How do I remove Stock Guage Cluster
Looking for a quick write up on removing the stock guage cluster (RPM,MPH, TEMP). I have a few lights out that I need to replace. If possible please include small writeup on replacing the light bulbs for the back light.
It's just phillips screws and they're all fairly exposed. All screws are phillips head. Unscrew the ones for the surround shroud, then remove shroud. Once removed you will see the screws holding in the cluster on the outer edges for which you'll need a long phillips head screwdriver. Unscrew and pull the cluster.
Sorry to bring back this post from the dead but I managed to remove the cluster and hvac so install a double din, when I removed the cluster it had the what I assume is called the "shroud" or hose or whatever, and my question is is it ok to just leave it as is back there with the rest of the wires? Or should I crimp/kinked and just zip tie it so it doesnt leak or whatever it does? As seen on the fourth pic. Any help would be appreciated
nekkidlad
10
Sep 11, 2015 05:16 AM
