May 8, 2007, 06:07 AM
Personal Sales Rating: ( 16)
Drives: WW IX, 1953 Jaguar XK120, Range Rover HSE, BMW 335xi, Mini Cooper S, Wrangler Rubicon Unlimited
How to boost your octane using various formulas
Here are some common ways to boost your octane using off the shelf products. I pulled this off another car site.
Formula #1 - Toluene
R+M/2.........114
Cost...........$2.50/gal
Mixtures with 92 Octane Premium
10%...........94.2 Octane
20%...........96.4 Octane
30%...........98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, i.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
10%...........94.5 Octane
20%...........97.0 Octane
30%...........99.5 Octane
Notes: Similar to Toluene. 12-16 ounces will only raise octane 2-3 *points*, ie. from 92 to 92.3. Usually mixed with Toluene and advertised as *race formula*.
Formula #3 - Methyl-tertiary-butyl-ether (MTBE)
R+M/2.........118
Cost...........$3.50/gal
10%...........94.6 Octane
20%...........97.2 Octane
30%...........99.8 Octane
Notes: Oxygenate. Very common in octane booster products. Has lower BTU ontent than toluene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
Formula #4 - Methanol or Ethanol
R+M/2.........101
Cost...........$0.60 - $1.75/gal
10%...........94.3 Octane (Methanol)
10%...........94.7 Octane (Ethanol)
20%...........Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combine with water.
Formula #5 - Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2.........101
Cost...........$0.60-$1.50/gal
30%...........Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
Sample Mixture
To make your own octane booster, it is easiest to make up a large batch, and then bottle it up in "dosage-size" uses. Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles (128 oz = 1 gal):
100 oz of toluene for octane boost
25 oz of mineral spirits (cleaning agent)
3 oz of transmission fluid (lubricating agent)
This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
~~NOTE:I AM NOT RESPONSIBLE FOR ANY HARM THAT MAY COME FROM WORKING WITH DANGEROUS CHEMICALS OR THE IMPROPER MIXTURE OF SAID CHEMICALS~~
__________________
Crimson
Felix Nihil Admirari
Quote:
Originally Posted by Bimmubishi
Whatever I'm done. I have to go clean my rainbow anodized deep dish volks and post about Voltex.
Offline
May 21, 2007, 03:32 PM
Personal Sales Rating: ( 0)
Drives: 03 evo
Ethanol will not eat gas tank linings, rubber or alumium on any car since the early 90's and vechile from the 70's to late 80's can handle 30%. It really comes down the the grade of the rubber used ... ethanol doesnt eat any type of alumium used in cars
There was a big deal about this on a different forum and I found a guy that found goverment test reports on this. Also I had done some testing on this. I run E85 in my 1995 jeep cherokee for months now and have not had any rubber wear. I have checked my lines about every 6k miles and i drive about 2k a month. Before I had done that I had let rubber line set in E85 for about 2 months and nothing happened to them. The biggest down side to e85/ethanol is that you wont get very good gas milage... about 20-30% less.
Offline
Jun 2, 2007, 01:58 PM
Personal Sales Rating: ( 2)
Drives: 06 IX
do these octane booster formulas really work? anyone use them and anything bad happen?
what kind of car site did you get it from? any results?
__________________
Just for the haters....
Evo IX
-Custom Exhaust only
everything is in the making....
I NEED THESE
WTB: Defi D-Gauge Temperature (Black Face, Amber Lighting)
** WTB: JDM IX tails, Ralliart CF Lip, JDM IX headlights **
Offline
Jun 2, 2007, 02:40 PM
Drives: mountain bike(evo)
yea i got to gas city once a month and 113 octane, gets the job done!!!
Offline
Jun 2, 2007, 04:22 PM
Drives: 06 IX
what?
__________________
Evo IX
I NEED THESE
Offline
Jun 2, 2007, 04:48 PM
Yes they work, that's why I posted them. If you're unsure just try a batch in a portable tank and take it to a local refinery or any place that can analyze gas and get them to tell you the octane rating.
__________________
Crimson
Offline
Jun 2, 2007, 05:01 PM
Drives: 06 IX
Quote:
R+M/2.........114
so for this one, i just need to go to a paint/chemical store and buy Toluene and throw it in the tank? 10-30 percent?
__________________
Evo IX
I NEED THESE
Offline
Jun 2, 2007, 05:09 PM
Personal Sales Rating: ( 25)
Drives: 08 Apex Silver X GSR 04 Apex Silver Evo VIII (traded)
All Sunoco's in PA now blend a 10% Ethanol Mix for all of their pump gasolines. They had to remove their 94 octane (The only 94 available around me) from PA's market because they told me that when gas is mixed with Ethanol, it is impossible to raise the octane level above 93. I called their customer service hotline and asked to talk to a representative. I was PO'd that there was no more 94. So what's the deal here? Is Ethanol an octane booster? If so, then why did Sunoco remove their 94? Maybe to cut costs? Also, in our owners manual it talks about using fuels with ethanol and MTBE, etc.
Offline
Jun 2, 2007, 05:20 PM
Drives: 03' Evo8
I'm going to have to try this out.
bump to spead the info
Offline
Jun 2, 2007, 08:13 PM
Yep
__________________
Crimson
Offline
Jun 2, 2007, 10:50 PM
Silver Sponsor
Personal Sales Rating: ( 80)
Drives: 03 BBY EVO by PPI and 00 Civic SI
Here is an off the shelf option for you guys:
http://torcoracefuels.com/index.php?...display&id=179
The biggest issue remains what octane the fuel your putting in, or the base fuel. Is it really 91/92/93? Does it already conatin ethanol or another type of chemical that will make the final product less effective? The base fuel is still the doubt here, not the additive.
Offline
Jun 2, 2007, 11:01 PM
Drives: 06 IX
so what would we need to do to find this out? also send it to be tested?
__________________
Evo IX
I NEED THESE
Offline
Jun 5, 2007, 09:14 PM
Silver Sponsor
Well there are places that test fuel/oil, etc. But the real problem is that you could test the base fuel one week and the next the same station could get it from a different distro. I think the only safe way is to take the worst premium fuel available in your large geographic area (probably 91) and use this when doing your calculations.
Offline
Jun 5, 2007, 10:42 PM
Personal Sales Rating: ( 3)
Drives: EViLUTION IX MR
Xylene,  I have been using this stuff for a long time. I pick up a 5 gal drum once a month at "Sherwin Williams" paint store. I have never noticed any negitive effects. I will run a mix 93oct and about 25% xylene or a little more if needed. Its alot cheaper then buying 110+ octane at the dragstrip for $7.50 a gal  I can get 5 gal drums for about 20 bucks.
Offline
Jun 5, 2007, 11:29 PM
Personal Sales Rating: ( 19)
Drives: 2001 Turbo IS300, 2006 WW IX GSR
Quote:
So do you use xylene straight up and drop it into your gas tank with 93 or do you mix other stuff with it?
__________________
2001 Turbo IS300 6 speed GT40R 389rwhp 361ft/lbs (undergoing surgery)
2006 WW IX GSR 306awhp 312ft/lbs
Dejon Intake * Blitz SBC-ID * Test Pipe * Stock Gauge Wideband
Self-Tuned
Offline
Tags
blend, bmw, bobhanaghan, boost, booster, difference, gumout, m3, octane, price, safely, toluene, toluol, ur, xylene  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
