Mar 15, 2007, 07:49 PM
#31
Personal Sales Rating: ( 1)
Drives: 02 LancerOZ, 89 Turbo 5-speed minivan
^ you beat me 2 it!!!!!!!!! such an awesome and simple tool.
__________________
2002 Lancer
Offline
Mar 16, 2007, 09:50 PM
#32
Personal Sales Rating: ( 25)
Drives: 05 GG Evo VIII MR
but then you have to have steel keepers right? don't some spring/retainer sets use titanium? is titanium magnetic?
Offline
Apr 7, 2007, 11:25 PM
#33
Personal Sales Rating: ( 22)
Drives: evo VIII
bringing this thread back.....
I just installed springs/retainers using the "rope" method instead of compressed air. Basically, starting with the pistons in #1 and #4, a little less than 1/2 way down, I fed 1/4" dia. nylon rope in through the spark plug hole in cylinder 1 and 4, then rotated the crank to almost TDC, or as much as it would go with the rope in there. Pulled the cams, but left the cam gears and timing belt zip tied together like the evomoto cam install write-up says, and then made sure I kept tension on the timing belt so it couldn't slip on the balance shaft or crank. The tension came from a bungee cord hooked to the underside of the open hood.
Once cylinder 1&4 were done, put the cams back in without rockers, put the cam gears back on, loosened the tension on the timing belt tool and rotated the crank about 180 degrees, and started the process all over again for cylinders 2&3.
I think this method is a decent substitute for pulling the timing belt, or for those who don't have an air compressor.
Offline
Apr 8, 2007, 01:45 AM
#34
Personal Sales Rating: ( 13)
I emailed this install link to a friend of mine who is a head honda mechanic ....
He responded with ..." Its amazing to see what people will do to save a little money"
Offline
Apr 8, 2007, 08:24 AM
#35
Drives: evo VIII
some people like to work on their own cars, not to save money, but to learn. Doing things a bit different than others is learning imo, and shows ingenuity. It's amazing what new things and techniques can be learned by not following the masses.
Does your head honda mechanic friend always go by the service repair manuals? Or does he do things his way, to save time, effort, etc.?
Offline
Apr 17, 2007, 12:10 AM
#36
Personal Sales Rating: ( 0)
Drives: Blue Evo 8
sorry for the slant, but this is the right audience to ask -- there used to be a nice vividracing.com write-up on camshaft replacement, but it is now gone. Anyone have a link to a similar write-up?? Does the  shop manual detail a cam swap procedure?
thanks in advance
Offline
Apr 17, 2007, 08:42 AM
#37
Personal Sales Rating: ( 7)
Drives: C DOUBLE NICKEL BENZ /04 acura tl aspec/ 91 talon drag car/evo 8(SOLD)
nice
__________________
600hp evo forsale
evomiz@aol.com
[url]http://forums.evolutionm.net/showthread.php?t=332144[/url ](SOLD)
IN MARKET FOR A EVO 5
Offline
Apr 17, 2007, 09:44 AM
#38
Drives: Lightning Yellow Evo VIII
Quote:
thanks in advance
Go to www.evomoto.com
Look under the Evo tech section -> installations -> camshafts
__________________
Mike - Evo-NY Crew #083
TSE: The Tri-State Metropolitan Area Evo Club
See my mods HERE
Quote:
Originally Posted by Basalix
I am pretty non-partial. Punani is punani. As long as it doesn't look like someone drug an axe between her legs, I will generally bury my face in it.
Offline
May 2, 2007, 03:32 PM
#39
Personal Sales Rating: ( 16)
Drives: Evolution VIII, 87 Mustang GT T-Top
You would be suprised how much easier it woulda been to just pull the timing belt. All you gotta do is reset the auto tensioner and remove the lower timing cover...
Offline
Aug 23, 2007, 09:47 PM
#40
this is a cool idea but I could have the head sitting on my work bench by the time you get done making that tool. I think it is easier to just pull the head, but thats just me.
Offline
Aug 24, 2007, 12:12 AM
#41
Personal Sales Rating: ( 4)
Drives: Graphite IX MR
I have a cylinder leakdown tester that would work perfect for this. (and you can set the pressure, sort of.)
Thanks for the write-up. Where can I get a spring compressor like that? ( or something similar)
__________________
Free your mind, and your ass will follow.
Gregor ~All Wheel Whore~
Offline
Jan 31, 2008, 09:43 PM
#42
Personal Sales Rating: ( 6)
Drives: 2003 RR Evo 8
Questions if I pull the whole head do I still need Schley product?
__________________
HTA3582R .63 hotside
Kelfords 272's
Buschur Race core
All other bolt on's
4WS Tuned
Offline
Feb 3, 2008, 09:04 AM
#43
Personal Sales Rating: ( 17)
Drives: '03 BBY Evo 8
Quote:
Any standard valve spring compressor should work fine at that point.
__________________
Quote:
Originally Posted by Brian_H
I got mine off ebay, it's totally the same. I don't know anything about cars but I can tell you its totally the same, butt dyno felt huge results and my friends brothers uncles cousin runs one in a fast honda.
Offline
Aug 11, 2008, 04:16 PM
#44
Personal Sales Rating: ( 11)
Drives: 06'Evo IX MR SE
So i guess i have to drop my oil pan, i had rags shoved in every hole, the keeper poped off and disappered.
__________________
NOTICE: Insanity has replaced Reason, in regards to the design and constrution of this vehicle!
UTAHEVOS
Offline
Aug 11, 2008, 09:47 PM
#45
Drives: myself to the emergency room
http://www.theracingpiston.com/servl...lve-evo/Detail
Beats the snot out of anything else for doing this with the head on.
__________________
If electricity comes from electrons, does morality come from morons?
Offline
Tags
car, changing, compressor, evo, gsr, install, replacing, retainer, retainers, rope, s2000, spring, springs, valve, vavle  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
