
