Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 5, 2009, 11:30 AM   #46
Personal Sales Rating: (17)
Drives: '05 evo!
whats everyones reading.. i dont know what i should set my temp and pressure to.. ive seen the temp to 180 but i dont know when i should be concerned
Offline
Old May 7, 2009, 05:57 PM   #47
kaj
Personal Sales Rating: (6)
Drives: '06 MR/'95 Civic DX coupe
Send a message via AIM to kaj Send a message via MSN to kaj
nice write up! i too would suggest using a steel braided line and remotely attaching the oil pressure sending unit.
we did that, for years, on our hondas. the bulk of brass on the back of the block would vibrate, move, etc... not good. we found it better to run the line to the firewall and mount the sending unit there. just be sure to leave enough SB line to allow for the movement of the engine, etc.
you should have no problems after that.
Offline
Old Jun 4, 2009, 04:52 PM   #48
Personal Sales Rating: (0)
AngryEvo8's Avatar
Drives: 2003 Evo VIII
I just got my evo and the oil pressure gauge is all messed up. It lights up but I dont think there is a oil sender attached. If I buy the install kit from napa which has the nylon tubing will I be good?
Offline
Old Jun 24, 2009, 12:53 PM   #49
Personal Sales Rating: (5)
evolv's Avatar
Can someone confirm the threads on the plugs?
The 42 draft designs page says the plugs are 3/8" BSPT (thus a 3/8 BSPT to 1/8 NPT reducer), if so then you probably wont find this type of reducer at the hardware store.
Though as someone stated before you could probably toss some teflon on there and cross thread it
Searching around for specifics:
British Standard Pipe aka Whitworth Tapered Thread Connectors (BSPT), seems to just be BSP(T/P) tapered or parallel.
vs
National Pipe Thread (NPT) aka IP (Iron Pipe)
The BSPT connector is similar to, but not interchangeable with, the NPTF connector. The thread pitch is different in most cases, and the thread angle is 55° instead of the 60° angle found on NPTF threads.
http://www.gatespowerpro.com/resourc...tification.pdf
__________________
03' WW :: Tanabe GF210 :: 255 Walbro :: Intake :: Blitz SBC id :: Blitz CBE :: Perrin HFC :: Blitz SUS :: Helix O2 :: Cobb DP :: HKS 272/272 :: SBR LICP/UICP :: TurboXS FMIC :: Megan Tubular Mani :: ARP Head Studs :: Stock turbo@21psi
Offline
Old Jul 19, 2009, 12:12 AM   #50
Personal Sales Rating: (3)
k20toEVO's Avatar
Drives: EVO VIII
saved to the favorites :P Looking to do this soon.
Offline
Old Jul 20, 2009, 04:09 PM   #51
Personal Sales Rating: (4)
ElToro's Avatar
Drives: 05 Rally Red Evo 8
I would also recommend the Remote line for installation.
I have the 42draftdesigns plug installed with a defi sensor, but after a little less than a year or so of daily driving, the wires coming out of the sensor housing broke off largely due to the vibrations and most likely the weather.
__________________
2005 RR GSR SSL
3" Works DP, Helix High Flow Cat, 3" Tanabe Concept G Blue Cat-Back, Works Drop-in Filter, Walbro 255 FP, Forge Unos MBC, Forge RS Dv, Jestr Tuned
Offline
Old Aug 27, 2009, 06:15 PM   #52
FTS EVO's Avatar
Drives: 2003 evo, 2000 f-350,1990 miata
I just hooked mine up. It seems to be working but i have a question. What do you guys see for oil pressure? Mine seems fine at idle but when it gets up in rpm the pressure peaks up at 100psi. It seemed high to me but what do you guys see?
Thanks Derek
Offline
Old Aug 28, 2009, 10:54 AM   #53
Personal Sales Rating: (2)
Davo's Avatar
Drives: 2004 Evolution VIII RS-II
^^tell us oil weight and then we can compare
amsoil 10w-30, cold is 74psi, idle warm is 16psi with a stri gauge
i have seen 100psi+ peaks
Offline
Old Aug 28, 2009, 06:02 PM   #54
FTS EVO's Avatar
Mobil 1 10w-30 fully synthetic. But with what you said you get it looks about right then. Thanks for the info.
Offline
Old Sep 28, 2009, 08:18 PM   #55
Personal Sales Rating: (19)
80210's Avatar
Drives: 06 Apex Silver Evo IX
Send a message via AIM to 80210
I can't get the 8mm hex loose! Gotta get a breaker bar asap as I've started to strip the hex!
Any other ideas? Breaker bar should work?
__________________
XS-Engineering DP, HFC, Megan CB, Cone Filter, Walbro, Hallman MBC @ 21psi, 4WS tuned
Offline
Old Oct 1, 2009, 08:25 AM   #56
80210's Avatar
Got a breaker bar hopefully that'll help! Any other ideas? I guess I'll get the car running too before to get some heat to it?
__________________
Offline
Old Oct 25, 2009, 06:27 AM   #57
Personal Sales Rating: (1)
Dragracer187's Avatar
Drives: Evo IX, Impreza GC8 GT
Send a message via AIM to Dragracer187 Send a message via MSN to Dragracer187
how much oil will you lose when taking out the filter?
Offline
Old Nov 7, 2009, 04:59 AM   #58
anyone?
Offline
Tags
evo, gauge, guage, helix, install, level, lug, oil, plate, pressure, sbc, sender, sending, temp, twin, unit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
