Jun 21, 2008, 04:08 PM
#31
Personal Sales Rating: ( 5)
Drives: 2003 GSR,2005 GSR sold... 2005 GALANT GTS, IX GSR.
My defi oil pressure just died on me last month and it was installed at the location above the oil filter. So I e-mailed defi and they said that the location is what killed it. I should buy a new sensor and the some adaptor from tein usa to installed.
__________________
TAKE NO B.S. Go to WWW.Jestrtuning.com.................................................. ..................................................Private discounts at Zales Jewelers....
Offline
Jun 21, 2008, 07:08 PM
#32
Personal Sales Rating: ( 0)
Drives: 2003 BBY Evo VIII
Quote:
Sounds like BS to me, why would location of the sensor break it? For exmple for oil filter you can even mounter "upside down" (i.e flow from bottom). Anything to do with hot oil can usually function at any angle.
Offline
Sep 23, 2008, 12:27 PM
#33
Drives: 06 Lancer OZ Rally
Does anybody know the size of the apex or allen bit that fitts the screws in there?
Offline
Nov 3, 2008, 09:37 AM
#34
Personal Sales Rating: ( 11)
Drives: 2006 Evo IX GSR/SSL
Quote:
8mm allen
__________________
06 WW Evo IX SSL
FOR SALE: 25K
http://forums.evolutionm.net/sale-ca...te-evo-ix.html
AMS GT850R
523whp/402tq pump 93 @ 30psi
AMS GT850R, Cosworth M2's, AMS DP, AMS Test Pipe, Megan catback, AMS Intercooler, AMS LICP, AMS UICP, AMS mini battery, APS Twin BOV, PTE 1000cc, walbro single, Greddy EBC, Shep built tranny, Exedy HD Twin, zeintronix zt-2, prosport boost/oil/volt gauges, AMS MM inserts, Works clutchline, Works shifter bushings.
Tuned by Mellon
Offline
Nov 18, 2008, 09:46 PM
#35
Personal Sales Rating: ( 19)
Location: texas with horses and cowgirls allllriiiiggghhhttt
Drives: 99 MX5, evo IX rs "downhill racer" (for lack of engine)
this method is superior to using the "sandwich ring" im guessing?
__________________
stuff for sale Factory Rods and pistons good condition
EvolutionDynamics KevinD tuned
Offline
Nov 22, 2008, 07:53 AM
#36
Personal Sales Rating: ( 1)
Drives: 2005 WW EVO VIII
Just throwing this out there but yellow teflon tape is designed to handle oil and chemicals while the standard white stuff is for air fittings.
if you are going to use it get the yellow stuff.
Offline
Dec 8, 2008, 09:46 PM
#37
anybody know if the prosport guages need different fittings as described in thread or will screw right in?
__________________
Offline
Dec 9, 2008, 06:34 AM
#38
Personal Sales Rating: ( 3)
Drives: 06 evoIX SE
Quote:
i know i had to get some fittings for my STRi gauges...
heres a link to an install with some info:
http://www.evolution-8.com/howto/defi.php
__________________
mah EvoIx pix
Tuned by:
AWD Motorsports
4WD Tuning
Offline
Jan 11, 2009, 09:44 PM
#39
Personal Sales Rating: ( 8)
Drives: 05' TB GSR ,481 whp Mazda RX7, Mercedez Benz ML320
Does any oil pressure sender work for this or does it have to be a mitsubishi oem part?
__________________
EVO 8 rear seats forsale pm me!!!!!!!!!!!!!!!!
Offline
Mar 3, 2009, 02:09 PM
#40
Drives: 2006 GG MR :)
Quote:
The sender and gauge have to be the same -- the calibration is set for the gauge.
__________________
3" Modified Megan Racing TBE & UR Cat.
Buschur O2 & Buschur Exhaust Manifold
Nisei LICP
DC2 oil catch can
Walbro Fuel Pump
Injen intake and UICP (w/ Perrin Filter)
ETS 3.5" FMIC
Zeitronix ZT2, ZAVT1, and Boost solenoid Failsafe
SMC Kit (50% Meth / 50% h2o )
GM 3 port BCS (28psi tapering to 22psi)
Enkei 17 x 9.5 NT03M 275/40 Azenis
Offline
Mar 6, 2009, 10:11 PM
#41
Drives: 2003 evo 8
Id recommend using a stainless line if you dont have your balance shafts, mine broke off.
Offline
Mar 6, 2009, 10:22 PM
#42
Personal Sales Rating: ( 128)
Drives: MR
I installed my oil pressure sender here and love it!
Offline
Mar 24, 2009, 09:50 AM
#43
Drives: Fully Built 2.3L Evolution VIII
Nice right up. I will have to cancel the adapter I ordered now.
Offline
May 5, 2009, 03:37 AM
#44
Personal Sales Rating: ( 42)
Drives: evo 1 gsr/ evo ix mr 5spd
Quote:
Bingo^^^
Using those cheap brass fittings is flirting with disaster even on a car with no bse kit, This is a very bad way to mount the sender.
It is not worth losing a motor over, Please people order the ams remote mount kit or make your own.
Trust me this is very bad!!!
The sender is heavy and the brass is cheap and weak and then add in heat cycles,vibration and boom you would prolly not even notice it before it did any damage.
__________________
The good die young and the pricks live forever!
-Lewis black
Offline
May 5, 2009, 07:54 AM
#45
Personal Sales Rating: ( 2)
Drives: 2004 Evolution VIII RS-II
the 42 draft design fitting is a good unit
due to vibration(i think) my oil pressure sender crapped out so ams remote line would be used
Offline
Tags
evo, gauge, guage, helix, install, level, lug, oil, plate, pressure, sbc, sender, sending, temp, twin, unit  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
