Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 10, 2008, 08:39 PM   #46
Personal Sales Rating: (0)
Drives: 04' evo gsr
Quote:
Originally Posted by dubbleugly01 View Post
bringing this thread back.....
I just installed springs/retainers using the "rope" method instead of compressed air. Basically, starting with the pistons in #1 and #4, a little less than 1/2 way down, I fed 1/4" dia. nylon rope in through the spark plug hole in cylinder 1 and 4, then rotated the crank to almost TDC, or as much as it would go with the rope in there. Pulled the cams, but left the cam gears and timing belt zip tied together like the evomoto cam install write-up says, and then made sure I kept tension on the timing belt so it couldn't slip on the balance shaft or crank. The tension came from a bungee cord hooked to the underside of the open hood.
Once cylinder 1&4 were done, put the cams back in without rockers, put the cam gears back on, loosened the tension on the timing belt tool and rotated the crank about 180 degrees, and started the process all over again for cylinders 2&3.
I think this method is a decent substitute for pulling the timing belt, or for those who don't have an air compressor.
did you release the timing belt tension? or just left the tensioner alone?
Offline
Old Sep 27, 2008, 02:12 PM   #47
Send a message via AIM to jimib Send a message via MSN to jimib Send a message via Yahoo to jimib
Has anyone just tried having the car on the ground and in gear with the ebrake on, so you do not have to take the tbelt off? I cant really see the car moving from 1 cylinder with 100 psi in it. Guess I will find out...
And about putting springs on with out taking the head off.. Its not just about money or time, it is about money, time, and not wanting to pull apart a motor with a nice sealed up head gasket. To some people here getting that far in to a motor is a seeming daunting task. I work in the engine business and id much rather do it this way.. Of course im used to changing valve springs on cars at the track all the time... Just usually never have to worry about damn mitsu auto tensioners!!!!!
__________________
MASTER CERTIFIED ENGINE BUILDER
_____________
http://www.myspace.com/hiaspirations
Facebook : Jimmy Bowling Cincinnati
JIMI B \\// BUSCHUR RACING \\// FORCED PERFORMANCE
______________
IX RS/\ FP RED/\ FP5R FULL BUILD THREAD:
http://forums.evolutionm.net/evo-eng...tor-build.html
Offline
Old Sep 27, 2008, 06:14 PM   #48
Quote:
I found out.... It moved . I had a on/off, and a regulator to sneak up on the psi, and it moved just after 60psi. Lesson learned, and time to reset the tbelt.
__________________
_____________
______________
Offline
Old Sep 27, 2008, 06:27 PM   #49
Personal Sales Rating: (1)
vtec2mivec's Avatar
Drives: Lancer EVO IX
Well, now I know not to try
__________________
My EB EVO IX 4 sale http://forums.evolutionm.net/showthr...70#post6253670
Offline
Old Nov 4, 2008, 01:38 AM   #50
Personal Sales Rating: (10)
bboypuertoroc's Avatar
Drives: 2006 Tarmac Black Mitsubishi Evolution IX
Subscribed... will be undergoing valve spring/retainer install soon.
__________________
ENGINE
FPRed - Kelford - ETS - TurboXS - Buschur Racing - Walbro - GSC - EPM - ACT - Hallman - PTE - ARP - PPI - TiAL - Gruppe-S
FOOTWORK
Tanabe - Progress - Stoptech - Hawk - Motul - Whiteline - Falken
EXTERIOR
JDM IX Rear - Rexpeed - JDM VIII MR Tails - JDM Signals - Blacked-out Headlights - Debadged - S2K Antenna - 6K HIDs
INTERIOR
Defi - Kenwood - Innovate - B+M - Speed Source
Tuned by Mellon
Offline
Old Dec 16, 2008, 10:49 PM   #51
Personal Sales Rating: (2)
magyar86's Avatar
Drives: 2005 EVO 8, 2008 F150, 1967 Camaro, 2006 GSX-R 1000, 2005 GSX-R 600(wrecked and for sale)
wanted to add to this thread a neat little tool i found, does it look like it will work? if it does it looks like it would save a huge amount of time...
http://toyotool.com/?gclid=CO_mgeD5xpcCFQ0xawod01d-TA
__________________
new setup:
motor: 8.3:1 weisco pistons, manley turbo tuff rods, arp L19 head studs, cometic head gasket
head: +1mm manley valves, supertech dual VS, full drag P&P, O-ringed, kelford 272 cams
turbo: turbonetics hurricane series, prototype 76mm t3
Offline
Old Dec 19, 2008, 09:51 AM   #52
Silver Sponsor
Personal Sales Rating: (5)
Mojo Motorsport's Avatar
Drives: 2003 Evo
Put it in 5th gear, parking brake, and chock the wheels, no guarantee but so far so good. Matco also makes a tool for getting the springs in and out, I love it very much, Part number VT102.
https://www.matcotools.com/Catalog/t...page=4
Edit: Use 3/8 socket extensions to hold the cam gears in place after you remove the cams, this way the pistons can rotate without screwing up timing.
