Battery Tray for Miata Battery?
Old Jan 31, 2010, 04:37 PM
TK40's Avatar
Hey guys,
I want to get a smaller battery so when I get around to doing a bad *** intake manifold I can fit the short route pipe. I've been researching this for a little while and it seems like the Miata battery is the way to go for someone like myself.
The only place I could find that sells a kit that has a tray that works with the Miata battery is Boost Logic, but their kit is a bit too pricey imo. They want $265 for the full kit with Battery, but I can get a new OEM Miata battery for like $120.
I was wondering what trays people are using with their Miata batteries?
Old Jan 31, 2010, 07:56 PM
Itchy's Avatar
seems easy to make a tray for it once i received it, but i did need to trim it in certain areas because it didnt fit with the engine mount. i say to get the im first and have custom pipe made because with many intake manifolds it puts the inlet farther out causing the need of custom pipe for correct fitment
Old Jan 31, 2010, 08:10 PM
talonkev's Avatar
I could only find one vendor that made a tray for the Miata battery, and the quality didn't look very good. I just opted to make my own tray.
Old Jan 31, 2010, 09:43 PM
TK40's Avatar
Talonkev, do you have any pictures of your tray? I guess if I can't find one for sale I'll see if some of the welders on my job can help me put one together.
Old Dec 9, 2011, 02:07 PM
talonkev's Avatar
I have had a few people PM me and ask for pictures and more info on the battery tray I made a while back. I was just recently putting the trans back in the car and took the time to snap some pics. The Miata battery has been great to me over the last 2 years, and I would recommend it to anyone.
This tray was made utilizing the stock tray, a piece of 3/16" aluminum plate that I had laying in the garage, and some 3/4"x3/4"x1/6" aluminum angle. It also uses the stock hold down bolts bent into a "J" shape.
I made an album in my profile page with more pictures if anyone is interested and would like to see more.
Attached Thumbnails Battery Tray for Miata Battery?-p1040262.jpg   Battery Tray for Miata Battery?-p1040266.jpg   Battery Tray for Miata Battery?-p1040287.jpg   Battery Tray for Miata Battery?-p1040291.jpg   Battery Tray for Miata Battery?-p1040306.jpg
Old Feb 2, 2012, 11:50 PM
10isace's Avatar
Great job What UICP is that? Do you know if all the short route UICP will work with this mod?
Old Feb 3, 2012, 05:42 AM
talonkev's Avatar
The UICP pictured is a MUSE. I would guess that any of the short route pipes would work, but I have no personal experience with any other brand UICP to know for sure. You just need to make sure the pipe allows space to fit the 7 1/2" L x 5" W x 7" H Miata battery.
Old Feb 3, 2012, 11:40 AM
Redoctane's Avatar
how much is it new
Old Feb 3, 2012, 11:56 AM
talonkev's Avatar
Originally Posted by Redoctane
how much is it new
I'm assuming "it" means a Miata battery. I have seen them range between $120-$150 depending on which brand you get.
Old Feb 3, 2012, 02:24 PM
10isace's Avatar
I got mine for $95 at Orielly's.
Old Feb 19, 2012, 10:27 AM
silverevo05's Avatar
Well I test fitted a honda battery group 51 not 51r and it fit great my only concern is that I had to cut both side supports on the battery tray to make it fit and I fear that it will slide forward to back upon acceleration and decel.
I guess I will have to go miata. What is the lowest cca our cars need?
Old Feb 21, 2012, 11:10 PM
evolutong's Avatar
subscribed
Old Feb 21, 2012, 11:20 PM
sujinX's Avatar
does anyone actually make this kit? i'm really wanting to do my 51r battery rather than the huge mitsu battery. the 51r saves about 10 lbs over stock, but it has power for all the other crap, like alarm, radio and stuff. dont like the mini battery idea for daily car.
Old Feb 21, 2012, 11:27 PM
SaulHudson's Avatar
You know I had an idea. Not sure weather it is brilliant or bad. Maybe someone could try out Reese Tuning's BR battery tray knock off. It is very ill fitting of the mini battery and is larger so it might fit somewhat ok for miata?
Old Feb 21, 2012, 11:45 PM
SOEuro's Avatar
i LOVE my miata battery, just make your own tray
Quick Reply: Battery Tray for Miata Battery?
