May 4, 2005, 07:51 AM
Personal Sales Rating: ( 2)
Drives: a POS
Walbro 255lph Fuel Pump
Another install guide for the Walbro fuel pump.
http://bolsen.homeip.net/fuelpump.htm
Offline
Jun 2, 2005, 08:31 AM
Drives: '03 Lancer EVO VIII
there are a few things I would add to that install.....such as when you unscrew the black cover, disconnect the harness from the fuel pump, and try to crank the car before undoing any fuel lines........also, on # 8. I would like to emphasize what he is saying about not pulling too hard. I pulled too hard, and the wires came out of the harness, so i put them back to what I thought was correct, reinstalled the pump, tried to start the car, and it wouldnt start. so, I had to remove the pump again, and swap the wires.......it was a very big pain in the ass for no reason
__________________
I miss my:
03 EVO 8 Apex Silver
Offline
Jun 10, 2005, 10:09 PM
Drives: a POS
Thx for the feed back.
Offline
Jun 19, 2005, 12:04 PM
Drives: 2004 EVO GSR
sorry to hate on your how to but i found this to have more info.
http://www.evomoto.com/tech_info.php...3_13&tech_id=9
__________________
Of all the thing I have ever lost, I miss my mind the most. - OZZY
Offline
Jun 20, 2005, 04:50 AM
Personal Sales Rating: ( 3)
Drives: 111SM
yeh, that ones good.. but it's easier once you jump on the fuel install first.
Hardest part is, of course getting the metal seal in, which isn't hard as people make it out to be.
it's a simple math.
Offline
Dec 23, 2005, 05:48 PM
Personal Sales Rating: ( 0)
Drives: Evo 8
I pulled too hard
Quote:
Do you recall if the blue wire or the black wire was closer to the release tab? I pulled to hard myself. That could be taken the wrong way
Offline
Feb 14, 2006, 03:22 PM
Personal Sales Rating: ( 4)
Drives: Z06 Vette(SOLD!!!), Civic, Evo VIII
I would just like to add, DO NOT DO THIS WITH A FULL TANK OF GAS, I did (the rocket scientist that I am) and it wasnt pretty, gas everywhere.
__________________
Attn Mitsubishi: Any and all modifications to my vehicle are equal or higher in quality and performance to those that were provided stock. As such under Title 15 Chapter 50 of U.S. Code (aka the Magnusson-Moss Warranty Act of 1975) particularly Section 2302(c) Mitsubishi must honor the warranty as provided with the car. Any refusal of service must be accompanied by absolute proof that an aftermarket component was the cause of any failure in the OEM materials. Failure to adhere to the letter and spirit of the law will result in prompt legal action against Mitsubishi and/or their authorized dealer.
Offline
Feb 14, 2006, 03:24 PM
Personal Sales Rating: ( 10)
Drives: Tarmac Black 05 HTA 35R powered by ETS
lol ^^
Offline
Feb 24, 2006, 11:52 PM
Personal Sales Rating: ( 1)
Drives: 03 RR EVO VIII, 07 Kawi ZX-6R
i was wondering if this would be the solution from my car start being able to start up after installing my ExHAUST FLOW....HELP SOMEONE HELP!!!
Offline
Apr 13, 2006, 05:55 AM
Personal Sales Rating: ( 8)
Drives: 2006 GG MR :)
Type of oil used to set the pump / gasket
The link refers to using a light oil when setting the fuel pump back into the gasket. What type of light oil are people using? Is there a TSB from Mitsu stating what to use? Thanks -- great link btw
__________________
3" Modified Megan Racing TBE & UR Cat.
Buschur O2 & Buschur Exhaust Manifold
Nisei LICP
DC2 oil catch can
Walbro Fuel Pump
Injen intake and UICP (w/ Perrin Filter)
ETS 3.5" FMIC
Zeitronix ZT2, ZAVT1, and Boost solenoid Failsafe
SMC Kit (50% Meth / 50% h2o )
GM 3 port BCS (28psi tapering to 22psi)
Enkei 17 x 9.5 NT03M 275/40 Azenis
Offline
Apr 14, 2006, 05:48 AM
Please help w/ light oil used....
bump ++ Please help...
__________________
Nisei LICP
DC2 oil catch can
Walbro Fuel Pump
ETS 3.5" FMIC
Offline
Apr 14, 2006, 08:21 AM
Drives: 03 evo 8(sold),05 sti(sold), 07 subaru tribeca, 97 Supra Turbo, 06 GG MR IX
When I did my pump I used just a little (just a touch on the tip of your finger) of mobil synthetic. Of course use new oil not old! I have never had a problem!
Offline
Apr 14, 2006, 09:09 AM
Personal Sales Rating: ( 11)
Drives: Stealth EVO
Make sure you do this with as little gas as possible.
__________________
K, thanks.
Offline
Jun 15, 2006, 02:38 AM
Personal Sales Rating: ( 5)
Drives: IX RS AMS 2.3L 35R
The first time I bought the Walbro pump, nothing came with! Only the pump itself. This is my second Walbro pump and it cames as a kit.
I didn't use the rubber isolator that came with the kit... I used the stock one... is it bad?
__________________
Offline
Aug 30, 2006, 11:56 AM
Anyone?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
