Oct 5, 2009, 11:38 AM
#31
Personal Sales Rating: ( 33)
Drives: 04 EVO VIII - Tarmac
I think I will do this tonight, to check my valve stem seals and see just how bad my head gasket leak is...
Offline
Oct 13, 2009, 07:17 PM
#32
Personal Sales Rating: ( 4)
2003 Mitsubishi Lancer Evolution
Drives: 03 Mitsubishi Evolution
Mine came out at 150 across the board. My heart sank at first cause I thought that was bad lol. Good thing I searched on here before getting all emo lol.
__________________
FPRed - 880cc injectors - Walbro 255 - Comp 280's - Prostreet Adj. cam gears - Shep trans and t-case - ACT 6 puck - EPM o2 dump - Ebay downpipe - HKS catback - ETS short route piping - Ebay fmic - 3" mafless intake - Tien S-tech's - ARP headstuds - AEM Tru Boost - AEM UEGO
Stock block - Stock head - Speed Density
TTR tuned 435 hp & 355 tq - 93 octane
494 hp & 415 tq - Q-16
Offline
Oct 16, 2009, 11:36 AM
#33
Personal Sales Rating: ( 0)
Drives: 06' Totyota Prius, 04' TB Evo VIII
Really helpful info thanks!
__________________
Performance: AEM Intake, JDM BOV, Works DP, Resonated TP, Perrin Exhaust, Greddy UICP, IX Turbo, Titek O2, Perrin Stealth FMIC
Handling: Tanabe Springs, Cusco Rear Strut Bar, Works Sway Bar & Short Shifter Kit, Whiteline Spherical Rear Endlinks, Blox Engine Dampener, APR Front Strut Bar, Endless Brake Lines & CCX Brake Pads, Bridgestone Re-01R
292awhp/276tq
EvoEmpire.org (Server Norcal/Bay Area Evo Groups)
Offline
Oct 31, 2009, 02:46 PM
#34
Drives: 03 Evo, 04 f350 crew cab dually, 04 g35, 91 TSI
140, 130, 130 and 135. It's ok cause I'm planning on building the motor. I just needed to know why I couldn't push more than 26psi on a aka green. No boost leaks as well for max psi.
__________________
a turbo thingy
Offline
Oct 31, 2009, 06:35 PM
#35
Drives: evo
This is a good how to
Offline
Tags
180, 427, check, compression, engine, evo, evo8, ix, min, pressure, reading, test  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
