Clutch Pedal adjustment
Old Apr 7, 2005, 12:26 PM
rkm625's Avatar
Started with this info : http://www.socalevo.net/forums/viewtopic.php?t=2493
Some of it was wrong, for me anyway.
To take the plastic off under the steering wheel it was 2 phillips head screws and one 10mm bolt. and then 2 more phillips screws to get the hood release off. It did help a little taking that piece off.
the nut you have to losen to get the rod free was a 12mm not 10mm. It's a pain in the as to get in there to do it. Once you losen the nut you can turn the rod. If you push on the pedal a little bit it makes the rod turn a lot easier. I'm not sure what everyone needs to do as far as personal adjustment but:
Fewer threads on the end = Less play
More threads on the end = More play
Keep track of how many turns you do so you can go back to where you started from. Good luck
Old Apr 7, 2005, 12:41 PM
marksae's Avatar
Why do you need to take off the plastic cover under the steering wheel? I can adjust my clutch without taking any panels off. I have an 03 if that makes any difference.
Old Apr 10, 2005, 10:44 PM
RalliArtEvoVIII's Avatar
ok? there is no need to remove anything, ONLy tools i needed was a simple flashlight and a 12mm open end wrench and my thumb and index finger...
1.pull driver seat all the way back and lay so u can see under the dash
2.locate the clutch rod first thing, its very skinny with a 12mm locking nut.
3.loosen the 12mm locking nut with the 12mm wrench, once loose, u can use ur hands from here on.
4. turn the rod and u'll see the clutch start moving towards the ground or off the ground.
5. adjust as u wish, hold the rod with finger and lock the 12mm locking nut. done.
antics22
Evo X How Tos / Installations
201
Jan 5, 2022 06:24 PM
tlcoll1
Feb 24, 2018 10:06 AM
antics22
267
Dec 6, 2016 08:40 AM
MitsuJoe
468
Feb 20, 2016 11:17 AM
trinydex
172
Feb 2, 2016 10:35 AM
Quick Reply: Clutch Pedal adjustment
