evo in hard right corners and oil pressure
Old Mar 6, 2023, 11:52 AM
JamieEVO8's Avatar
whats the max the oil pressure is allowed to drop when doin hard turns without a baffled sump?
the track i go to assen TT has many right turns and the oil pressure stayed between 4 and 5 bar in corners
is that good?
oil im using is 10w40 motul 300v
Old Mar 6, 2023, 03:43 PM
Abacus's Avatar
I'd prefer no less then 50-70psi at a guess. Moments of low oil pressure aren't good for the turbo or engine bearings.
Could add 20-50 and a 1/2 qt over stock to try to compensate until you can upgrade the pan.
A common rule of thumb is anything more then a 200tw tire and 10/10ths driving needs a race fab or infinite pan.
Old Mar 7, 2023, 04:35 AM
JamieEVO8's Avatar
i already do the 1/2 t over stock
im using toyo r888r's though 50psi is like 3.5 bar it never went below 4 bar
bebecko
May 1, 2020 06:28 PM
gasolinebaptism
Mar 12, 2015 08:00 PM
superlemonevo
Jan 11, 2010 08:20 AM
exacc
Apr 21, 2008 09:34 AM
QuickEvo
Dec 31, 2003 03:54 PM
Quick Reply: evo in hard right corners and oil pressure
