Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo How Tos / Installations > Evo How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 26, 2004, 11:22 AM   #1
Personal Sales Rating: (56)
Jakeg97's Avatar
How to install the spark plug anti-foulers to remove the ses or cel light
this install was hard to find so i decided to write this up to make it easier to catch it on the search
this installation will remove your SES (service engine soon) light , or CEL (check engine light) that is caused when you install a test pipe (no cat) or high flow cat.
when this light comes on from your install of a new exhaust , be aware that this has no effect on the performance of your car. its just a stupid reminder that the o2 (oxygen) sensor is finding a problem caused when you removed or did something to the stock catalytic converter.
btw - i thought about going with an o2 simulator / eliminator , but the cost / install / problems associated with this fix. did not appeal to me.
Offline
Old Dec 26, 2004, 11:23 AM   #2
Jakeg97's Avatar
notes before starting
- you might have space for only 1 spark plug anti-fouler, sometimes using 1 will work / sometimes not
- having an electric drill helps out tremendously , those battery operated ones dont have that much power; they will still work but will be a pain
- this may still not solve your problem of the light; a small percent of people that try this 'quick fix' still cant get the light to go off
STEP 1
-purchase 2 spark plug anti foulers at your local auto parts store
-18 mm size
-made by HELP brand / part number 42002
-HELP has also another part number 42009 and are shorter in length than the 42002, i have read that they work
$5 o2 cheater/non fouler how-to
STEP 2
-disconnect the negative terminal on your battery. this will reset your ecu
-take one of the anti foulers and drill out its center using a 1/2 bit ,
-this will increase its hole size and allow your stock o2 sensor to fit
STEP 3
-screw the drilled spark plug anti-fouler on top of the original
-be sure to use some kind of anti-seize on the treads. in case you need to remove your fix with ease
STEP 4
-unscrew your stock o2 sensor and place your cel / ses fix in
-use anti seize on the threads
-clean your cell (by wiping it off with a paper towel)
STEP 5
-reinstall your o2 sensor
STEP 6
-reconnect your battery (your ecu is reset)
-you have just solved the problem of the 'damn light keeps coming on'
ps. it cost me 8 dollars for the pack of 2 spark plug anti-foulers
Offline
Old Dec 27, 2004, 08:59 AM   #3
Personal Sales Rating: (0)
Robbyh's Avatar
Drives: 05 Evo VIII
I only used one of the anti foulers (since using two made the end of the 02 hit the bottom of the car.) No Cel with just one installed.
Offline
Old Dec 27, 2004, 09:07 AM   #4
Personal Sales Rating: (43)
eve-slow's Avatar
Drives: GG IX
So what does this process have to do with spark plugs? Also, you still may get the SES light because I have the Helix tp with mechanical fix (which is basically the same thing as you have done by putting the 02 sensor away from the direct exhaust gases) and the light is still on. You never know though, you may get lucky with no light!
__________________
06 EVO GG IX
03 EVO RR VIII (She gone)
95 Red turbo Integra GS-R (She long gone)
RUSH GROUP DETAILING
MY IX GG
MY IX GG
Offline
Old Dec 27, 2004, 10:56 AM   #5
Personal Sales Rating: (4)
berkel's Avatar
Hi,
I also used just the drilled anti-fouler. It's pretty tight with one on my car, and two may have been a problem. It's worked great so far.
The hardest part for me was driilling the damn thing out with my weak-sauce cordless drill, lol.
eve-slow question, did you reset the light and then it turned on again? I think it's hit or miss with some cars, and/or may require tweaking to get the O2 sensor to see an acceptable amount of exhaust...
Take care,
FB
__________________
03 EVO - DIY grounding mod, DEFI mech boost gauge, Hallman MBC, Forge BPV, K&N Panel Filter, NGK BPR7es, MAP O2 Elim DP, MAP IM/EM, MIL.SPEC TB/CAT, Fujitsibo CB, Walbro FP, AMS I/C and piping, Buddy Club 264/272, Evo 6.5 TME Turbo,
ACT Clutch/Flywheel
331HP 338TQ DynoFlash
Offline
Old Dec 27, 2004, 04:30 PM   #6
Jakeg97's Avatar
Quote:
thats the name of the item that gives you the fix.
i have had no problems with the light as well as many other people. however a small number of people do continue to get the light.
are you able to use this method with your Helix mechanical fix? like added to it?
