Need advise
Need advise
Hey everyone,
I am in the middle of replacing my clutch and I was taking off the fly wheel to go have it resurface when I noticed one of the bolts are pretty rounded. Every other bolt came of just fine but this one will not budge. I tried to be careful as much as possible but its pretty bad.
Anyone have any advise on how to get rounded bolts out? I did run to the store and get a socket that is suppose to grab it but the socket "teeth" just rounded out.
Thanks!
Thanks!
You should post up a pic so we can see how bad. Typically your best bet is to hammer on a smaller socket but if yours in damn near completely round then there is no edge for the socket to grab. They do make those twist sockets you bang on like the ones you would take a wheel lock off with if you do not have the key. Similar idea though, hammer it on and hope it bites when you put torque on it.
It was completely rounded then i took a grinder to it to square it up a bit and hammered a socket on but as soon as i used the impact on it, it would just pop off
I was gonna say to put 6 point edges on it again and try. Hm. I would do it by hand. The impact might be hurting you. I would spend time to makes some edges, get socket with a good bite and do it by hand. That way if you can see the socket begin to slip, stop take it off and grind or change sockets. The impact is just gonna spin like crazy and you cannot watch it like you can by hand. Once it moves a little bit you are home free so i would do it by hand.
edit, Put pressure on back of the rachet while turning to keep the pressure towards the flywheel to help keep it from slipping off
Thanks
I would put all the other bolts back in and tighten them so all the pressure isn't on the bolt you're trying to get out. Like others said, try and get edges back on it and use a smaller socket, or a crescent wrench, or cut a line down the head of the bolt to get a flat head chisel with a socket on the end to turn it. There's a bunch of ways, just get creative and take your time!
I will try this when I get home. Good Idea. And trust me I get pretty creative haha I had to make my own slide hammer with the handle from my jack a long bolt and some washers. Haha
Old Eagle
15
Apr 21, 2013 02:49 AM
ToddMcF2002
Jul 4, 2011 08:08 AM
webguy330i
Sep 7, 2005 12:27 AM
