Mar 15, 2007, 08:17 AM
#31
Personal Sales Rating: ( 0)
Drives: EVO 8
Just wanted to say that I tried this on my 350z and it worked perfectly.
My EVO came with an expensive 02 simulator so I didn't have to worry but if my car didn't have it, I would of done this non fouler/cheater mod.
Tony
Offline
Mar 20, 2007, 08:25 PM
#32
Personal Sales Rating: ( 7)
Drives: IXSE
Have any of you guys ran track days with this installed? I would like to know if a CEL is possible while hard driving
Offline
Apr 14, 2007, 08:13 PM
#33
Personal Sales Rating: ( 17)
Drives: Apex Evo IX
where can I get the 90 degree bend? I'm keep getting rattle from bottom. I tried banging the body with hammer but still getting rattle at high speed.
__________________
PoorMan's Evo
Texas Tech Red Raider
Unit ed States Army Back from Iraq
Now Going to Korea for 2 years -_- Goodbye Evo See You In 2-3 Years
Greddy, HKS, AMS, CUSCO, Seibon,Megan
Enkei GTC-01 18X8.5
Join the Army! Crackheads, Retards, Dumb@sses in the Army. No education or common sense required!. I know truth hurts.
Offline
Apr 14, 2007, 09:08 PM
#34
Personal Sales Rating: ( 56)
Quote:
Originally Posted by Hkysk8r07
didn't see one in here which is why i posted it. plus it shows the people with no idea what a tool is how to actually do it. :
i guess you didnt search that hard = How to install the spark plug anti-foulers to remove the ses or cel light
Offline
Apr 16, 2007, 05:51 PM
#35
Personal Sales Rating: ( 1)
Drives: 03 RR evo
hey guys, i did all of the steps in the how to and my CEL is still on. I read my codes and it is still my 02 sensor. Whats the problem?
__________________
MODS:
RNR/HKS CF TI TBE, AEM intake, Hallman Boost Controller, 255 fuel pump, Dynoflash, forge BOV, autometer boost gauge
Offline
Apr 16, 2007, 05:57 PM
#36
Personal Sales Rating: ( 3)
Drives: como tu abuela
did u disconnect the battery first?
also, try the longer ones, there are some threads around here with the part number on those.
I used 1 long and one short.
Offline
Apr 16, 2007, 06:06 PM
#37
Drives: 03 RR evo
well i forgot to disconnect the battery first but after i put together the two short non foulers and connected it to the 02 sensor i reset it. The CEL doesnt come on right after i turn the car on, its when i turn the car off and then on again is when it comes back on
__________________
MODS:
Offline
Apr 16, 2007, 07:04 PM
#38
try the longer ones then, part#42002
or 1 of each
Offline
Apr 25, 2007, 01:22 PM
#39
Drives: 2003 Apex Silver EVO
The two spark plug anti-foulers will not work with Buschur's exhaust. It hits the bottom of the car and you cannot rotate the cat-back without hitting the bumper with the muffler. Will just one anti-fouler work with no cat?
Offline
Apr 26, 2007, 09:18 PM
#40
Drives: WW IX MR
Quote:
Originally Posted by fromWRXtoEVO
Alex,
The WRX had actually 2 cats on the downpipe but yes like you said it was on the upper area. The Evo 8 and the Evo 9 had two different o2 sensors locations and the shape of the cats are also different.
The o2 housing has one of the o2 sensors. Depending on if you have a Evo 8 or a Evo 9 that would determine wre the secondary o2 sensor is located. On the Evo 9 the secondary o2 sensor is located right above the cat which has a flat cut on top of it.
On the Evo 8 the secondary o2 sensors is located ion the rear section of the cat -back.
Do a search on my name, I posted many pics in the past displaying the different locations of the o2 sensors on the Evo 8 and Evo 9.
Carlos
I have an Evo IX MR and I just bought an Espelir JGT500r catback and an Espelir downpipe. I am also going to install a test pipe. Since there is one o2 sensor in the o2 housing and another located right above the cat, what can I use to plug up the now redundant third bung that came with the catback itself?
Offline
Apr 26, 2007, 09:44 PM
#41
Personal Sales Rating: ( 25)
Drives: 05 GG Evo VIII MR
usually, any exhaust piece you buy that has a bung in it, also includes a plug for the bung in case you're not using it.
Offline
Apr 28, 2007, 03:41 PM
#42
Because the 2 anti-foulers did not work with Buschur's exhaust. I took the one that the O2 sensor screwed into and braised a washer on it and made the hole even smaller to try to keep the gas that reaches the sensor to a minimum. I will let you guys know if this works for those of you who do not want to bang the crap out of the underbody to get the 2 anti-foulers to fit.
Offline
May 25, 2007, 04:17 PM
#43
Drives: 03 Evo 8 (silver)
dang....just got mine in the mail from Gruppe-S....13$$$ and thought that was a good deal....oh well...
__________________
O,O,O,OH SNAP!!
2003 Evo 8, HKS 272 cams, HKS cb, cat delete, helix dp, AEM intake, walboro 255 fp, custom dynotune reflash, Megan manifold, more to come......
"I am a hot little potato right now!!"
Look out for the 10,000+ posters, they probably have no lives..
Offline
May 25, 2007, 06:48 PM
#44
dang again, still got the check light, guess I need to do some tweaking..
__________________
O,O,O,OH SNAP!!
Offline
Jun 2, 2007, 12:19 PM
#45
Drives: WW EVO IX
Just did this 2 minutes ago on my ams tbe and then turned car on and no ses light, hopefully it stays this way. Thanks for the right up
Offline
Tags
42009, anti, bung, ford, fouler, foulers, fowler, mkv, mod, nonfouler, o2, oxygen, plug, pn, sensor, spark  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
