Mar 1, 2007, 08:10 PM
Personal Sales Rating: ( 0)
Drives: Wicked White Evo IX MR
I just installed mine today using this link http://www.evomoto.com/tech_info.php...3_13&tech_id=9 what everyone says about not having much gas is definetely true, i had 3/4 of a tank, big mess. The only extremely annoying part is getting the big black piece that holds the stuff in off and back on...
__________________
Cobb tuned at:
312whp @ 24psi
285 ft/lb torque
Numbers off Mustang dyno on 91
Engine:TurboXS TBE, TurboXS FMIC, Injen Intake w/ upper and lower i/c piping, Forge Unos MBC, Walbro 255 FP, FP EVO Green, 750cc injectors, 02 housing
Misc.:Alpine 9857 Head Unit w/ ipod cord, JL W6v2 10" sub., Alpine 650 Watt amp., Beatrush Aluminum Undertray, 3M 20% Tint, Steering Wheel mounted Defi Boost Guage
Offline
Apr 14, 2007, 01:39 PM
Personal Sales Rating: ( 1)
Drives: evo8
i pulled the wires out too...........can anyone tell me which wire goes closer to the tab??.......aslo the other wire at the bottom of the assembly came out of where it goes in to top (the wire under the high pressure hose) can i get help on that??
__________________
hks intake, cusco turbo pipe, ams lower intercooler piping
hallman mbv, 3" O2 housing, 3" B&B turbo-back, 10.5 exhaust housing, hks 280 in/ex cams, smc methanol injection, zeitronix wideband, dynoflash and WORKS Pll, evoscan 9.0
12.03@ 117mph 28lbs with meth.
Offline
Apr 14, 2007, 02:32 PM
Drives: evo8
bump
__________________
Offline
Apr 14, 2007, 05:23 PM
Drives: evo8
c'mon someone help please
__________________
Offline
Apr 19, 2007, 10:01 PM
Personal Sales Rating: ( 21)
Drives: 2005 VIII
Not sure...
if you still need this but on the connector you got two big wires and two small. The two small are both black (obviously) and the two big if you are looking at it from the front with the two and the three smaller holes facing away from you and the bigger wires facing you, the black goes on the left, the white on the right
__________________
2005 EB VIII with everything except injectors and a bigger turbo!
Thanks to Evolution Dynamics for the great work!
Offline
Apr 23, 2007, 05:32 PM
Personal Sales Rating: ( 32)
Drives: Tarmac 06' Evo --> Evo-NY #55
hmmm i did a few of these installs already so everything was super smooth when i did another today... now its been a year since i did my last so ill ask this one question.....
after the white plastic housing is dropped back into the tank and the black metal ring is fastened back down with the nuts, does anyone know if the white housing should be able to move ever so slightly? mine can move about 1mm all around. concerned w/ a fuel tank, fuel may spill over.
Online
Jun 8, 2007, 11:23 AM
Personal Sales Rating: ( 4)
Drives: 2006 Evolution IX (Traded) 2008 Apex Silver EvoX GSR
i'll need to do this. good write up.
Offline
Jun 8, 2007, 12:46 PM
Personal Sales Rating: ( 2)
yea i am gonna have to install mine really soon
Offline
Jul 7, 2007, 06:54 PM
Drives: TB Evo IX MR
good write up, did mine a few weeks back, didnt need the install kit, well it didnt come with it, but it turned out fine reusing the stock pieces.
Offline
Jul 7, 2007, 11:53 PM
Drives: Evo 9
I followed the evomoto install tutorial and it took maybe a half an hour start to finish....I reused the stock pieces and it works great.
mifesto - you shouldn't be able to move the pump housing, the black ring holds it in place, did you remove the gasket on the underside by mistake? Maybe you didn't line it up correctly(the ring, though I don't see how you could tighten the nuts if you did mess up)
Offline
Jul 8, 2007, 12:11 AM
Personal Sales Rating: ( 5)
Drives: 03 EVO VIII
i didn't use any of the parts out of the kit. i heard the filter form the kit was sucking in and causing problems, so i just stayed with the stock pieces, including the rubber. it should not be a problem. i was instructed to do this and it has worked for the last 2 years.
Offline
Jul 16, 2009, 04:11 PM
Drives: Evolution VIII MR RS
Is there any DIY Double pumper???
Offline
Sep 4, 2009, 08:26 AM
Drives: Evo VIII
Good write up
Offline
Sep 10, 2009, 03:27 PM
Drives: 2005 Evo VIII
i got mine on but it doesnt prime...
__________________
3" Megan TBE
Greddy Profec B boost controller
K & N cone filter
Forge Wastegate
Walbro 255 Fuel pump
Turbo XS Upper and lower intercooler pipes
AGP Fmic
Exedy Stage 1 Clutch
Tuned Diiirk@AWDmotorsports
Online
Sep 30, 2009, 12:23 AM
Drives: EVO IX
Will this info to my mechanic , he will be doing it next week...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
