Aug 29, 2009, 03:01 PM
Personal Sales Rating: ( 3)
Drives: EVO IX
Door for gas tank broken??
I just went to the gas station to pump some gas and ran into a problem. The lid/door wont open, I pressed the lid release thing a bunch of times and it won't open and now I can't pump any gas. The lid is stuck closed. Mitsu closed down in my area and the nearest dealer is an hour away. Any idea whats wrong with the door? Can anyone tell my what parts I need so I can oder them and fix the lid?
thanks
Online
Aug 29, 2009, 04:03 PM
Personal Sales Rating: ( 0)
Drives: 2003 Evo 8
It is most likely the door spring. It is a piece of metal than helps the open when you pull the fuel door relice. I dont know the part number off hand you would need to go to the dealer for that but in the mean time all you need to do is use a flat headed screw driver and when you are holding the door relice buttion use the screw driver and pry it open just try to no scratch your car.
Offline
Aug 29, 2009, 04:10 PM
Personal Sales Rating: ( 1)
Drives: 2003 TB Evo VIII, 1991 CRX Si B16 Turbo
This question should be a sticky lol
__________________
~ 2003 TB Evo 100% stock, for now : P ~
Offline
Aug 29, 2009, 04:44 PM
Drives: 2004 mazda protede 5 and 2005 Mitsubishi Evolution 8
Have someone hold the fuel door release latch and someone else trying to pry it open. Of course without breaking it..
Offline
Aug 29, 2009, 09:24 PM
Drives: 03 Evo
I had this problem in my accord and it would randamly do it, I would some times take a key and try to pull the door a little and some times that would work but mostly I just kept lifting the lever up and down alot of times!! there were times I thought I wasn't going to be able to get gas!! VERY FUSTRATING
Offline
Aug 29, 2009, 09:37 PM
Drives: 03 Lancer OZ, soon to be an evo IX MR, funds almost accumlated:)
My lancer is like this. I just put my wallet under the gas release leever and push on the left side of the gas door to open it. No biggy.
edit to say you need to leever all the way up.
__________________
"I can't take HIS money, I can't print MY OWN money, I have to WORK for money, why dont I just lay down and die? "
Offline
Tags
acces, accord, broke, broken, car, cover, door, evo, gas, lid, problems, shut, spring, stay, tank  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
