Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 27, 2007, 07:56 AM   #16
Personal Sales Rating: (0)
Drives: EVO 8
Great writeup. I was about to go do this at a dealership or a shop but now I think I can do it myself.
Thanks a lot. I'll post results by this weekend.
Tony
Offline
Old Feb 11, 2008, 05:20 PM   #17
Personal Sales Rating: (52)
evodan2004's Avatar
Drives: 03 Evolution 8
Send a message via AIM to evodan2004
ok i did the how to which worked great but here are my results.
1. 170 at 7 cranks 180 at 10 cranks
2. 175 at 7 cranks 180 at 10 cranks
3. 175 at 7 cranks 180 at 10 cranks
4. 180 at 7 cranks 185 at 10 cranks
i did not know how many cranks to allow so i did a reading a 5 7 and 10. 5 was the same at 7 basically..
so to the pro's how is my compression looking???
to do a wet test how much oil do we add?? do we do it when the motor is hot as well??
03 evo8
stock blcok
60k miles
__________________
JESTR TUNING - FULL-RACE - SPARK TECH - NISEI ENGINEERING - DRIVEN INNOVATIONS - DOG BOX RACING
NEW JERSEY EVO OWNERS *THREAD*
My F/S thread STOCK & AFTERMARKET *CLICK HERE*
WTBWTBWTBWTB : Evo RS door handles
Offline
Old Feb 11, 2008, 05:33 PM   #18
evodan2004's Avatar
03 evo8
stock blcok
60k miles
bump
__________________
Offline
Old Feb 11, 2008, 05:40 PM   #19
evodan2004's Avatar
03 evo8
stock blcok
60k miles
bump
sorry motor is getting cold. dont know if i should do this hot warm cold.
__________________
Offline
Old Feb 11, 2008, 06:07 PM   #20
evodan2004's Avatar
bump
__________________
Offline
Old Feb 18, 2008, 12:15 PM   #21
Personal Sales Rating: (4)
broddey's Avatar
Drives: Graphite IX MR
Send a message via AIM to broddey
So if I can't keep my engine running for long, what should the compression be when cold?
Mine read 120 on three cylinders and 115 on the fourth. Any ideas as to whether or not this is normal on a cold engine?
Offline
Old Apr 8, 2008, 01:43 PM   #22
Drives: Weightless Evo VIII
bump for last two questions!
Offline
Old Apr 8, 2008, 05:31 PM   #23
Personal Sales Rating: (1)
Drives: 03 Evo
I got 177 178 177 180 from passenger to driver side. I let the engine crank over for approximatly 3 seconds. Engine coolant temp was 50 degrees. Does is change if the car was not warmed up before the engine was compression tested? Does the amount or time you let your engine crank over increase the psi.
Offline
Old Jun 9, 2008, 11:33 AM   #24
Personal Sales Rating: (20)
Inprogress's Avatar
Drives: 2006 EVO IX
Send a message via AIM to Inprogress
Will I need anything else besides this?
http://www.harborfreight.com/cpi/cta...emnumber=95187
In terms of any connectors?
I know I'll need connectors to remove the old spark plugs, but what about connecting the compression tester into the cylinder?
__________________
2006 Evo IX
GSC S1 Cams // Megan TBE // PTE 1000cc Injectors // Apexi Filter // Perrin FMIC // AMS LICP // ETS UICP // Walbro Pump // Hallman MBC // ACT HDG6 Clutch + ACT Streetlite Flywheel // BC Coilovers // Blox Front Mount
"We are what we repeatedly do. Excellence, therefore, is not an act, but a habit." -- Aristotle
Offline
Old Mar 9, 2009, 10:45 AM   #25
Personal Sales Rating: (33)
Redline06's Avatar
Drives: 06 RR Evo IX MR
Send a message via AIM to Redline06 Send a message via MSN to Redline06 Send a message via Yahoo to Redline06
Bumping from the dead.. lol
Can this method be applied to other cars as well.. ie. the wife's corolla..lol
__________________
IX MR
FS: Forward Facing 62/62 Kit
Offline
Old Mar 24, 2009, 11:04 AM   #26
Personal Sales Rating: (11)
Sievers's Avatar
Drives: Fully Built 2.3L Evolution VIII
Nice. Does anyone know how to find out your compression ratio? I have no idea.
Offline
Old Apr 27, 2009, 07:01 PM   #27
Personal Sales Rating: (24)
detroit pistins's Avatar
Drives: tb ix gsr ssl
bump
Offline
Old May 19, 2009, 01:23 AM   #28
Personal Sales Rating: (3)
guapoholic's Avatar
Drives: his evo like he just stole it
Send a message via AIM to guapoholic
As a rule, most engines should have 140 to 160 lbs. (in the Evos case High 170) of cranking compression with no more than 10% difference between any of the cylinders.
-Low compression in one cylinder usually indicates a bad exhaust valve.
-Low compression in two adjacent cylinders typically means you have a bad head gasket.
-Low compression in all cylinders would tell you the rings and cylinders are worn and the engine needs to be overhauled.
__________________
Pow, right in the kisser.
Offline
Old Jun 21, 2009, 02:55 PM   #29
xRoguex's Avatar
Drives: 2005 Evo SSL
Send a message via AIM to xRoguex
Just picked up my evo - did a test. Car has unknown mods. with 60k on it - i got 179 across the board on 5 cranks.
Sounds odd?
Offline
Old Oct 2, 2009, 05:47 PM   #30
kaj
Personal Sales Rating: (6)
Drives: '06 MR/'95 Civic DX coupe
Send a message via AIM to kaj Send a message via MSN to kaj
155/150/155/132
Offline
Tags
180, 427, check, compression, engine, evo, evo8, ix, min, pressure, reading, test
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
