Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Dec 10, 2006, 02:54 AM   #1
Personal Sales Rating: (0)
Garage is empty, add now
NEW HKS EVC wiring troubleshoot help.
Hi Fellas,
Just recieved my new HKS EVC.
www.hksusa.com/new-evc
Ok, the wiring harness came unlable and im having abit of problem trying to work out which is which.
Here is the wiring stated on the wiring diagram booklet.
B - 12volt ignition
U - 12 volt battery
E - ECU Ground
P - Pressure / Airflow Signal
I - RPM Signal
S - Speed Sensor
T - Throttle Position Sensor
# - Injector Signal.
OK, i only have 6 wiring according to the harness, that came with the HKS EVC.
Red
Black
White/Silver
Blue/Silver
White
Blue
Can someone out there PLEASE shed some details as to what wire is what?
Thanks in advance.
Cheers
Offline
Old Dec 10, 2006, 08:47 PM   #2
Personal Sales Rating: (301)
Drives: WW IX RS, Honda Element SC, Swapped E30
Send a message via AIM to Mitchubishievo
Bump since I'm gonna have this EBC too...
Offline
Old Dec 15, 2006, 01:46 PM   #3
Personal Sales Rating: (54)
TURBODAWG's Avatar
Drives: 2011 Hyundai Sonata 2.0T
Send a message via AIM to TURBODAWG Send a message via Yahoo to TURBODAWG
Did you guys get them working? How do you like them?
Offline
Old Dec 18, 2006, 01:50 AM   #4
Yup, i got mine install by pro as the instructions were all writtern in japanese and tech the installer is jap.
awesome unit, very user friendly and so much easier to tuned than my previous apexi avcr.
very stable boost to redline now as the stock unit was dropping to 16psi at top end.
turbo is now spooling and kicking in earlier, very impress
Offline
Old Dec 18, 2006, 05:49 AM   #5
I'll be PMing you next spring if I have issues .
Offline
Old Dec 18, 2006, 09:40 AM   #6
Personal Sales Rating: (34)
rogue's Avatar
Drives: WW EVO X.... previously -EVO IX - Apex Silver
Send a message via AIM to rogue
Not infront of my car but I think.
Red - Switched 12V Power
Black - Ground
White - 12V Power
if anything call HKS. They will give you the info over the phone.
Daimon
__________________
Offline
Old Dec 23, 2006, 09:56 PM   #7
Personal Sales Rating: (18)
fromWRXtoEVO's Avatar
Drives: Benz CLS biturbo, Golf turbo
Black - Ground
White - 12V Power
Daimon
No Daimon,
The HKS EVC only gets power from the accesorie source, it comes with a red wire and an attached fuse in-line and a ground.
The only white wire on the harness goes to the engine RPM signal line or speed signal line as per intruction manual page 22 para 3.2 step 5)
I installed mine last nine and have the intruction manual in front of me. Maybe I overlooked something but I might be wrong.
Carlos
__________________
Loyal to my Evo community as always since 2004, owner of 4 Evos and counting. On my 24th turbo car.
Offline
Old Dec 23, 2006, 09:57 PM   #8
Mine boost controller came with english and Japanese instructions.
Carlos
__________________
Offline
Old Dec 23, 2006, 10:05 PM   #9
Hi Fellas,
B - 12volt ignition
U - 12 volt battery
E - ECU Ground
I - RPM Signal
S - Speed Sensor
Red
Black
White/Silver
Blue/Silver
White
Blue
Thanks in advance.
Cheers
It is very simple. I had mine installed yesterday by myself. The actual controller/display comes with 3 tiny connectors in the back, you only need to use the 2pin and 3 pin connectors.
One of the connectors in the back has the scrmable wires(you don't need to use them) The other connector has a "Y" harness . One end provides the power and ground and the other side directly connects with the harness coming straight from the EVC steping motor.
The "blue and white" wires that you are talking about are the Throtle input signal(Blue) and the Speed/rpm signal (white)
The harness coming from the EVC steping motor is white on the end that connects the display and is black on the end that connects the Steping motor.
I am writing a huge installation write up. I took more than 30 pictures, I have been just lazy to post them but please feel free to PM me if you have any questions.
This is the third EBC I have use on my cars and I consider the installation easy. Even a cave man can do it. . Seriously, PM if you get stuck but I should be opening a post tomorrow with pictures and details.
Carlos
__________________
Offline
Old Dec 23, 2006, 10:41 PM   #10
Personal Sales Rating: (39)
NocturnalEVO's Avatar
Drives: 2006 Lancer Evolution IX MR
Send a message via AIM to NocturnalEVO
im looking forward to your post about how to install the EVC 6.
I just did mines today, but not sure if I did it right lol..
btw, i dont have a tune or anything, stock ecu. What should I set the boost at?
__________________
Najeeb
2006 Lancer Evolution IX MR Wicked White - FOR SALE!
2006 R6 Anniversary Edition
Offline
Old Dec 23, 2006, 10:47 PM   #11
A couple of important initial suggestions though:
1) do not use any lubricant to slide the hoses into the step motor nipples or the two vacuum filters (filter are foam filled and step motor can malfuntion and missread boost vacuum signal, it is that sensitive...)
2) be very aware that the supplied 6mm hose internal diameter is indeed too big for the stock compressor and waste gate nipples. This might give you a catastrophic visual perception that the hose is secure. I suggest you use a more appropiate better suited hose that fits the nipples tight and not loose.
Specially you that don't have a tune, pay a lot of attention to the turbo and waste gate hoses, from own experiences (13 turbo cars, 3 EBC,10 plus MBC, 2 blown 4G63'S, a few blown turbos) you can dynamite your engine or pick up some turbo wheels from the tarmac if your boost hoses are loose. I am not kidding
Carlos
__________________
Offline
Old Dec 23, 2006, 11:41 PM   #12
i hear ya, we got a reducer and used a smaller hose to connect to the compress housing and wastegate nipples.
btw, should I set the boost at 19.5psi or so on my boost controller?
__________________
Najeeb
Offline
Old Dec 24, 2006, 09:19 AM   #13
19.5psi is perfectly fine. The EBC would probably maintain that number all across the rpms range.
This is a understatement from the instruction manual (page 2), quote:
Warning Function- "If the boost exceed the user selectable warning value, the EVC notifies the user with and audiable beep and a visable warning display. Simultaneously,it lowers the boost to the baseline boost value or by a user preset value. This function prevents damage to the engine and/or the turbine due to over-boost"
HAHAHA, it is only true as long as the hoses are properly connected otherwise it would do the exact opposite, your audio signal would be your turbo exploiting, your visual signal would be pieces of the turbo in the tarmac, and unlike the manual says, you will produce engine damage.
If power fails then yes, the internal steping motor would get stuck on the existing boost value but if a hose comes loose there is not a damn thing you can do to prevent catastrophic damage.
In other words, it should work fine but a faulty installation would or could destroy your engine.
Carlos
__________________
Offline
Old Dec 24, 2006, 09:57 AM   #14
lol you got me very scared haha... i'm thinking of switching to all metal hosing, and weld it all together lol..
__________________
Najeeb
Offline
Old Dec 24, 2006, 12:30 PM   #15
Okay so I fixed the problem I was having, no CEL
Car seems to be running great right now!
Another question I have, is there way to set the A/B levels in PSI instead of the 0%-199% way they have?
__________________
Najeeb
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
boost, civic, controller, diagram, evc, evo, hks, install, japanese, manual, throttle, tipssetting, tps, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
