Steering wheel not lining up!
Old Jan 15, 2011, 12:43 PM
FoxFister's Avatar
Well, after A terrible mishap I had with letting someone work on my car and deciding to drop the subframe to do A clutch job. I finished the install myself but when I went for A drive I noticed I did not line up the steering wheel column spines right and now my steering wheel is about A 1/4 turn to the right when it's supposed to be straight. My question is, is there anyway to fix this without having to drop the subframe again?!?!
Old Jan 15, 2011, 12:51 PM
Bobster22388's Avatar
This is why you are supposed to unbolt the power steering rack from the sub-frame and leave it all attached to the car when you do remove the sub-frame. Sounds like your going to have to pull it all back down and readjust it.
Kracka's Avatar
Any alignment shop can fix it, or you can get under there and do it yourself if you prefer. You should be able to do it both under the dash or under the car.
Old Jan 15, 2011, 01:03 PM
Celica2EVO's Avatar
If you take the bottom half of your dash off under your steering wheel and the bottom cover off the steering wheel you can fix it easily. There are 4 bolts that hold the steering column up. You will have to undo the steering column and pull it off the shaft coming through the firewall. After that, line up the splines and put it back together. Repeat until its straight. After that put a line on the shaft where they meet to mark where its straight. Its FAR easier to drop the subframe on a clutch install is why they did it. Once its marked its easy to line up from there out.
Old Jan 16, 2011, 12:14 AM
Silver Sponsor
SpoolinUp's Avatar
Sounds like a good plan. Personally I put a line on before so I know how many splines I went over, then erase it when finished and make a new line.
Such a pity that some mechanics are so careless.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jan 16, 2011, 12:36 AM
mr.saechao's Avatar
Just get an alignment done and you will be ok, your toe is off adjustment and an alignment will correct it.
BluEVOIX
Jul 31, 2017 07:49 PM
OX
Dec 30, 2016 05:52 PM
KiDMaTiX
Jun 5, 2016 04:40 PM
deeman101
Oct 27, 2014 11:28 PM
theblue
Jul 28, 2008 01:04 PM
Quick Reply: Steering wheel not lining up!
