Sep 15, 2006, 05:53 AM
Personal Sales Rating: ( 33)
Drives: 04 EVO VIII - Tarmac
sounds good, I have some other things I need to do under the hood, so I plan on adding this to my to do list for today...
Offline
Sep 20, 2006, 06:27 AM
Have you had any problems with the dipstick popping out since this mod?
Offline
Sep 20, 2006, 09:06 AM
Personal Sales Rating: ( 5)
Drives: 2003 Evo 8, 1999 MX-5 Miata
Offline
Feb 17, 2007, 09:51 AM
Personal Sales Rating: ( 1)
More thoughts
A better idea would be to run the outlet of the catch can into the intake just in front of the turbo. Air should be cleaner, so no oil and the hydrocarbons are actually gonna be burned. Good idea if the flow is enough. It also takes out the leak from the PCV valve. They are notorious for leaking boost. Im guessing you saw boost quicker with the nipple capped off.
The key is to maintain enough flow under high boost to help reduce blowby from the rings, valve seals.
Does the crankcase have anywhere to vent from too? If so then it might be a great idea to key that into an integrated system that pulls into the turbo inlet, but still caps off the intake manifold port.
Milburn
__________________
Apex Silver 2005 MR => 25mm Progress adj rear sway, Espelir GT springs, Carbotech Bobcat pads, all four DBA 4000 slotted rotors, Motul 5.1 brake fluid, ss brakelines, Sparco harness bar w camera mount, Corbeau Cr-1 wide body seats, SFI 16.1 5pt harnesses, -2.0 f/-1.2 r camber , 0" toe out front/ rear, Buschur rear+Beatrush front undertray, full body undertray project , Whiteline rear bump steer kit, Autometer EGT, boost, oil pressure, 17 psi max boost, dual catch can system
Offline
Aug 21, 2009, 11:35 AM
Personal Sales Rating: ( 6)
Drives: 05 EVO VIII GSR
Anybody have new pics on where to mount this?
__________________
RRE STAGE 2E (E-85) 466 AWHP/393 AWTQ
www.roadraceengineering.com
Quote:
Originally Posted by Bliu
You really showed me...I am too sensitive, I have no sense of humor, and I don't know s***t about my car so that's why I post nonsense...There, are you happy?
Offline
Tags
235, breather, caterpillar, delete, evo, filter, gsr, hose, pcv, reroute, valve  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
