Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo General
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Feb 23, 2012, 09:06 PM   #16
Personal Sales Rating: (7)
Garage is empty, add now
Drives: 05 SSL,06 EB GSR, 06 AS GSR, 06 AS SE, 06 AS SE #2 (current) SE
Points: 8,148, Level: 60
Points: 8,148, Level: 60 Points: 8,148, Level: 60 Points: 8,148, Level: 60
Daily Activity: 13.0%
Daily Activity: 13.0% Daily Activity: 13.0% Daily Activity: 13.0%
this is what I'm going to do
Click the image to open in full size.
Offline
Old Mar 9, 2012, 01:49 PM   #17
Personal Sales Rating: (0)
artinist's Avatar
Drives: 06 EVO IX
Points: 7,237, Level: 56
Points: 7,237, Level: 56 Points: 7,237, Level: 56 Points: 7,237, Level: 56
Daily Activity: 7.8%
Daily Activity: 7.8% Daily Activity: 7.8% Daily Activity: 7.8%
it might be easier to pick up a used miata tray and screw it on top of the stock tray after its been cut to size. that way it will look nice and will not let the battery slide back and forth
__________________
88 Starion 341 RWHP on 91 octane (sold)
97 3000GT VR4 (sold)
Offline
Old Mar 9, 2012, 05:18 PM   #18
artinist's Avatar
Drives: 06 EVO IX
both autozone and o'rilley have the 90-97 miata battery for $105 which can be found on their site. prices may differ depending on zip code.
Here is the necessary stuff to mound the miata battery for $20
just trim the evo one to size if you like than screw this on top of it and you are done:
http://www.partsgroup.com/images/sales/IM001343.jpg
http://www.partsgroup.com/store.aspx...ta-Misc&Page=2
__________________
Offline
Old Mar 9, 2012, 05:37 PM   #19
Personal Sales Rating: (17)
Drives: 2006 Evolution SE
Points: 6,893, Level: 54
Points: 6,893, Level: 54 Points: 6,893, Level: 54 Points: 6,893, Level: 54
Daily Activity: 1.6%
Daily Activity: 1.6% Daily Activity: 1.6% Daily Activity: 1.6%
The battery from Autozone here isn't an AGM battery, but the O'Reilly one is. Both AZ and Wal-Mart both only had regular acid batteries. I'll take a pick tomorrow of the custom aluminum tray that I made.
Offline
Old Mar 10, 2012, 03:21 PM   #20
Here is mine with the tray that I made. I picked up a small piece of aluminum, made a template, then bent the aluminum in a vice. I heated it a little to make sure that it didn't crack, but it didn't break in my tests without heat. I picked up some battery holds at AZ for about $3 and the top bracket for about $5. I powder coated it at work. I picked up a sheet of a rubberized foam with an adhesive back for $1 at Hobby Lobby to guarantee it wouldn't slide at all. There is also a bracket that bolts to the transmission mount bolts and attaches to the tray for extra support. I've got about $15 into this tray. The UIP in the picture is an old ETS pipe, but my Buschur short route UIP clears it without a problem. I will take pics of it when I finish breaking in my new engine and go speed density which will be about 500 more miles.
Offline
Old Mar 10, 2012, 07:41 PM   #21
artinist's Avatar
Drives: 06 EVO IX
clean work. nice
__________________
Offline
Old Mar 10, 2012, 08:35 PM   #22
Personal Sales Rating: (19)
Drives: 06 Evo MR, 98 GTi 2.0T
Points: 4,981, Level: 45
Points: 4,981, Level: 45 Points: 4,981, Level: 45 Points: 4,981, Level: 45
Daily Activity: 14.8%
Daily Activity: 14.8% Daily Activity: 14.8% Daily Activity: 14.8%
I'm looking into this as well. I would of thought the CCA of a miata bat. was over 400... but almost all of them state 370. There are some better specs on some of the braille batteries... although price is ~$50-75 more.
Offline
Old Mar 10, 2012, 09:13 PM   #23
Personal Sales Rating: (6)
Drives: 95 eagle talon tsi awd, 03 VIII
Points: 2,586, Level: 30
Points: 2,586, Level: 30 Points: 2,586, Level: 30 Points: 2,586, Level: 30
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Quote:
Originally Posted by TK40 View Post
Talonkev, do you have any pictures of your tray? I guess if I can't find one for sale I'll see if some of the welders on my job can help me put one together.
For what its worth, it was around 32* here Friday and my VIII started strong on a duralast gold miata battery from autozone. I'm sure the higher cca the better but how much does one actually "need" .
Offline
Old Mar 11, 2012, 10:15 AM   #24
Quote:
Just general information. Most Evo replacement batteries are 500+ CCA and a lot are in the 600's, so apparently Mits thinks that's what you need, however, they also design the vehicles to survive (like most OEM's) in -40F weather, so if you lived in Minnesota or Alaska ... where ever, it certainly is 0F for a lot of the winters, -20F is common for mornings.
Its not necessarily one morning or day it was 32F, its for constant time periods which will actually start bringing the internal temperature of the battery down which will make it hard to start, these are the reasons why you need high CCA.
On a second note, your battery is an energy storage bank, if the OEM didn't believe it needed to be the size that it is, than all batteries would be tiny, its not like OEM wants to add weight to your car for no reason...but again it depends on the usage and the design requirements the manufacture believes you need.
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
2000, battery, boost, bracket, evo, evolution, evolutionm, kit, lancer, logic, mazda, miata, mount, oemmiatabattery, tray
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
