Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 19, 2009, 07:20 PM   #166
Personal Sales Rating: (10)
2003 Mitsubishi Lancer Evolution
huevosrancheros's Avatar
Drives: 03 Banana EVO VIII
I'm pulling mine off to sandblast them. This does look like a nice method. I'm almost tempted to go ahead and pull this off.
__________________
PS3 ID: Kinikuchunks, Add ME for some Call of Duty Modernwarfare2.
KUNiiiZZZEEE Dial-IN
Offline
Old Apr 19, 2009, 07:23 PM   #167
Quote:
Originally Posted by Redlimit835 View Post
caliper off car>>>>2 bolts (i believe aprox 17mm) and one line (12-14mm) hemostat >> free caliper..... and the rotor is as easy as a good thud with a hammer.
thing is if you remove the line you have to bleed your brakes..... and as i found out the hard way alunimum calipers and steel bleeders oxidize together and in no way shape or form like to be loosened or removed... almost had to buy a new caliper when i did this.....had one break off in the caliper too....... was a nightmare with some good old PB blaster and a little heat... the part that worries me most is that my car only had 50k on it.......
neglecting that fact that I "should" bleed my brakes more often.
anyone else have this probem..
later
DJ
its a 19mm socket and they'll pop right off.
__________________
Offline
Old Apr 25, 2009, 08:42 PM   #168
Personal Sales Rating: (0)
2005 Mitsubishi Lancer Evolution
etuhs's Avatar
Drives: 2005 WW VIII, 2003 SRT-4, 2004 350Z DD
Nice job, this helped me alot.
Thanks
Offline
Old Apr 29, 2009, 03:29 AM   #169
Personal Sales Rating: (3)
guapoholic's Avatar
Drives: his evo like he just stole it
Send a message via AIM to guapoholic
Anyone here use anything higher than 400 grit when sanding? I want the surface to be very smooth before painting it.
__________________
Pow, right in the kisser.
Offline
Old May 28, 2009, 01:29 AM   #170
Personal Sales Rating: (5)
eagle claw's Avatar
Drives: 05 lancer gsr
I like the silver.
__________________
03 RR GSR
04 AS GSR 11.41 @ 123
06 MR (current)
Offline
Old May 28, 2009, 02:02 AM   #171
Personal Sales Rating: (4)
xRoguex's Avatar
Drives: 2005 Evo SSL
Send a message via AIM to xRoguex
http://cgi.ebay.com/ebaymotors/MUSTA...ht_1473wt_1375
will NOT chip, peal, discolor, messup, ****up, you name it... tested 10,000 miles on an s2000. flawless to this day
Offline
Old May 28, 2009, 05:18 PM   #172
Personal Sales Rating: (1)
Drives: S13
He speaks the truth. Good stuff. Time consuming to apply but turns out nice.
Offline
Old May 28, 2009, 07:14 PM   #173
xRoguex's Avatar
yeah - left out that part. prep for it sucks but damn guys -- they are perfect after.
Offline
Old Jun 14, 2009, 02:44 AM   #174
Dlove316's Avatar
Drives: Mitsu Lan Evo IX
Send a message via AIM to Dlove316 Send a message via MSN to Dlove316 Send a message via Yahoo to Dlove316
Thanks for the write up. Nice to know what to do when my calipers starts to fade
Offline
Old Jun 17, 2009, 11:41 PM   #175
Personal Sales Rating: (2)
R/TErnie's Avatar
Drives: TB Evo IX
Send a message via AIM to R/TErnie
you want to finish with at least 600. 400 will leave sand scratches
__________________
11.1@129mph - 521whp via Dynojet
Offline
Old Jun 18, 2009, 03:51 PM   #176
kaansahbaz's Avatar
Drives: evo 8 MR
nice 1 , i ll do them soon maybe in 2 weeks
Offline
Old Jun 28, 2009, 07:01 PM   #177
BEISSEN's Avatar
Drives: 05 MR
Send a message via AIM to BEISSEN Send a message via Yahoo to BEISSEN
I have just finished mine Almost. I messed up and took them off the car and Im fixing my mistake"Brake Fluid & Brake Cleaner" It was not 100% Dry and cured yet..But I did the Four step ProcessAfter cleaning and stripping.
Step 1.
Clean
Step 2
Strip "Tal-Strip"-Sand & Wipe With Alcohol
Step 4
Primer "Engine Enamel Grey"500F
Dupli-Color Red Caliper Paint "Rattle Can"500F
Apply Decals "XenonMods.com" 10.99 Shipped all 4 corners with extras.
Engine Enamel Clear 500F
I will soon post some pics.
__________________
Offline
Old Jul 17, 2009, 01:29 AM   #178
hinkle0856's Avatar
Drives: Evo IX MR, 97 Tacoma, 86 CRX SI
Just started mine this week, spent the last couple days dremeling all the clear off. Its a pain in the A$$ but sanding is way worse. Will post pics when done.
Offline
Old Aug 9, 2009, 07:33 PM   #179
Thoe99's Avatar
Drives: '03 Lancer Evolution 8
How much sanding do you do? Are you supposed to sand all the original red paint off? or just the original clearcoat?
__________________
CarDomain pics
Mods: GSC S1 cams, QTP 3" electric cutout downpipe, Hallman Pro MBC @22psi, Walbro 255 fuel pump, Vibrant cone air filter, Nisei LICP, custom self-tune, RobiSpec KW Club Sports, 18x9½+40 Enkei NTO3-M, 285/30/18 Yokohama Neova AD08
Offline
Old Aug 9, 2009, 10:17 PM   #180
BEISSEN's Avatar
Drives: 05 MR
Quote:
I Used Tal-Strip from Avanced auto to get it done and just sanded what was left and then used fine sand paper to get a nice surface and then did my steps.I also used alcohol afterwards to clean reidue off.
__________________
Offline
Tags
brembo, brembos, caliper, calipers, decals, evo, evolution, fn01rc, mitsubishi, painting, stickers, vr4, write, xenonmods
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
