Oct 23, 2007, 09:16 PM
Personal Sales Rating: ( 49)
Drives: '04 Evo VIII
RRE Cam Install Video
I found this on streetfire tonight. I had not yet seen a video on a cam install, and I figured it might help out a few people. There is a disclaimer that says it's not suppose to be used as a write up or tutorial, but I think it's pretty good anyhow.
http://videos.streetfire.net/video/e...d00128e555.htm
__________________
BR FS635
BR BFIC
BR 3" V-Band TBE
BR UICP
Tial Q
AEM EMS
Kelford 272's
PTE 1000 Injectors
Walbro 255
Forge UNOS MBC
PPI Ported Stock Intake Manifold
PPI 65mm Throttle Body
Offline
Oct 23, 2007, 09:40 PM
Personal Sales Rating: ( 17)
Drives: IX GSR
very cool video, nice find.
Offline
Oct 23, 2007, 09:54 PM
Personal Sales Rating: ( 36)
Drives: EVO METH MACHINE
definitely a good vid
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
409WHP/395WTQ
Stock 8 Turbo + MeTH
Online
Oct 23, 2007, 10:07 PM
Personal Sales Rating: ( 2)
Drives: 03 Lancer es ( BLK )
i wanted to hear her run before and after
__________________
Live ur Life to the fullest
Mods Done:
RRM: Fuel Rail, Pulley, Header, Test Pipe, Motor Mounts, Piggy Back, Front & Rear strut bar, Anti sway bar, Lower tie bar. Dc Sport cat Back, NGK plugs Magnecore wires. Speed Element vg. Stock manni Ported, 99 mirage cam, fidanza cam gear
Offline
Oct 24, 2007, 05:32 PM
The only thing I would have liked to see in the video was bleeding the lifters. I've seen some people post that you technically don't need to bleed them, and then other people (including vendors) say it's a must. I've never done it personally. I've read about how to do it, but it's always nice to actually SEE someone do it step by step, much like this video...it's one thing to read about a cam install, but much easier to watch someone do it.
__________________
BR FS635
BR BFIC
BR 3" V-Band TBE
BR UICP
Tial Q
AEM EMS
Kelford 272's
PTE 1000 Injectors
Walbro 255
Forge UNOS MBC
Offline
Oct 24, 2007, 05:43 PM
Personal Sales Rating: ( 10)
Drives: 05 TB Evo VIII, 90 TSi
The only thing that I see so far thats wrong is the fact that the cam cap bolts should not be torqued to 20-25 fl lbs... Its 14-15 ft lbs...
Offline
Nov 2, 2007, 07:34 AM
Personal Sales Rating: ( 1)
Drives: anything with wheels
any idea how much different the process would be for a mivec motor?
Offline
Nov 5, 2007, 08:36 PM
Quote:
This was taken from another post about installing cams on a mivec engine...
Quote:
Originally Posted by GregGSC
Pointers...
The little Cap on the mivec gear is made of aluminum and requires 32 N-M can be broken very easily it uses a 14mm Allen. Make sure you buy one that will work with your tq wrench.
you can either stuff a rag in under the mivec gear when you remove the aluminum cap it will spill some oil out of it. Keep that off the timing belt. you can zip tie the belt to the gear and use the timing belt tensioner tool just like on an 8. the 9 mivec doesn’t require any bleeding. and as far as the lifters go, not really necessary unless you have the car sitting for days or weeks.
One thing to watch out for if you remove the timing belt completely. Watch the Oil Pump gear and make sure that it doesn’t move. There is a balance shaft behind it and that can actually go 360 degrees out, and all the marks will line up, but it will be out. it will cause the motor to vibrate badly at about 4k rpms plus.
__________________
BR FS635
BR BFIC
BR 3" V-Band TBE
BR UICP
Tial Q
AEM EMS
Kelford 272's
PTE 1000 Injectors
Walbro 255
Forge UNOS MBC
Offline
Nov 5, 2007, 11:27 PM
Personal Sales Rating: ( 15)
Drives: Like a baby back *****
Same thing except you basically install both cams like the intake cam. Also the intake cam uses a 14mm allin key instead of a bolt on the cam gear.
__________________
09 UCF Formula SAE Race Car
06 EB EVO IX
372whp/356wtq 11.8@116 1.75 60' Stock turbo, cams and 93 octane
UNDER CONSTRUCTION
Offline
Nov 15, 2007, 01:25 PM
Personal Sales Rating: ( 6)
Drives: LNF
He makes that look SO easy. I am more tempted than ever to do this myself even though I've never done cams before.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
