May 15, 2007, 05:23 PM
#31
Personal Sales Rating: ( 14)
Drives: 04 SSL
Quote:
Originally Posted by fugiwara
I just order set of drive shaft bushing. Questions to Revin9k, where are these bushing located? underneath driver seat, next to test pipe?
Well, they hold up the drive shaft, so it is directly under neath you. There are 8 pieces total, 2 pieces make one bushing. There are 4 bushings to replace. You can't miss em once you're under there. And yes, one set is located close to the converter/TP.
__________________
OCD IS NOT A DISEASE, IT'S A LIFESTYLE.
Kuniiizzzeee Dial-IN!
We the people are united, the ones you never look in the eye. We the people, the uninvited,
the ones that see right through your lies.
Offline
May 15, 2007, 05:28 PM
#32
Personal Sales Rating: ( 9)
Drives: an evo addicted to METH!
Awsome brah! Good looking out.
Offline
May 15, 2007, 05:36 PM
#33
Drives: 04 SSL
Quote:
Whats up Ruben?
__________________
Offline
May 15, 2007, 06:21 PM
#34
Personal Sales Rating: ( 55)
Drives: corolla
thanks for the reply.
another question, I was told by kami speed that the rear diff spacer is directly related to the clunking noise than the drive shaft bushings, is that true?
Offline
May 15, 2007, 06:31 PM
#35
Drives: 04 SSL
That is correct. But while you're under there already, might as well do the the drive shaft ones too.
__________________
Offline
May 15, 2007, 07:12 PM
#36
Drives: corolla
I only ordered the drive shaft bushing at the moment, b/c I want to see if I can feel any difference first.
Will the clunk noise go away or diminish after the drive shaft bushing replaced?
Offline
May 16, 2007, 09:39 AM
#37
Drives: corolla
up
Offline
May 16, 2007, 06:00 PM
#38
Drives: 04 SSL
If you are looking to get rid of the "clunk", the rear diff bushings will rid you of that problem, even though I believe, ( please do not mis construe this statement) that better driving technique also helps.
I really never got that clunking noise too often to begin with. I am changing out what ever bushings I can on my Evo and applying as many braces as I can to the car to stiffen everything up.
__________________
Offline
May 17, 2007, 08:47 AM
#39
Quote:
Originally Posted by revvin9k
Whats up Ruben?
All is good....nice write up bro. I didnt even know these were available. I have to get them.
Thanks.
Offline
Jun 15, 2008, 01:56 AM
#40
Personal Sales Rating: ( 5)
Found this picture on SCE.....how come his looks different than yours??
James
__________________
Dim Sum Racing
Offline
Jun 19, 2008, 01:19 PM
#41
Silver Sponsor
Personal Sales Rating: ( 62)
Drives: 05 Evo VIII, 04 STI, 07 S2000, 07 Civic Si, 06 Vitz, 06 IS350
revvin9k, is it cool if we used your review/installation info on our website? Its perfect.
Offline
Jun 20, 2008, 09:12 PM
#42
Drives: 04 SSL
Quote:
Yes, feel free.
Offline
Jun 20, 2008, 09:35 PM
#43
Personal Sales Rating: ( 12)
WOW. Good to hear all of the positive comments.
I've had them for a few weeks now, and after reading this, gave me enough reasons to go install them.
__________________
2005 Evolution MR- WW
Offline
Jun 21, 2008, 12:07 AM
#44
Personal Sales Rating: ( 6)
2005 Mitsubishi Lancer Evolution
Drives: 2005 Evolution RS WW
I have these in as well as the poly rears courtesy of the energy suspension kit. The poly kit was one of the first things I bought to rid the car of the clunk when I bought it. The prop shaft bushings I did to keep my exhaust from rattling off the drive shaft mount. Turned out to have other benefits as mentioned. (I also did kart boy poly hangers)
It is unbelieveable how treacherously crappy the stock d/s bushings are.
Great small mod thats easy to overlook, but well worth the effort.
A side note to the installation procedure. As I also did mine on my back- is to make sure you have some sand paper handy. Something coarse like 220<
My bushings would simply NOT just "go" in. And this will complicate trying to balance the top ring / hold the drive shaft, and manage to get a 5th arm to tighten nuts.
Take the mounts apart one section at a time. Do not drop all 4. Roll the sand paper into a small roll, and twist it into the d/s mount hole. This will allow you to simply pop the BR bushing right in. A quick tap from a hammer works nice too. I inserted the bottom & top bushings and then just pushed the mount in place. It may get hung up on the studs, but its easier than trying to balance the top ring and draw the bottom one thru if its a tight fit situation. Sometimes the mounts require a little side to side twist to reinstall, but they WILL go in even with the bushings fully installed.
I did not drop the exhaust either, and used the same wiggle extension pictured.
__________________
Buschur 3" TBE no cat, Buschur deluxe FMIC & piping, HAFE GT3076R turbo kit, GM BCS, HKS 272's, Tial bov & 44WG, W255, FIC 850's, MaftPro, LMS meth kit, GTWorx springs, Bilstein HD's, ES bushings, AWD MS Alu D/S, Beatrush d/s bushings, Powerflex front & rear mount, ACT 2900 /street disc, Prolite flywheel, DBA 5000/4000 brakes, Goodridge, Motul. Emissions delete, all tuned with ecuflash!
-Dustin
Just PM me!
Offline
Jun 21, 2008, 01:27 AM
#45
Quote:
James
nobody knows??
James
__________________
Dim Sum Racing
Offline
Tags
bar, beatrush, bushing, bushings, carrier, change, changing, driveshaft, evo, hanger, moustache, prop, propellers, shaft, subaru, waverunners  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
