Quote:
Originally Posted by stevolee
My fuel gauge won't read anymore, but my fuel pumping is working.
I've heard that the floater could be disconnected, but how can I tell? Please, any info would be of great help!!!
Did you bend or damage the fuel level sender? Make sure thats ok. make sure the harness going into where the pump slides in didnt get damaged.
btw, I would like to add that on the evomoto how to where it states to use a 5.5mm too lock the ring onto the filter for the pump. A 4mm works MUCH better. just make sure its straight then push down on it. I used a 5.5mm and it just kept bending the ring but it never wanted to slide down.
I found the ring surround for the fuel pump assembly wasnt too bad to come out. You just have to angle it and pull the sucker out.
