Nov 28, 2006, 08:20 PM
Personal Sales Rating: ( 11)
Drives: 03 TB, 99 EK
Quote:
Originally Posted by Spec'd
Nice writeup ... Why not pull the head and install some ARP headstuds
at the same time ?
My take on upgrading head studs is to not touch them unless they need changing. I run stockish boost (WORKS P2) anyway, so I don't run high boost. My car sucks up enough gas running stockish boost at the track already. I'm gonna enjoy the power increase of my cams before deciding if I need to crank up the boost any more.
Offline
Nov 29, 2006, 06:19 PM
Personal Sales Rating: ( 0)
Drives: the ones with 4 wheels
at the same time ?
You can install head studs one at a time with the head on  But thats another story
Offline
Nov 29, 2006, 06:29 PM
Personal Sales Rating: ( 25)
Drives: 05 GG Evo VIII MR
on honda's before, i've used string instead of air to keep the valves in place. just put string into the cylinder through the spark plug hole till it covers the piston and crank the motor by hand till it presses the valves up, and leave enough string outside to pull it out when you're finished. then there's no need to pull the timing belt, but this method will work too, i just didn't always have access to a compressor.
Offline
Nov 29, 2006, 09:29 PM
Personal Sales Rating: ( 16)
Drives: WW 05 GSR
Quote:
You can, but not on my car.
Offline
Nov 29, 2006, 11:27 PM
Quote:
How can you rotate the engine to move the pistons if you leave the timing belt on? I've heard of using the rope method, but also knew someone who dropped his valve into the cylinder attempting that method as well. Then he had to pull his head.
Offline
Nov 30, 2006, 08:47 PM
Quote:
Originally Posted by marksae
How can you rotate the engine to move the pistons if you leave the timing belt on? .
true, my bad, you do have to slip the timing belt off to get the cams out. duh!
Offline
Dec 7, 2006, 09:49 PM
Drives: WW 05 GSR
After taking a good look under the hood ... It seems like you would be able
to save a lot of work and time by more or less using marksae's method of changing valve springs and retainers.
It appears that removing the head would be alot of extra work.
The main thing I find difficult is removing the head from a perfectly
good running engine with 7600 miles on it.
Offline
Dec 8, 2006, 12:12 PM
Silver Sponsor
Personal Sales Rating: ( 84)
Drives: 04Evo-white/05FSTi
Nice write up, at what amount of psi does the piston start to move to bdc? So the compressed air will def. move the piston?
__________________
Wayne ~ PRESIDENT@
Paradigm Performance Innovation
http://www.paradigmperformance.net
THE BEST DEALS ON 65mm T/B's & PORTING!
Kelford cams available!
FIC Injectors - SUPER DEALS!
Ported and Swain/silver coating!
JUN B.L exhaust!
Designing parts the right way!
PPI's Youtube http://www.youtube.com/user/ParadigmPerformance
11.10 / 124.89 / 1.60 60ft. FPGreen + E85 + PPI (Now rocking the Red & Kelfords)
Offline
Dec 8, 2006, 12:29 PM
Quote:
I guess it would depend on whether or not you have your timing belt on.  If the timing belt is preventing the crank from spinning, it would obviously take more force to turn the crank. For me, since I had the timing belt off, it didn't take much pressure to move the crank. Even 30 psi moved it.
IMO, the risk of the piston moving on you while you're trying to change the springs and retainers is not worth it. If there was a sudden increase in volume, there could be enough of a pressure drop to cause your valves to fall into the combustion chamber.
Offline
Jan 22, 2007, 07:52 AM
Personal Sales Rating: ( 33)
Drives: 04 RS and 08 GSR
Can someone briefly summarize what work you are saving by not pulling the head? There's the cost of a head gasket, but it seems like if you already have the timing belt off there wouldn't be that much more to pull apart? I guess the intake would come off with the head?
Offline
Jan 22, 2007, 10:42 AM
lines, hoses, draining fluids, once the head is off you should really have it checked by a machine shop as well to make sure it's true.
Offline
Feb 6, 2007, 11:34 AM
Drives: 250cc superkart
Here is one tip that is not mentioned in the writeup. When re-installing the keepers I found it MUCH easier to spread some axle grease on the keeper and on a small screwdriver to hold the keeper on while re-installing. It makes it much easer to position the keepers on the valve when they stick to it and makes it harder to drop them.
Offline
Feb 11, 2007, 07:05 PM
Personal Sales Rating: ( 10)
Drives: 05 TB Evo VIII, 90 TSi
ive done this install a few times already on a few evos. I dont think it is necessairy to pull the head to do this, and i do infact think it is a waste of time, however if you are doing headstuds pull the head. I have a homemade valve spring compressor and i am pretty tired of it. Miller sells the specific tool for 240 but I think that the push pull type spring compressor is going to be my next purchase  Nice write up. I thought about doing it a while back.
Anthony
Offline
Mar 15, 2007, 03:15 PM
Drives: TB Evo 8
just so you all know the universal valve spring compresor that he has list has been dicontinued,
__________________
For Kyle Nino, Rest in Peace my friend, i will never forget you and i will keep your dream alive.
As i roll though the valley of the shadow of death, I shall fear no evil, Cause i'm the baddest tanker in the valley, and i carry a 120mm canon!! Nuff said!
Offline
Mar 15, 2007, 07:35 PM
Gold Sponsor
Personal Sales Rating: ( 127)
This tool http://buy1.snapon.com/catalog/item....re&dir=catalog will save you tons of time. Much easier to use than a spring compressor. Nice write-up.
__________________
Ryan
Injected Performance / EVO8.com / Injected Blog
(888) 465-7373
Paypal ID: sales@injectedperformance.com - Paypal must be confimed address
Wholesale Distributor:
Advan, AEM, ARC, Brian Crower, Bride, Brembo, Cosworth, Cusco, Ferrea, Gram Lights, Innovate, Innovative Turbo, JIC, Koyo, Power Enterprise, Precision Turbo, Project Mu, RPS, Seibon, StopTech, Sun-Auto, Tein, Tial, Unorthodox, Volk, Walbro
Offline
Tags
car, changing, compressor, evo, gsr, install, replacing, retainer, retainers, rope, s2000, spring, springs, valve, vavle  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
