Gas pedal sticking when cold
I do this every winter. I have another opinion about why we get so much build up. I think it might have something to do with the air cleaner elements. I think oiled filters ala k/n or Perrin, etc have a bit of extra slime going through. I never had this issue the first winter i had the car. The following summer i replaced with a Perrin and have had to clean every winter since.
This theory is based on the fact that if the gunk was oil based it would thicken in the winter. The only other explanation is that the tolerance on the butterfly is so tight that temperature causes the contraction. Which would have been a factor the first year i owned the car but wasnt.
Keeping it clean keeps me from waking up the neighbors with that first 'kick' of the cold car LOL.
Take Care..
Take Care..
Take Care..
Take Care..
im willing to bet you that anyone whos eliminated the EGR doesnt have this problem anymore...
Could be EGR. But my 'annual' issue started after the air cleaner. I am not to worried about it. Its very easy to take care of.
I tend to think the gunk is oil based tho. Carbon usually doesnt clean up as easily. Carbon would be EGR for sure. The only expereince i have cleaning carbon is with a bead blaster or on old carbureated cars; we used to trickle water down a hot engine to break the stuff out of the cylinder heads.
But i have to say that i bought the car used last year, so maybe the first owner lied to me and he modded the car before, then put it back to stock and i will never know it. So maybe someone that own the car stock since 0 miles will confirm.
Friggen glad I stumbled on this thread. I just thought it was normal for the first few minutes to be sticky but now I know its something to fix.
Too bad its -30C (-22F for you americans) here so It may have to wait till a bit warmer day. Enjoy your nice weather florida (bastards)
I like these little tricks i'm learning from evo m.. so far my other fav is spraying hairspray on IC couplings for grip after mine blew off. Thanks guys!
Wow, came on to look for a solution to this and it's right here on the first page. I bought the car brand new on 08/2006 15miles on the odo, it started sticking this winter currently at 67,000 miles.
I purchased my car brand new with a handful of miles. I've never modded and noticed this "sticking" problem just within the last month with about 36,500 miles on the clock. While the carb cleaner certainly cleaned some of the film/dust from the TB and turned a brand new toothbrush black, there wasn't any thick build up of gunk like I was expecting. Maybe it doesn't take much to cause the valve to stick, but I wonder if this problem will return when the temps dip again.
GM dealers also sell stuff called Top Engine Cleaner, this stuff is evil. It will destroy any carbon build up on anything, it will also destroy paint so be careful. I keep a few cans laying around all the time.