Offline
Old Dec 27, 2004, 07:27 PM   #7
Personal Sales Rating: (17)
bigmac's Avatar
Drives: 2003 EVO VIII-Rally red; Yamaha YZF426; Kawasaki 1500 Vulcan Classic; SGS Pro downhill mountain bike
I added a MR downpipe, Ultimate RAcing hi flow cat and a BR catback to my car and immediately began getting CELs. I did this fix-took about ten minutes to do it, and I have been CEL free for about 6 weeks now. Worked great! (I used both anti foulers, and they fit easily the way the BR catback sits on the car.
__________________
2003 Rally Red EVO VIII, Vishnu Xede Stage 1, cams, BR turbo back, other stuff.
Offline
Old Dec 27, 2004, 07:36 PM   #8
Personal Sales Rating: (11)
Evillusion's Avatar
Drives: 2005 Nismo Frontier
excellent write up and nice pics. I will be doing this "mod" this week so nice timing also!
I purchased the Help p/n 42009 antifoulers. they are shorter than the 42002 counterparts. I'll let you guys know if they work or not.
__________________
Tell your mom she still owes me $50
Offline
Old Dec 27, 2004, 07:36 PM   #9
JTB
Personal Sales Rating: (23)
JTB's Avatar
Drives: BMW M5, Caterham Superlight R
I initially tried with just one and immediately got the CEL again. I then added the second and... Success! No more CEL!
This is an easy, effective, cheap fix!
__________________
JTB
Acceleration is meaningless if it can't stop and handle -- this includes turning right!
Video -- Chasing down an F40 Caterham style -- PPIR May 2004
Picture Diary Scotland -- Elise and Caterham
Offline
Old Dec 27, 2004, 11:13 PM   #10
Jakeg97's Avatar
another link for the fix
http://forums.evolutionm.net/showpos...1&postcount=14
Offline
Old Dec 27, 2004, 11:17 PM   #11
JTB
JTB's Avatar
Quote:
Originally Posted by burningmoney97
STEP 5
This step is actually very important! Don't forget the anti seize!
__________________
JTB
Offline
Old Dec 27, 2004, 11:24 PM   #12
EvoM Super Moderator
Silver Vendor
Personal Sales Rating: (65)
Zeus's Avatar
Drives: Old Man with a 03' EVO VIII, 05' Subaru 2.5GT Limited, 06' Kawa Z1000, 02' Kawa ZR-7s, 07' GSXR 1000 (babysitting lil' brother's ride while he's in the sand box), 00' Integra Type R SOLD
Send a message via AIM to Zeus
Both anti-foulers worked for me... the one alone didn't.
__________________
Contact me for parts -n- installs!
Best deals on All Megan products!! Megan Evo X turbobacks and O2 housings!!! OE TYPE replacement rotors-n-pads DEAL. I'm only available 8am-12pm Central Tues-Sat, available all day Sun/Mon. Currently only accepting PayPal, all sales final, customer warranty claims processed directly through the original manufacturer. All shipping quoted for the contiguous 48 states.
Offline
Old Dec 28, 2004, 12:21 AM   #13
Personal Sales Rating: (30)
good write up
__________________
RETIRED
Offline
Old Dec 28, 2004, 12:30 AM   #14
BuLocal's Avatar
Drives: Z06 Vette(SOLD!!!), Civic, Evo VIII
Same here. Clearance will depend on your exaust. Most setups clear with two antifoulers.
__________________
Attn Mitsubishi: Any and all modifications to my vehicle are equal or higher in quality and performance to those that were provided stock. As such under Title 15 Chapter 50 of U.S. Code (aka the Magnusson-Moss Warranty Act of 1975) particularly Section 2302(c) Mitsubishi must honor the warranty as provided with the car. Any refusal of service must be accompanied by absolute proof that an aftermarket component was the cause of any failure in the OEM materials. Failure to adhere to the letter and spirit of the law will result in prompt legal action against Mitsubishi and/or their authorized dealer.
Offline
Old Dec 28, 2004, 08:22 AM   #15
EVOwhat's Avatar
awesome write-up!...this should be a sticky in the EVO how to's and installations...
Offline
Tags
anti, antifouler, antifoulers, dp, fouler, integra, mod, numbers, o2, oxygen, part, plug, remove, sensor, spark, sparkplug
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
