Question about Muse Piping.
Okay, so i plan going with the Muse Upper (Short Route) and Lower Piping, the question is, has any body went with that set-up and used it with the stock intercooler? If so, how's the fitment on it? And notice a big difference in spool/power?
Also, if any of you guys have the piping with the Niesi intercooler, how's the fitment for that?
Thanks.
Thanks.
I personally like the Nisei, they make one of the shortest routing LICPs and it comes with a bracket too. The Nisei comp intercooler is probably the biggest core one you could get and fit under stock crash beam gl.
i was running both the upper and lower piping. the upper used to be a cheaper aluminum based piping, now its a stainless steel pipe. The only downside to this is its heavier, but you dont have to worry about crushing the ends with tbolts. Its got a new design so you can recirculate stock bov as well with stock recirc tube, no extension junk anymore.
The lower pipe is stainless steel also, and seems to fit perfect. I used this setup on my perrin fmic and put down 551/486 with correction in 97f on a properly reading mustang dyno. the pipes seem to flow and do what they are meant to do, and they do not create boost leaks even at 40psi of pressure.
VRSF Tiago
EvoX 'For Sale' External Engine / Power
169
May 5, 2019 02:35 PM
vipevo9
Jun 7, 2015 12:58 PM
dtrackstar
Aug 7, 2011 11:34 AM
rcheung
50
May 6, 2009 08:18 AM
