Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 13, 2009, 04:12 AM   #1
Personal Sales Rating: (0)
Drives: Mitsubishi Lancer Evolution VIII
How to swap auto transmission to manual transmission on my Evo-7 GT-A??
Guys I need help to convert my A/T to M/T on my evo-7 GT-A? Pls if u can mention the parts which ll need for the convertion and also mention the advantages & disadvantages.
Offline
Old Jun 14, 2009, 12:34 PM   #2
Drives: Evolution GTA
Unhappy GTA conversion
Did you get any responses or solutions to your swap question cuz I need to do the same swap?
Offline
Old Jul 21, 2009, 11:30 AM   #3
nads1978's Avatar
Drives: Evo VII GT-A (manual 5 speed)
Send a message via Skype™ to nads1978
Bump
Offline
Old Oct 25, 2009, 01:58 PM   #4
nads1978's Avatar
I have now done this conversion, still want any info?
__________________
WANTED ECU PLUGS.... VII GT-A. - - Auto, no more... It's now 5 on the floor
Since the creation of the Internet, the Earth's rotation has been fuelled, primarily, by the collective spinning of English teachers in their graves.
< GT-A info> <GTA ECU Pinout> <LPG & Evo?> <GTA XML/ROM>< Evo differences>
Offline
Old Nov 9, 2009, 02:05 AM   #5
monsta's Avatar
Drives: 2005 Mistubishi Airtrek Turbo
Quote:
It would be great if you did a run down of what you did and any issues that you ran into. You also mentioned to me in a PM about reflashing using the Tephra mods
__________________
I suck small children off the sidewalk when I accelerate :)
Offline
Old Nov 9, 2009, 09:25 AM   #6
nads1978's Avatar
I will be doing a full write up of the job on the MLR, but will also try to make it a reference point for all things GTA. ECU/wiring/drive-train differences etc etc. (will update this thread when I have done it)
Yep, got Tephra's 5.10 [96260009-v5.10fix2-mods] running on my GTA ECU (running manual box remember), The valet part worked okay - didn't try much else, as when I took the car out, I had to change back to my GTA ROM. I must not have changed all the settings over - got 'judder' when on boost (maps/timing - anything else?)
Did you have a look at the pinout? Does it correlate with any work you have done previously?
__________________
Offline
Old Nov 11, 2009, 02:05 PM   #7
hey nads1978 i m happy hear that someone done the conversion successfully. Can u tell me is it difficult or not. Yeh I m dying to do it. Pls help what are the thing i need for the conversion.
Offline
Old Nov 11, 2009, 02:16 PM   #8
nads1978's Avatar
Quote:
Hi Sean, I've seen you over on the MLR.
Here is a quick rundown...
Parts required:
  • 5/6 speed manual gearbox
  • Gearbox mounts
  • 5/6 speed Linkage, selector & knob.
  • Clutch pedal & mount
  • Release (slave) Cylinder
  • Master cylinder
  • Clutch pipe work
  • Flywheel + bolts (different length GTA/Manual)
  • Clutch
  • Release bearing
  • Front left drive shaft (different length GTA/Manual).
  • Centre console (front part only)
  • Reverse connector plug
The speedo will not work, as the GTA calculates the speed from input/output shaft speeds. I will be looking into this on my car over the next few weeks and update. This is the only issue left.
The main problem with the conversion is mounting the clutch pedal. The front of the pedal box mounts to the blank on the bulkhead, but the top of the pedal box will not mount to the chassis above, there is a gap. The manual car has an extra bracket built into the chassis. You have 2 options here, remove all the dash, and make a bracket, or, what I had done, brace the top of the pedal box with a large bracket over to the brake pedal mount.
Like I said above, I'll be doing a full write up about it on the MLR within a couple of weeks.
Regards
__________________
Offline
Old Nov 11, 2009, 02:31 PM   #9
tnx mate. This is enough info for me. Yeh i want to know more about this. Check ur inbox.
Offline
Old Nov 12, 2009, 01:03 PM   #10
another thing what about the wiring & ecu??
Offline
Old Nov 12, 2009, 01:08 PM   #11
nads1978's Avatar
As mentioned speedo is not working but I plan to rectify this next week.
Gearbox loom modifications:
There are 4 plugs, large black, small black, large grey, small grey.
The large black plug going into your gearbox is the only one we need. It has 2 rows of pins, 4 big & 6 small. The 4 big ones are the ones we are interested in.
The pins are attached to wires coloured: (1)[brown] + (2)[Black/Yellow] + (3)[Black/Brown] + (4)[Black/Yellow]
(1)+(2) are for the reverse light switch - extend to gearbox connector.
(3)+(4) are for Neutral/park sensor - the ECU won’t allow you to start the engine unless in N or P, short these 2 out (or hide a switch in the cabin for an extra immobiliser).
Your GTA dash will still indicate when you are in reverse, and will still beep in the cabin.
__________________
Offline
Old Nov 12, 2009, 01:13 PM   #12
nads1978's Avatar
__________________
Offline
Old Nov 17, 2009, 11:15 AM   #13
nads1978's Avatar
Clicky
__________________
Offline
Tags
2003, auto, automatic, conversion, evo, gta, lancer, manaul, manual, standard, swap, tips, tranny, transmission, trasmision
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
