Dec 13, 2007, 08:22 PM
Personal Sales Rating: ( 8)
Drives: AP1 + CT9A
Becareful with teflon tape, I used have similar setup, whole thing was leaking from teflon tape while temp goes high. Teflon tape is not recommanded for track from here.
Offline
Feb 13, 2008, 03:44 PM
Personal Sales Rating: ( 2)
What should be used instead of teflon tape?
Thanks
Offline
Feb 18, 2008, 07:16 PM
Thanks for the write up - I just installed my Oil pressure gauge and it was pretty easy. Didnt need a breaker bar either!
Offline
Mar 10, 2008, 07:05 AM
Personal Sales Rating: ( 11)
Drives: WW '05
Im installing the Oil pressure and temp gauges this week. Already took the 2 bolts out, was very hard to get them out I may add.
As for sealent, Im going to use Permatex High Temperature Thread Sealant. Using taflon tape is not recommended, as it creates a barrier between the engine and the sensor. Sensor has to be grounded to the engine, and if not, it may give you incorrect readings
heres the link, click click
Offline
Mar 10, 2008, 07:11 AM
Personal Sales Rating: ( 3)
Drives: 06 evoIX SE
yea i did this install last week... i did need a breaker bar... besides the fact that my garage is not as roomy as i would like it to be... lol. great write up btw, i had read thru it a couple of times before i even started working on the car.
im using teflon tape... and it hasnt given me any problems yet, but we'll see
thx for teh write up!
__________________
mah EvoIx pix
Tuned by:
AWD Motorsports
4WD Tuning
Offline
Mar 18, 2008, 07:31 PM
Personal Sales Rating: ( 16)
2003 Mitsubishi Lancer Evolution
Drives: 2003 Lancer Evolution VIII
does the oil and temp HAVE to be in the holes as shown in the pics or can it be the other way around too?
Offline
Mar 24, 2008, 09:12 PM
Drives: Evo IX
what did you guys use to get out those bolts on the filter housing??? im doing this install tomorrow and i hope i have the right tool to get them out!
__________________
Ported & Polished Manifold
Megan O2 Housing
Megan Downpipe
Megan Test Pipe
Greddy Ti Exhaust
ETS Intake
ETS UICP
ETS LICP
ETS 3'' FMIC
SSQV BOV
Walboro 255 Pump
Hallman MBC
ACT Clutch & Flywheel
HKS Turbo Timer
AEM Boost,Oil & Wideband
Tanabe GF 210's
Labonte ISG-10 Meth Kit
Arp Head Studs
4WS TUNED!
Offline
Mar 25, 2008, 08:46 AM
Personal Sales Rating: ( 13)
Drives: 04 Evo VIII
Quote:
It doesn't matter. both are oil holes so I assume you are talking about oil pressure and oil temp senders.
__________________
Some go fast parts, I can't remember right now.
Offline
Mar 27, 2008, 08:17 PM
Personal Sales Rating: ( 0)
Drives: 2006 Mitsubishi Lancer Ralliart
Quote:
my sensor runs an oil line to the cabin on mine, so is it okay still to use teflon? or is it absolutely necessary to use threadlocker still?
Offline
Mar 28, 2008, 05:55 PM
Drives: 04 Evo VIII
Quote:
They are pipe threads so you really don't even need either. But if you want that added security use teflon just be cautious and make sure it is only on the threads and no excess can get in the line. it won't hurt anything but your gauge
__________________
Offline
Apr 20, 2008, 12:50 AM
Drives: Evo
is this the screw that i have to unscrew for the oil pressure sensor? im installing my defi bf oil pressure on tues. need an answer asap.
Offline
Apr 20, 2008, 01:07 AM
Drives: Evo
what is this piece?
where can i purchase it?
do i need it to install the oil press?
Offline
Apr 24, 2008, 02:40 PM
Drives: 04 Evo VIII
Quote:
Yes
what is this piece?
Its just a brass pipe fitting you can get at your local hardware store and only you will know if you need it or not, all depends on how your sending unit hangs down and if its in the way. But thats something you can get at the local store no problem.
Did you get the metric adapters?
__________________
Offline
Jun 13, 2008, 10:16 PM
Personal Sales Rating: ( 22)
Drives: BBK powered EVO 8
going to use this HOW-TO Sunday and finally install my Defi BF oil temp/press gauges.
I have a 42draftdesigns install fitting and thread sealant, OEM filter and oil.
Will let everyone know how it goes.
Offline
Jun 21, 2008, 03:51 PM
Drives: 2003 BBY Evo VIII
Quote:
Originally Posted by 03evoevo
Stewart Warner boost, oil pressure and engine temp
The oil pressure is the only one acting up.
No need to send it back, SW (i have those as well) need very good ground, I had similar issue with my A/F gauge, after grounding it better had no problems after that
Offline
Tags
evo, gauge, guage, helix, install, level, lug, oil, plate, pressure, sbc, sender, sending, temp, twin, unit  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
