Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo General
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Mar 26, 2010, 07:09 AM   #1
Personal Sales Rating: (0)
Garage is empty, add now
SnowEvoVIII's Avatar
Send a message via AIM to SnowEvoVIII
Post Driving with a bad alternator? need help quick
11 hours from home. Alternator is dead from what I can see. With jump starts at gas stations, can I make it home freeway driving? I'm pretty sure I know my answer, but I need to ask regardless
Offline
Old Mar 26, 2010, 07:23 AM   #2
Personal Sales Rating: (13)
2005 Mitsubishi Lancer Evolution
Bobster22388's Avatar
Drives: '14 WW Ralliart
roconnell mrboobster evogamer05
I'm going to say no here. There is no way for the battery to recharge. Which means all of the electronics in the car are going to go out and the engine will just stop running.
__________________
LaScuola Motorsports
2014 WW Ralliart
K&N SRI, many more mods to come!
Offline
Old Mar 26, 2010, 07:45 AM   #3
Personal Sales Rating: (3)
silverIXMR's Avatar
Drives: Evo 9 MR, 01 2500hd 8.1l allison
yea once the battery dies the car wont jump start anymore if the alternator is bad too. put a multi tester on it when its running if possible.if you get a little over 14volts then you just need a battery and the jump starts should get you home. if it is under 12 volts call AAA. good luck bud
__________________
Evo IX MR Stock motor, turbo, trans
AMS TBE/ GRIMMSPEED EBCS/ FORGE WGA/ COSWORTH M3/SUPERTECH VT/ARP HS/TURBO XS FMIC/ PIPING
EXEDY TWIN HD/ WORKS CLUTCH LINE/BUSCHUR SHIFTER BUSHINGS/ MAP o2 DUMP/BLOX FILTER
FIC 1100/ MAP REV2 IM/ MILSPEC 65mm TB
///BRENTUNING
Offline
Old Mar 26, 2010, 08:07 AM   #4
Personal Sales Rating: (2)
Drives: BBY Evo VIII
This is ghetto....ghetto buddy but I've done this before. I put a jump box on my car and just left it on there.....I was able to close the hood(wasn't on an evo) and I was able to get where I was going.....I only went like 5 to 10 miles though. That's a lot further. Towing it would be your best option.
__________________
TeamREDLINE
---WWW.MIDWESTEVOS.COM---
Offline
Old Mar 26, 2010, 08:29 AM   #5
Poik242's Avatar
11 hours, no way.
__________________
2006 TB SE 384awhp
1997 30th Anniversary Z28: Long tubes and stuff. 294rwhp/326rwtq
1988 Volvo 740 Turbo: Junk yard parts and gypsy tears. 270rwhp/317rwtq @ 17.5psi
1984 Volvo 242 Turbo: HX50, Bayliner Capri engine, T56, BMW E39 IRS. Jack stand queen.
Offline
Old Mar 26, 2010, 08:50 AM   #6
haha I told you it was ghetto! Just stop at Napa or Autozone or O'Reileys or any parts star and see if they can get you an alternator and let you borrow some tools. Not a hard install.
__________________
TeamREDLINE
Offline
Old Mar 26, 2010, 08:53 AM   #7
Personal Sales Rating: (14)
Genesis8's Avatar
Drives: Evo \////
Yep, no way.
Quote:
Originally Posted by Poik242 View Post
11 hours, no way.
Offline
Old Mar 26, 2010, 08:57 AM   #8
Hey OP where are you at? I seen you are from CO, I'm station in SD if you are anywhere around this area i.e. a few hours away let me know.
__________________
TeamREDLINE
Offline
Old Mar 26, 2010, 09:19 AM   #9
glgz's Avatar
Drives: 03 EVO 8
I would say you could go maybe an hour at most with nothing on in the car if that. 11 hours no way. I would just by a new one and put it on. I changed on the side of the road once on my old Z-28. I didn't have a choice has it locked up and wouldn't let me even turn it over.
Offline
Old Mar 26, 2010, 10:40 AM   #10
Personal Sales Rating: (1)
jestoy7's Avatar
Drives: 2012 Evo X
Send a message via AIM to jestoy7
Are you sure it is the alt and not a bad ground or bad battery connection? These can cause symptoms of a bad alt too. Worth checking, good luck!
__________________
Johann / 2012 Evo X
Offline
Old Mar 26, 2010, 11:12 AM   #11
Personal Sales Rating: (35)
JakeTheVIII's Avatar
Drives: 05 Silver Evo 8.5, 03 TB Evo 8 Project, 08 R6, and Sievers' 2.3L 37R Evo 8 @ 40+ psi
Ok here's what you do. Use a power inverter inside the car to plug into cig lighter, plug in your jumpbox to the inverter, hook to the battery, should be good to go.
Just kidding. There's no way you'll make it 11 hours. One battery would die within an hour. Use a generator inside the car! It's gonna be a long way home. If towing it is not an option, drive as far as you can, stop and charge, repeat.
Offline
Old Mar 26, 2010, 11:15 AM   #12
Quote:
Good point! We all took his word that it was a bad alternator when it could just be a loose/bad connection.
__________________
TeamREDLINE
Offline
Old Mar 26, 2010, 01:33 PM   #13
Personal Sales Rating: (4)
EvoVan's Avatar
Drives: EvoIV
You wont be able to get more than an hour out of her.
Offline
Old Mar 26, 2010, 01:35 PM   #14
Poik242's Avatar
On an 11 hour trip you will spend more time recharging the battery and stopping than it would take to just replace the alternator.
Quote:
__________________
2006 TB SE 384awhp
Offline
Old Mar 26, 2010, 02:18 PM   #15
No way its gonna last 11 hours. I had the same problem with my explorer, but after about 30 mins city driving, all gauges died, everything, and the car was sputtering all over, but just made it home.
And im sure the evo needs a lot more electronics to run properly so..
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
1988, 1997, alt, alternator, bad, bayliner, driving, evo, explorer, generator, inverter, jump, power, repeated, starts, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
