Ecu question???
Old Aug 9, 2013, 05:43 AM
OPENA(671)'s Avatar
Ecu question???
When I bought the car, It had a aftermarket ecu. I bought an stock evo viii ecu. So my question is. Is it ok to just switch and plug in the stock ecu?
Any ideas help. Thanks.
Old Aug 9, 2013, 05:52 AM
gpfury86's Avatar
Need more info, what ecu was in it? What map sensor is on the car? A lot of times other ecu's have different sensors ie. air intake temp, wide bands, oil pressure and temp, among many other sensors that the stock ecu won't be able to recognize.
Old Aug 9, 2013, 03:24 PM
OPENA(671)'s Avatar
The current ecu is an apexi power fc. The only sensor on it is an apexi safc2. I'm planning on taking that out too. Besides that, everything is stock. Hope that's the info you needed.
Old Aug 9, 2013, 05:52 PM
gpfury86's Avatar
It should be fine if its a plug and play box, I'd just hook the stock ecu up, load a tune, and see what she does.
Old Aug 9, 2013, 07:21 PM
OPENA(671)'s Avatar
Cool. I'll try it out. Thanks.
Old Aug 10, 2013, 07:39 AM
misterevo8's Avatar
depends on your mods on the car. what if it is an ecu tuned specifically for the set up. be careful.
Old Aug 10, 2013, 01:50 PM
OPENA(671)'s Avatar
Hmmm.... Yeah. I'm taking that into consideration. The car has some basic bolt ons, nothing extreme. The previous owner didn't really tune with the ecu.
What's the worse thing that could happen?
Old Aug 10, 2013, 02:45 PM
misterevo8's Avatar
oh, you will be fine with basic bolt ons. i do suggest however, once you get the stocker ecu on it, get it tuned for optimal performance and reliability.
Old Aug 10, 2013, 04:17 PM
OPENA(671)'s Avatar
Oh. Ok. Thanks for the advice. Had me thinking there for a moment.
Old Aug 10, 2013, 04:41 PM
OPENA(671)'s Avatar
I switched my ecu, now it won't start!!! What's could be wrong?
Old Aug 10, 2013, 05:46 PM
gpfury86's Avatar
Did you load a tune into the stock ecu that's compatible with your car/setup, the injector scaling many things could be wrong to cause it not to run. BTW by my earlier statement I didn't mean to start the car and go floor it, i just meant to get the car started and idling, the ecu will need to be tuned for boost most likely unless it's a bone stock car, which with a stand alone I highly doubt it is.
05Evolution8MR
Dec 16, 2014 09:29 AM
ApacheToYaDome
Feb 6, 2013 06:51 PM
doghouse
16
Apr 11, 2012 10:34 AM
Quick Reply: Ecu question???
