Bad misfire @5-6k...help please
Ok another issue, to start off, car has 255 fuel pump, 1000cc injectors, jun cams, ams built ect ect.. I noticed it started mis firing about 2 weeks ago if you was to get wot, but it got worse, now it seems one whole cylinderr if not 2 isnt firing, idles perfect, normal driving is great as well, always shell or bp 93 oct or 110, its not bad gas...I changed the plug wires and spark plugs, same **** still happens...
.023- car is tuned at 22psi pump gas... im thinking it's one of the factory coil packs.. its was tuned and maped by Chris at AMS...I bought the car from a guy that had her to 50k miles...20k on build..it ran great for about 6 weeks then this happened.. MAF Hmm maybe ill look at the sensor real fast
mxguy1286
Jan 26, 2011 03:53 PM