__________________
Evo Performance Upgrades, Tuning and Maintenance.
www.mojomotorsport.com - 516-428-0645 - Ahochhauser@gmail.com
Customer Reviews: http://forums.evolutionm.net/vendor-...ng-island.html
Offline
Old Dec 19, 2008, 10:36 AM   #53
TIBOevo's Avatar
Drives: 03 EVO V111
Send a message via MSN to TIBOevo
i would definately replace the valvestem seals since your in there also. especially in my case with 124k miles on the engine.
__________________
http://s253.photobucket.com/albums/h...t=72c0b584.pbw recent pics
to FAIL, or not to FAIL?. that is the question.
Offline
Old May 9, 2009, 06:12 AM   #54
Epix_'s Avatar
**HELPFUL TIP**
When you go to install the keepers, take a small brush and paste a small amount of wheel bearing grease on the grooved part of the valve where the keepers sit. Then after the spring is compressed just push the keepers on the valve and presto, they stick! This way you don't need to hold them with needle nose pliers or any other crazy way you may have concocted in your head.
Since wheel bearing grease is petroleum based it will mix with the oil just fine so don't worry about it causing any problems. I have assembled many cylinder heads using this technique and have never had any problems.
This is not necessary if you are using a tool such as this
__________________
Quote:
Originally Posted by davidbuschur View Post
I think some of FP's turbos should be named, "Blue vein throbber".
Offline
Old May 9, 2009, 10:55 PM   #55
Drives: Evo IX MR
Great writeup, nice pics...until step 13 that is. I'd say "tricky" is an understatement. Assuming you've just installed new cams you're probably also installing stiffer springs. Those springs are a b*tch to compress. Ideally this is a 2-man job. Good luck.
__________________
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. - Albert Einstein
Offline
Old Jul 14, 2009, 03:13 PM   #56
Personal Sales Rating: (3)
Drives: Evo VII
If pressurizing the cylinder to keep vlaves from dropping and not wanting the crank to move, can you just put a socket and ratchet on the crank pulley bolt and jam it somehow so the pressure does not make it rotate?
Offline
Old Jul 14, 2009, 03:33 PM   #57
Jp7
Jp7's Avatar
Drives: CT9A (MR/9) - Hopefully AE86 Soon
I just did this and lost timing when at TDC going from finishing cylinder 2 & 3 then tried to pressurize 4, crank spun, with only 20 PSI in the cylinder with the car in 1st and the e-brake on.
Best way to do this WITHOUT losing timing is to CAREFULLY walk the camgears around to BDC by hand so that 1 and 4 will not push down after you did 2 and 3. This is a pain but much easier then re-doing timing. - don't forget to keep serious tension in the belt.
Offline
Old Oct 12, 2009, 11:19 AM   #58
My Garage
DavesGSX's Avatar
Drives: 2006 Evo MR/1999 Eclipse GSX/1992 Eclipse GSX
This is where you get the best tool for the job. I bought this and it only took me 40 minutes to do all 16 with the head off.
http://www.euroexportinc.com/product...ducts_id=44428
Offline
Old Nov 7, 2009, 11:05 AM   #59
dan628's Avatar
Drives: 05 EVO VIII
^^^ that tool you posted, will it work with the head on? Do I have to worry about the valves falling or will this tool catch them.
__________________
Hallman MBC - Defi boost gauge - AEM UEGO - Perrin TBE, SRI, FMIC, BOV, boost tube, oil catch can, antenna, end links - HPF LICP - Sun Hyper Force - Walbro 255 - Blitz radiator cap - Agency Power 27mm rear sway bar, front mount - Cusco V1&V2 tie bars, front/rear strut bars, trunk bar - Dynoflash custom tune
Offline
Old Nov 7, 2009, 03:48 PM   #60
2003 Mitsubishi Lancer Evolution
Wheatley's Avatar
Drives: 03 evo VIII
Send a message via AIM to Wheatley
I did it in under two hours with the head ON. I saved the hassle and cost of removing the head. Not to mention I cant have a head on and off in an hour and twenty mins. If I already had the head off I would much rather do it then, but sometimes removing the head just isn't the best option.
To the person that had the timing jump, if you would have read in the thread I as well as a few others said to leave it in gear with the e brake on. Lesson learned but it sucks. I only knew because someone I know told me that his jumped when it wasnt in gear.
Edit: I think that tool would work with the head on, just remember to pressurize the cylinder.
__________________
03 EVO
FatFab/35r/Shep/Magnus/QM/AMS/SparkTech/Cornfed on a FatFlash.
Best E.T. 11.300
Best trap 136.52
Offline
Tags
car, changing, compressor, evo, gsr, install, replacing, retainer, retainers, rope, s2000, spring, springs, valve, vavle
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
