How to install the spark plug anti-foulers to remove the ses or cel light
#46
Is the CEL trown by an "over lean" mixture? Has anyone pulled the code? It seems that the only thing this mod, and RRM's version, does is limit the amont of gas that passes through the O2 sensor. If the CEL was somethig else, this theoretically wont help, right?
#48
btw for those needing a shorter setup. possibly running catless stock exhaust. You can take 1 anti fowler and drill it almost to the end very close then get a few washers and stack up then thread the o2 back in works like a charm on the stock exhaust....
#52
Originally Posted by Evo9"Miss Rose"
^^^im pretty sure it does!!! i just got my SES light on today soo imma try this METHOD!! sounds eazy and cheap and it Does the job
#55
ok...for the people like me that has the hks cf ti exhaust my friend and i made a 90 degree anti fouler..ill post pix of wat we made..works great..no cel..we might even make some if people need them...
#59
yeah, my light keeps coming on no matter what i do..... put one drilled in and it worked for about 5 miles, then came on..... and it rattles on the underbody, no room for two so i tried a 90 deg. elbow.... worked for 15 miles, then the light is back on..... idono what the hell is up with this thing.
