How to install the spark plug anti-foulers to remove the ses or cel light
#64
Originally Posted by fyr3
whats anti-sieze?? <-- noob
http://www.napaonline.com/MasterPage...+%26+Lubricant
#66
Just a word of advice: don't panic if it comes on at first
I only made it 2 miles down the road before a cel, but it may have been some cleaner or debris from the installation/drilling of the anti foulers..... because the next day I drove a few more miles and the light was gone..... 11 runs at the drag strip and 60 miles later, still no cel
of course now that I posted this it will probably come back on
#72
There are 2 O2 sensors on the Evo. The first is before the cat and the second is after the cat. You do not need to worry about the first.
As far as using 2 anti-foulers you are basically stepping the O2 sensor further out so that it sees even less air from the exhaust flow and hence less likely to give a SES light.
#73
On the IX, there is an 02 on the actual cat...
I was more talking about what I should use to plug the 02 which came on my catback cause my testpipe also has an 02 port (for the IX)
#74
If you go to the manufacturer of the exhaust, assuming you bought it new, you might be able to get a plug. Otherwise this is one I found -- the plug is standard and should fit. Good luck
http://www.diyautotune.com/catalog/i...3736-p-71.html
#75
i had a member pm with a couple questions that might help others out
q
"Are you saying to do this for both the catback and for the testpipe so that the o2 sensor reads further away from the exhaust?"
a
since you have a 9 , you would need to do the o2 fix to the test pipe bung, or to the catback that has a bung after the test pipe without one.
using the stock 9 cat, you will not need the fix. even with a different downpipe
q
"what would happen if I were to just scew in the 02 sensor to my catback and get a testpipe without and 02 bung (the IX's have an 02 port on their cat)?"
a
it would throw a code and your exhaust would now look like/designed all evo 8s with the same problem after switch out the stock cat.
which have the bung for the o2 sensor after the cat and on the straight/intermediate pipe
q
a
q
a
