Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo General
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Sep 10, 2010, 05:57 PM   #1
Personal Sales Rating: (25)
Garage is empty, add now
2plaz's Avatar
Drives: EVO9
Points: 2,270, Level: 28
Points: 2,270, Level: 28 Points: 2,270, Level: 28 Points: 2,270, Level: 28
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
No Spark!? CPS bad?
so i started my car the other morning and drove about 5ft out of the drive way and the car turned off. it wouldnt start back up so i tried to push start it... still didnt start.
yesterday i trouble shot it and found Fuse #1 under the steering column blown. replaced it but still no start.
i can smell gas when it cranks... so, yes, it cranks.
i pulled two different plugs and used two different kinds of coils to test for spark... bang! none.
no CEL codes... my conclusion is that my crank position sensor is bad.
so i have 3 questions now;
has any had a similar issue and how did u fix it?
is the CPS from a 2g dsm the same as the evo?
where can i find a write up on how to replace it? (i just want to see where the sensor end plugs into)
__________________
team Redline
Quote:
Originally Posted by 05evoGSR View Post
the FAIL is strong with this one...
Offline
Old Sep 10, 2010, 09:52 PM   #2
Personal Sales Rating: (9)
2003 Mitsubishi Lancer Evolution
apexisilver8gsr's Avatar
Drives: 03 evo 8
Points: 2,766, Level: 32
Points: 2,766, Level: 32 Points: 2,766, Level: 32 Points: 2,766, Level: 32
Daily Activity: 0%
id say its ur ECU man i had a problem where something burnt out inside the ECU where one of the coils wasnt getting spark
Offline
Old Sep 11, 2010, 03:58 PM   #3
2plaz's Avatar
Drives: EVO9
Daily Activity: 0%
Quote:
yeah but none of them are.
the ignition coil was popped and i changed it... still didnt start.
__________________
team Redline
Offline
Old Sep 11, 2010, 04:15 PM   #4
Personal Sales Rating: (48)
LGshow19's Avatar
Drives: Fast Taxi
Points: 2,212, Level: 28
Points: 2,212, Level: 28 Points: 2,212, Level: 28 Points: 2,212, Level: 28
Daily Activity: 17.0%
Daily Activity: 17.0% Daily Activity: 17.0% Daily Activity: 17.0%
You probably have something grounded on some type of frame or metal...
I had the ignition fuse pop and I would replace it, but it will pop again after it would start...
The ground was the rear 02 sensor was sticking to far out of the exhasut(extender bung so it wouldn't throw a code) and was rubbing the frame... Problem fixed once I removed the extender bung
hope this helps
Offline
Old Sep 11, 2010, 09:20 PM   #5
Personal Sales Rating: (8)
2005 Mitsubishi Lancer Evolution
lp_ceo's Avatar
Drives: grey sedan with a wing
Daily Activity: 0.4%
Daily Activity: 0.4% Daily Activity: 0.4% Daily Activity: 0.4%
check with a scanner to see if you have any codes and if your crank sensor is reading, then go from there .
__________________
DIPP,CEO
BURRUS & SMITH AUTOMOTIVE CORP.
Offline
Old Sep 12, 2010, 08:21 AM   #6
2plaz's Avatar
Drives: EVO9
Daily Activity: 0%
hope this helps
yeah i think i read an older post, maybe yours, about someone with those problems.
my fuse hasnt popped since i replaced it and my wires are good.
i hoping this would have been the problem cuz its an easy fix.
__________________
team Redline
Offline
Old Sep 12, 2010, 08:21 AM   #7
2plaz's Avatar
Drives: EVO9
Daily Activity: 0%
Quote:
dont have any codes.
how do i check if the cps is reading?
__________________
team Redline
Offline
Old Sep 12, 2010, 08:42 AM   #8
Personal Sales Rating: (2)
PurEvo's Avatar
Drives: o6 MR
Points: 6,307, Level: 51
Points: 6,307, Level: 51 Points: 6,307, Level: 51 Points: 6,307, Level: 51
Daily Activity: 0%
What did you do to solve your problem? I'm having the same problem right now and can't seem to figure it out.
__________________
06 RR IX MR - Weekend/Play monster - DD atm
07 VR C6 Z06 - weekend/getaway
Offline
Old Sep 12, 2010, 09:43 AM   #9
Personal Sales Rating: (3)
My Garage
italianevo88's Avatar
Drives: ford f350/ 2003 evo 8
Points: 5,546, Level: 47
Points: 5,546, Level: 47 Points: 5,546, Level: 47 Points: 5,546, Level: 47
could it be the cam position sensor? those are real finiky
__________________
03 EVO- FP- Black- Strictly Modified
Offline
Old Sep 12, 2010, 05:40 PM   #10
2plaz's Avatar
Drives: EVO9
Daily Activity: 0%
Quote:
ive already gone through the CAS troubles during my cam install and test run. the CAS was on backwards and codes showed up. but yeah i did check them.
__________________
team Redline
Offline
Old Sep 12, 2010, 05:42 PM   #11
2plaz's Avatar
Drives: EVO9
Daily Activity: 0%
yeah but non of my coils are getting spark
Quote:
x2
__________________
team Redline
Offline
Old Sep 12, 2010, 08:12 PM   #12
Personal Sales Rating: (1)
white_evo27's Avatar
Drives: 03 ww evo SOLD! 03 tb evo
Points: 4,954, Level: 45
Points: 4,954, Level: 45 Points: 4,954, Level: 45 Points: 4,954, Level: 45
Daily Activity: 1.7%
Daily Activity: 1.7% Daily Activity: 1.7% Daily Activity: 1.7%
plug ur battery in!
__________________
2003 WW Evolution Vlll... 423whp/361tq *10/22/10 R.I.P
... 2003 TB Evolution 8.5 ... 535whp
UMADBRO? Built
E-Spec Tuned
E-SPECPOWER.COM
"NOS is like a girl wit an STD, u wanna hit it but are afraid of the consequences"
Offline
Old Mar 24, 2011, 09:12 PM   #13
Personal Sales Rating: (7)
CristianRO's Avatar
Drives: 03 Evolution VIII
Points: 2,747, Level: 31
Points: 2,747, Level: 31 Points: 2,747, Level: 31 Points: 2,747, Level: 31
Daily Activity: 0%
Quote:
So im assuming you have fixed the problem ... could you please let me know what the answer was so i can try to fix mine. im having the same type of behavior out of my Evo 8. recently did the 60K service install + cams + cam gears.
Thanks in Advance!!!!
Offline
Old Mar 24, 2011, 09:47 PM   #14
LGshow19's Avatar
Drives: Fast Taxi
Might have install the sensor in the wrong position.
Offline
Old Mar 25, 2011, 12:04 PM   #15
CristianRO's Avatar
Daily Activity: 0%
i didnt.. :/ i actually took a picture of the area after the install .. and looking at the picture you can tell is install corectly
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
2g, bad, cas, cps, crankshaft, dsm, ecu, evo, evolutionm, gas, position, sensor, spark, start, test, www2plarz
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
