How to fix a stuck sunroof
Old Apr 2, 2010, 02:27 AM
  #106
ATTAHO's Avatar
I finally get to make a contribution. lol A
I just did this one hour before this post and it worked second try.(skipped a step first try) Hope this works for you guys.
https://www.evolutionm.net/forums/ev...ml#post8158403
Old Apr 3, 2010, 11:05 AM
  #107
Jogenmaru's Avatar
Im confirming this. It works.
Old Apr 7, 2010, 01:51 PM
  #108
Skott2k's Avatar
great write up everything worked well mostly for me, im a tard and somewhere along the line i only made it work like...1/2 way. it opens all the way up if i hold it. It closes but i have to push it like 20 times and wont just lift up. I guess that beats not working at all heh.
Old Apr 7, 2010, 01:57 PM
  #109
Skott2k's Avatar
I used this guide followed by ^ that guide and im back to working order...freaking awesome so happy. thanks guys
Old May 12, 2010, 12:55 PM
  #110
03nmeva's Avatar
i have a feeling my motor is starting to go out because its really weak but idk i realign it by pushing it back and making the motor go all the way back and when i try to close it it goes halfway and seems llike it gets stuck on something :/
Old Aug 11, 2010, 02:10 PM
  #111
lemmysports2's Avatar
ATTAHO thanks for the write up. i went to bolt my motor back up and the roof was out of sequence, i didnt know what to do.. you saved my ***. works great now.
Old Sep 6, 2010, 12:20 PM
  #112
Sir Lance-A-Lot's Avatar
Originally Posted by gbwaacha
ok so i finally got around to fixing my sunroof...and let me tell you that cajun power's instructions are great...i follwed them step by step and everything worked the way it was supposed to work....about that one screw thing holding the motor in place.....when i dropped my roof liner i had 2 screws come rolling out so i suspect that the screws came loose and fell out causing the motor to fall off track....anyways i put all three screws back in any everything works great....hes right about the visor clips being a pain but everything else is relativley easy if you have some patience....once again thansk for the write up Cajun!!
Funny thing is, this exact thing just happened to me. Sunroof went out a month ago and I had nothing but cloudy days here so I didn't care too much. Of course the last couple weeks of summer its been sunny as hell. I went to take the headliner off and those same 2 screws came out (the 2 outter most ones). The middle one was secured perfectly, kind of makes me think it was intentional maybe? A way for mitsu to get money or something?
Either way phenomenal write up, much appreciated because I was biting my nails prior to searching for your write up when I was just trying to figure it out as I go. Some things were self explanatory but once I got to the front portion to those damn clips I thought I was border line S.O.L.
Thanks again!
Old Nov 7, 2010, 07:02 PM
  #113
Evo3573's Avatar
my sunroof kicked the bucket also, anyone have any problems with the sliding headliner below the sunroof not working?
Old Nov 22, 2010, 11:20 AM
  #114
one4's Avatar
Thanks so much for the writeup!!! Saved me this morning. I was able to fix it in about a hour. It sounded like crunching metal! I only had one screw holding the motor in also lol
Old Jan 31, 2011, 08:56 AM
  #115
siceclipse's Avatar
My sunroof broke yesterday.
Found these instructions started on it this morning at 11am, finished at 11:45.
I only found 1 screw dropped and 2 were loose.
You only have to unclip the rear half of the liner.
I will also confirm that the initialization instructions work perfectly.
Old Feb 23, 2011, 09:07 AM
  #116
drift collab's Avatar
OMG Thank GOD I found this thread. I opened my sunroof and then found out it wouldnt close. I pulled it manually shut and will do the repair tomorrow! Thanks for the awesome info!
Old Mar 14, 2011, 04:34 PM
  #117
never2low's Avatar
Awesome, this worked perfectly!
Old Apr 21, 2011, 01:45 PM
  #118
donkey26's Avatar
wish there was pic... some of us are visual learners..
Old Apr 21, 2011, 01:55 PM
  #119
Tw3NTy0n3's Avatar
Picture of what exactly?
I used this guide to take apart mine but I drive an 04 Ralliart Lancer.
I was able to fix it, long story but it was not what everyone else is experiencing. In either case, I still have the top completely off and can take pics if it's the same.
Old May 1, 2011, 09:46 PM
  #120
godmiller10's Avatar
big fail of mitsu's part. My sunroof is doing this. won't tilt or close, just opens. Guess ill do this write up sometime soon! thanks
Quick Reply: How to fix a stuck sunroof
