Got a boost controller ??
I am about to purchase a boost controller but I do not know if I should go electronic or manual. And which brand has the best over all performance? I see the Hallman makes a good manual. I was also looking at the Turbo XS hp manual controller also. But what about say the Grimmspeed one that plugs straight to the OEM harness?
you are talking about three different things
grimmspeed's device is used with ecu controller boost
an ebc just gives you more functionality and better temperature change self-adjustments
a mbc is the tried and true simplest way to control boost
you need to do more reading
closed...
closed...
